03-05-2017, 11:49 AM | #1 |
Rep 535
Spedo/Tach lights out
The lights behind the circular spedo and tach are out on my 2015 F10 528i. The other display lights with letters and symbols when I turn car on are working. The "dash illumination dial" has no effect. Looked in the fuse box in the trunk and no visible indication of blown fuse (I presume that these solid color fuses would have a discoloration if blown). Any ideas?
03-05-2017, 01:00 PM | #2 |
Rep 291
You'll need to pull the appropriate fuse out and take a closer look.
Look for a small metal piece within the fuse...if it is broken apart then it is blown. |
03-06-2017, 10:09 AM | #3 | |
Rep 4
Drives: 2012 535 Xl
I don't know which panel the offending fuse resides in, but I thought you should be aware. In my experience, It can be very difficult to diagnose a blown fuse without removing and examining it, or using a multi meter. |
03-06-2017, 10:49 AM | #4 |
Rep 535
^^^ No, I was not. When I looked at the trunk fusebox, I found a folded paper with the fuse numbers and sizes, but no identification of which served the dials. Where can I find a diagram that identifies which fuses serve different functions?
03-06-2017, 02:44 PM | #5 | |
Rep 4,047
