2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 535i/xi Dinan available
      07-25-2014, 02:53 PM   #1
voyagergab
voyagergab's Avatar
Drives: G82 M4 6MT, G01/F97 X3M
Lightbulb F10 535i/xi Dinan available
Got this email from our Dinan rep at the dealership here in Canada:
D-TRONICS Performance Tuner
For the F10 535i/xi
D-TRONICS Performance Tuner for
F10 535i (N55) (RWD & xDrive)
For vehicles with a production date before
July 2013 (Mechanical Diaphragm Wastegate)
Stock Performance:
300 HP, 300 lb-ft torque
With D-TRONICS Tuner (Stage 1):
364 HP, 375 lb-ft torque
Installed $2420.00 + GST
D-TRONICS Performance Tuner Description
The D-TRONICS Performance Tuner is a highly engineered and sophisticated
piece of computer hardware and software that enhances engine
performance, without negating or voiding your new car warranty coverage
and without affecting long term reliability or the functionality of
on-board diagnostic systems. It was also designed to be emissions legal
in 50 states (E.O. Pending). The ultimate objective of developing this
piece of technology was to provide the ability to control every signal
entering and exiting the BMW factory Engine Control Unit. These items
are unique to Dinan and together they embody the apex of performance
engineering in a powerful, reliable, and warrantied package.
The Dinan Difference
The biggest benefit of Dinan's D-TRONICS Performance Tuner is our ECU has the...
"...capability
of setting an optimum target lambda (fuel mixture) as well as
correcting short term trim which is the difference between target and
scheduled fuel mixture. By matching these two correctly we can reduce
knock sensor activity which will make smoother performance, protect the
catalyst, increase power and allow us to make it emissions legal."-
Steve Dinan
The
Dinan Difference is possible by employing a full staff of talented
engineers that are well rounded in all aspects of their job.
Manipulating these signals with an adept hand all the while keeping an
engine running at its best and with the most reliable power is what
Dinan is all about.
Well Engineered
Plug-in tuning devices all have one thing in common, they send a modified
signal to the factory ECU, telling it the boost pressure is below target
values. This then causes the factory ECU to raise the boost pressure to
what it thinks is the correct value. This modified boost pressure
signal causes errors in fuel mixture and ignition timing. These errors
can cause the on-board diagnostics systems to set faults, but they can
also cause exceedingly high catalyst temperatures and a loss of power.
In addition, when power is increased, exhaust gas temperature will
increase as well and this must be countered with a slightly richer
air/fuel mixture. The D-TRONICS Performance Tuner uniquely has the
capability to adjust target Lambda, correct short term trim as well as
ignition timing errors induced by raising boost pressure. This enables
Dinan calibration engineers to optimize air/fuel mixture and ignition
timing at elevated boost pressure throughout the entire gamut of engine
RPM and engine load. Additionally, the ability to correct short term
trim corrections (the difference between target and scheduled fuel
mixture) remain within OEM specifications. This minimizes knock sensor
activity, which in turn means smooth engine performance, catalyst
protection and power increase, while this is also required to make the
car emissions legal. Dinan engineers have worked for two years on the
D-TRONICS Performance Tuner in efforts to provide BMW enthusiasts with
Performance without Sacrifice.
State-of-the-art Hardware
The D-TRONICS Performance Tuner is engineered using the best possible
components and advanced hardware. The most obvious and visible component
is the elaborate wiring harness. Using OE connectors and an expandable
braided wiring sleeves ensures that all visible components appear as if
they come straight from the factory. More importantly however it
guarantees long lasting and dependable performance due to the use of
high heat, moisture and abrasion resistant materials and design. The
other hardware element involved is the Dinan electronic control unit
(ECU) itself. While its outward appearance may seem tame, the
processing power and sophistication held within its internal circuitry
is anything but. Capable of delivering signals to various systems at an
astonishing 4000 times per second the D-TRONICS Performance Tuner yields
the power to control all current signals delivered to the ECU as well
as those developed in the future without a hiccup in performance or
reliability. This immense processing power equates to a high degree of
engine control resulting in a much lower likelihood of setting a fault.
In addition smoother running conditions and superior drivability are
achieved, all of which are Dinan hallmarks.
Unmatched Warranty
Dinan's comprehensive warranty program, introduced in 1997, provides superior warranty coverage to that which you would find elsewhere. If
your vehicle is currently covered by the vehicle manufacturer's new car
limited warranty, Dinan® products are warranted for the remaining term
of the vehicle manufacturer's new car limited warranty. The
manufacturer's new car warranty is limited to 4 years or 50,000 miles
(80,000 kilometers in Canada), commencing on the date of first retail
sale or the date the vehicle is first placed in-service as a
demonstrator or company vehicle, whichever is earlier. Dinan's
warranties are transferable when ownership of the vehicle into which the
Dinan products were originally installed is sold. BMW
automobiles can now be performance-tuned without the associated concern
of negatively affecting the new car warranty coverage.
Drivability
There is more to a tune than just cranking up the boost. Power needs to come
on smoothly and in a predictable way to make the car as fun to drive at
wide open throttle as cruising around town. It is your BMW, but reborn
with new found acceleration and speed.
