01-06-2015, 09:23 AM | #1 |
Rep 712
Drives: 22' M240i
Meisterschaft Exhaust
So I finally pulled the trigger and ordered Meisterschaft GTC Exhaust for my 550i
*UPDATED* Installed with pics
2022 M240i Thundernight Metallic / Oyster
Previous 2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i Last edited by FeckinSpaceman; 01-20-2015 at 03:00 PM.. |
01-06-2015, 02:24 PM | #2 | |
Joint Chiefs of Staff
24185
Rep 190,777
01-06-2015, 03:03 PM | #3 | |
Rep 712
Drives: 22' M240i
Kind of an after thought to be honest.....but I am willing to sacrifice the diffuser for this exhaust. Just want to know what I am in for so I can notify my installer.
Previous 2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i |
01-06-2015, 03:21 PM | #4 | |
24185
Rep 190,777
Joking aside, i just called GTHaus and they said it does not fit.
01-06-2015, 03:34 PM | #5 | |
Rep 712
Drives: 22' M240i
And helping each other is just what we do! So does that mean I am going to have to saw this thing up? Or will an aftermarket diffuser correct this?
01-06-2015, 03:43 PM | #6 | |
Rep 712
Drives: 22' M240i
Ultimately this was a last minute impulse buy that I got from another vendor on New Years Eve....they gave me an offer that I didn't turn down.
01-06-2015, 04:04 PM | #7 | |
24185
Rep 190,777
You can either cut the current diffuser or get a quad one.
01-06-2015, 07:05 PM | #8 |
Rep 664
The wiring is pretty simple to do.
What I do on BMW's is use the access ports in the trunk floor (small rubber grommet), remove the plug and carry the wiring into the trunk area. Then I use the fuse box in the passenger compartment. Make sure that the fuse you use is for a component that "goes to sleep" otherwise you will create a draw and have a dead battery. |
01-06-2015, 10:28 PM | #10 | |
Rep 712
Drives: 22' M240i
Ok thanks for the tip! Important Nope, gonna send it into the shop but again I want to know what I am getting into and more than likely will have to give some direction to whomever does the install.
01-06-2015, 10:28 PM | #11 |
Rep 712
Drives: 22' M240i
Thanks again btw
01-06-2015, 10:30 PM | #12 | |
Rep 413
Regular non-MSport diffuser custom cut: http://www.vividracing.com/catalog/w...BM101401_5.jpg The valves have electro motors. The installers should connect them to the battery and have custom hard switch in the cabin, or have integrated the upgrade unit called GTC Wireless Remote Control: |
01-07-2015, 10:09 AM | #13 | |
Rep 712
Drives: 22' M240i
So I did buy the GTC Wireless Remote Control, so with that I will not have to hard wire anything correct? Does this change the other install wiring notes that people have mentioned?
01-07-2015, 10:14 AM | #14 | |
Rep 664
The wireless remote feature, all your doing is wiring up the unit to a power source so that the valves open and close by using the remote |
01-07-2015, 02:35 PM | #15 | |
Rep 712
Drives: 22' M240i
Ok, I follow. So I am going to need the power source regardless. Any idea if they provide enough wire or will I need have it?
01-07-2015, 02:37 PM | #16 |
Rep 664
01-07-2015, 02:40 PM | #17 |
Rep 712
Drives: 22' M240i
Perfect, thanks! I can't wait to hear this beast.
I wish I lived in Cali....so many more knowledgeable mod friendly vendors and shops out there.
01-07-2015, 03:15 PM | #18 | |
Rep 413
What diffuser do you actually have? As for the valve control, I saw the connection just once (I have different exhaust without valves). The wires were connected to the wireless unit installed inside of the trunk which was connected to fuse panel i.e. to 12V DС. The guy was sitting on driver's place and pressing the buttons on the remote control, so the valves were moving both ways. You supposed to have the installation and operation manual, otherwise ask GTHAUS or just engage an experienced local partner to do the job for you. |
01-07-2015, 04:14 PM | #19 | |
Rep 712
Drives: 22' M240i
01-07-2015, 07:52 PM | #20 |
Rep 483
I'd be interest to know which shop you pick. I found one or two places in Tampa that seemed trust worthy but never really had them do any work. I actually went to Orlando to get my ACS springs installed. But that was almost two years ago now when most people hadn't touched a F10 before.
01-07-2015, 08:05 PM | #21 | |
Rep 712
Drives: 22' M240i
Ok so good news.....here is the response I got backfrom GT Haus "Hello, Our 4x90mm tips on our BMW F10 550i unit are actually a direct replacement for the OEM rectangle style tip. You will not have any fitment issues. Let us know if we can be of further assistance. Thank you! Best Regards, GTHAUS" So apparently no cutting
01-08-2015, 12:14 AM | #22 |
Rep 413
Expected good news Please share pics when have the exhaust installed!
http://www.bimmerfest.com/forums/sho...d.php?t=661578 |
