2010 2011 BMW 5 Series Forum F10 BMW 5-Series Gran Turismo GT (F07) Forums General 5-Series GT (Gran Turismo) (F07) Forum 21'' Staggered wheels on X-Drive GT?
      03-30-2014, 09:59 PM   #1
535ixgt
Drives: 2011 535iX GT
Hi All,
I was wondering if I could run a staggered set up on my 2011 GT X Drive. The factory set up is squared in all four corners with 245 45 19.
I'm considering a new oem bmw staggered set up with:
275 30 21
245 35 21
Would I have any issues with the x drive system? I ran the calculations and the rolling diameter is nearly equal. Anyone run this set up on the GT xdrive?
      03-31-2014, 05:36 PM   #2
TheBlackGT
Like No Other.
TheBlackGT's Avatar
Drives: BMW F07 LCI
That setup should be okay. Just make sure you get low offsets, since the GT is quite wide.
Here are my offsets (rears are perfect, fronts could use spacers):
Front: 20" x 8.5" ET20 (could use 10mm spacers)
Rear: 20" x 10" ET25 (perfect offsets with no rubbing)
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT
my work: http://www.instagram.com/CorsaAutoDesign
Roxy210.00
      03-31-2014, 07:07 PM   #3
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
As long as your diameters front & rear are equal or very close to, you should be just fine.
      03-31-2014, 09:08 PM   #4
535ixgt
I'm going with the OEM BMW style 312. Apparently these came with differing offsets, so I will have to check which offsets are on the ones that I am buying. I will find out and post to see if it would be acceptable.
I have seen these wheels on a 7 series and they look fantastic!
      04-01-2014, 11:25 PM   #5
blkcofy
blkcofy's Avatar
Drives: 2010 550i GT Sport Dinan
Has anyone seen the V-Spoke 356 Liquid Black Wheels on the M6? These would look wicked on the GT.
http://www.bmw-post.com/2012/09/28/l...at-paris-2012/
550i GT Black Sapphire Metallic w/ Ivory White and Black Nappa Leather, Cold Weather Package, Sport Package, Black Foose Legend Staggered 20s, DVDinMotion software, H&R Lowering Springs, Black Kidney Grill swap, and the Dinan Stage 2 Performance Software: 501 HP @ 5000 RPM / 580 FT-LBS @ 3500 RPM (w/ Cobra iRadar)