Designed for the Future
The Dinan D-TRONICS Performance Tuner was engineered with future expansion of functionality in mind. Boasting the most powerful processing power on the market the D-TRONICS Performance Tuner can handle more functions and processes than any of its contemporaries. To that end the Dinan
performance tuner is capable of interfacing with the CAN and FlexRay
communication systems which allow for controlling powertrain functions,
among others. This means that when new functions are developed there
will be no need for a new box, just a short software update at your
local Dinan dealer.
      07-25-2014, 03:08 PM   #2
Sum1.
Addict
Drives: '14 550iX M-sport
Gotta call BS to at least one of those claims. The JB4 (plug in tuner) does not compromise Air/Fuel ratio. In fact, there is zero difference in A/F with and without it.
And it's -75% less expensive.
'14 550iX M-Sport | BMS Tune | M5 Exhaust & Diffuser | 20" 601's | Beltronic STi+ | L.I. Quad | Color Matched Everything...Carbon Black |
      07-25-2014, 03:11 PM   #3
badblack550xi
badblack550xi's Avatar
more Dinan bull shit gimmicks =D still waiting for a dinan car to give me run for my money
2011 550i RWD 60-130 7.35
      07-25-2014, 03:31 PM   #4
613Bimmer
613Bimmer's Avatar
Drives: One car with good steering ;)
I'd personally like to see a comparison done by someone who has/had a JB4 and this tune. Then I'll judge which one is worth the $$$. Can anyone chime in for this (obviously when they make their way into a regular owners car)?
      07-25-2014, 03:42 PM   #5
voyagergab
voyagergab's Avatar
Originally Posted by F10Enthusiast View Post
I'd personally like to see a comparison done by someone who has/had a JB4 and this tune. Then I'll judge which one is worth the $$$. Can anyone chime in for this (obviously when they make their way into regular owners car)?
I'm totally on the same page.
Didn't want to start a flame war, merely letting everyone know that the Dinan option seems finally closer.
      07-27-2014, 03:44 PM   #6
BMW Rolls
Making mods count
BMW Rolls's Avatar
Drives: F02 - E53 - E9 (currently)
New to perf upgrades on BMW
11 535 X-drive
Fair amount of hands on experience with bolt ons and software/ecu upgrades on non BMW vehicles.
I'd like to boost the boost but like the warranty.
Read the email I got from Dinan and saw this thread so figured I'd ask about Dinan alternatives if one wants to keep relationship with local dealer who has been good to me on this and other BMW's.
This is not a huge power jump for $2k IMO. But warranty is key for my new cars.
Sorry for newbie question...
'15 F02 750 Li
'11 F10 535 (sold)
'06 E53 X5 4.8is
'01 E46 330ci (sold)
'72 E9 3.0 CS
      07-28-2014, 09:15 PM   #7
voyagergab
voyagergab's Avatar
Found out that with Dinan you give up the option of an extended warranty.
Hmm....
      07-28-2014, 09:17 PM   #8
BMW Rolls
Making mods count
BMW Rolls's Avatar
Hmm....
Where did that come from? Aftermarket extended warranty offers are different, no?
'15 F02 750 Li
'11 F10 535 (sold)
'06 E53 X5 4.8is
'72 E9 3.0 CS
      07-28-2014, 09:20 PM   #9
voyagergab
voyagergab's Avatar
The dealership sent the following warranty document, that a customer is expected to sign:
I here by acknowledge that by installing Dinan software I’ve read and understand the following warranty details:
Cars Covered by the original vehicle manufacturer's new car limited warranty
If your vehicle is currently covered by the vehicle manufacturer’s new car limited warranty, Dinan products are warranted for the remaining term of the vehicle manufacturer’s new car limited warranty. The manufacturer’s new car warranty is limited to 4 years or 80,000 kilometers in Canada, commencing on the date of first retail sale or the date the vehicle is first placed in-service as a demonstrator or company vehicle, whichever is earlier. Dinan’s warranties are transferable when ownership of the vehicle into which the Dinan products were originally installed is sold.
To obtain service under this warranty, the vehicle must be brought, upon discovery of a malfunction or defect in materials and/or workmanship, to the workshop of any Authorized Dinan Dealer, during normal business hours. Proof of purchase in the form of a lawful invoice is required. The Authorized Dinan Dealer will, without charge for parts or labor, repair or replace the defective Dinan component(s), as well as any original vehicle manufacturer’s component(s) that may have been directly affected by a Dinan component, using new or authorized re manufactured parts. The decision to repair or replace said parts is at the sole discretion of Dinan and/or the original vehicle manufacturer. Parts for which replacements are supplied under this limited warranty become the property of Dinan and/or the original vehicle manufacturer. In all cases, a reasonable period of time must be allowed for warranty repairs to be completed after the vehicle is delivered to the Authorized Dinan Dealer.
Cars no longer covered by the original vehicle manufacturer's new car limited warranty
Dinan Performance Products are warranted for a 2-year, unlimited mileage period from the date of original
purchase. Dinan’s warranties are transferable when ownership of the vehicle into which the Dinan products were originally installed is sold. Further details can be read on www.dinancars.com
Extended Warranty
Extended warranty will not be available for my vehicle after the original vehicle manufacture warranty expires.
