2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: 8HP Transmission Fluid Service
      02-23-2024, 02:19 AM   #89
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Originally Posted by Smytty View Post
Had this thread pinned for a while; going to tackle this sometime in March just trying to visualize the repair. This is done entirely without the wheels spinning? Can I keep the car on Jack stands while running through the ISTA procedure or will the wheels have to be on the ground?
The wheels will not move during the below procedure?
Step 4. Foot on brake, release parking brake, shift car into reverse, release brake. Wait 10 seconds. Brake, shift into drive, move shifter to the left and go into M1. Release brake, wait 10 seconds. Shift into M2, wait 10 seconds. Brake, shift into park, engage parking brake.
BMW was not clear on the wheels part, but when I contacted ZF, they said the wheels should NOT spin. So, yes, keep car on jack stands, and then just keep your foot on the brake pedal any time you're in gear.
Thank you for bringing Step 4 to my attention, I had neglected to update that step to reflect the ZF information. You should NEVER release your foot off the brake.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      02-24-2024, 10:50 AM   #90
Smytty
Thank you for the clarification. Also Thanks for the write up will be tackling this in the coming weeks. I’ve only done trans fluid in my late Great E60 6MT. Just drain and fill.
Diff fluid on a RWD 550 is just drain and fill correct?
      02-24-2024, 11:27 AM   #91
Unspec
Unspec's Avatar
1301
Yep nothing fancy. There's no drain plug IIRC so you need to figure out how to suck out the fluid. I used thin poly tubing to mine out.
2015 BMW 535xi
      03-15-2024, 11:04 PM   #92
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
I deeply respect the attention to detail in making this for all of us to use! I want to do this myself, I have the tools for it, I know my 5er will greatly benefit from a drain and fill.
      03-15-2024, 11:13 PM   #93
One big reason I don't do this is the need to keep the car level. I'm also not young enough anymore to do all this work lying on my back.
      03-17-2024, 03:39 AM   #94
ChiltiCoatl89
Buy a lift!
      03-17-2024, 05:50 PM   #95
Originally Posted by ChiltiCoatl89 View Post
Buy a lift!
Won't fit in my garage...
      04-18-2024, 06:20 AM   #96
BuiltnBoostedZ
Drives: 2012 535ix
Good write up. Bout to do this after I swap coil packs, spark plugs, water pump, and front brakes. Sitting at 53k miles.
2012 F10 535ix - JB4 - BM3 - Meisterschaft GTC - coded modules - CF front lip - CF rear diffuser - clear bra