Customer Name,
Customer Address,
Customer Signature,
Date,
Vehicle VIN Number,
      07-28-2014, 10:52 PM   #10
BMW Rolls
Making mods count
BMW Rolls's Avatar
Still vague, some extended warranties might still work I would guess, they can't control the free market, if some company decides to provide extended warranties, they might do so, or exclude the engine if upgraded etc. a number of variables not addressed in the Dinan language there. IMO.
Maybe they are referring to the Dinan parts.
'15 F02 750 Li
'11 F10 535 (sold)
'06 E53 X5 4.8is
'72 E9 3.0 CS
      08-17-2014, 01:26 PM   #11
voyagergab
voyagergab's Avatar
Did anyone get this tune yet?
      08-25-2014, 11:16 AM   #12
tree
tree's Avatar
41
Drives: 2016 Alpina B6
I got it last week. Haven't had too much time driving yet, but the car is definitely quicker. I took it for a short run on one of my favorite twisty mountain roads and in sport mode it was a lot of fun! Need to go on a good road trip to give it a good test.
      08-25-2014, 11:17 AM   #13
voyagergab
voyagergab's Avatar
Awesome. Where are you located ?))
      08-25-2014, 11:50 AM   #14
tree
tree's Avatar
41
Denver, CO
      08-25-2014, 12:38 PM   #15
voyagergab
voyagergab's Avatar
Denver, CO
Thanks. How is the power delivery? Curious at what rpm do you get the extra power and if it has any bumps. And how is gas mileage )
      08-25-2014, 05:27 PM   #16
tree
tree's Avatar
41
Can't tell much yet about gas mileage. I've been a little heavy on the pedal since the tune. Also, I do a lot of city driving, and honestly, I'm a guy that doesn't track gas mileage.
As far as power delivery, I think it's somewhat subjective (unless using a dyno). Most of my driving is in Comfort. The car is feels quite a bit faster off the line. When rolling at 30-35mph, with the RPM's about 1100, if I depress the accelerator about an inch, there is a downshift and a slight delay before the car delivers power. There is less delay if I push the pedal harder. I asked my dealer to have a look at it, and they think it's functioning normally and chalk it up to turbo lag, but encouraged me to contact Dinan. I got a hold of someone at Dinan, and we have a time set up in a couple weeks to test it out. They can program the box to go into standby mode which returns the car to stock, and then reprogram back to "tuned" to get a comparison.
I did get a chance last weekend to take the car on a twisty mountain road, and did some driving in "Sport" and "Sport+" and shifting manually with the paddles. The car had way more power than I was willing to tap. Seriously, I don't know how the guys with the 550's handle the beast! Must be better driver's than me!!
All in all, the car feels faster and more powerful. There are no rough shifts, torque delivery is strong at 1500RPM all the way to redline, no warning lights have come on the dash. The hesitation I'm feeling may well have been there before the tune, and I could be just more sensitive to it now. Dinan and my local dealer (Schomp BMW) have been superb in the customer service department.
I'll report back after my next service appt.
      08-25-2014, 06:01 PM   #17
voyagergab
voyagergab's Avatar
Thanks very much for the review! So far there were no 1st-hand reports on the new Dinan tune that I could find.
I also read on the Dinan site that these boxes supposed to be bluetooth enabled so you can switch maps. Any experience with this?
Thanks again!
      08-25-2014, 06:28 PM   #18
tree
tree's Avatar
41
I asked the dealer about the ability to use the bluetooth feature to switch maps. Their response was that there is only one map available, and the bluetooth feature is not meant for consumer use. It's meant to be a one size fits all, plug and play device.
      09-05-2014, 10:32 AM   #19
voyagergab
voyagergab's Avatar
Hi. How is the Dinan working for you after you had it for little while now?
      09-05-2014, 10:58 AM   #20
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Just wanted to clarify this statement now that I saw it. The bluetooth feature AT PRESENT is not meant for consumer use. We are in development on getting an idevice/android app for the end user that will allow you to change maps (although the 535 only has one at the moment anyway), put the box into bypass mode, software/firmware updates without having to take it into a dealer, etc. We are hopeful to have this available by year's end barring any major problems arising.
      09-05-2014, 12:04 PM   #21
top6491
MSGT USMC (Ret)
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
It's going to be hard to get the 535i community to commit $2K+ for a tune on a car they may be getting rid of in a couple of years, like myself. Either need a sale or more testimonials to sway that audience from the much less expensive and popular JB4.
      09-05-2014, 12:56 PM   #22
Dinan_Engineering
Drives: Any BMW
Understood. Unfortunately that is the downside of being late to market on the 535i. We are confident that with additional people adopting the Dinan tune the reviews will reflect the superior drivability Dinan offers. In many markets there has been a push for Dinan demo vehicles so I encourage those that are interested into contacting their local Dinan dealer to see if a vehicle is available so you can feel the difference first hand. If there is not then perhaps just asking the question will spur them into action so one will be available soon thereafter.
