2010 2011 BMW 5 Series Forum F10 19 Inch 351 Alloy Tyre Pressure sanity check ? |
03-16-2015, 06:35 PM | #23 |
Rep 619
I feel dirty....I havent checked them in the 18 months I have had it, relying on the TPM
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
03-17-2015, 02:34 AM | #24 |
Rep 1,597
You might want to check them, the TPM doesn't seem to flag up pressure loss until it's pretty low or there's a sudden loss. Mine was 16 PSI when it flagged that the tyre was low. Also my F10 seems to loose pressure a lot more regularly than previous BMW's. I would check previous cars and the pressure would hardly change over very long periods of time, however the F10 seems to loose pressure every time I check. Therefore I'm checking it more regularly, not sure if it's to do with the 20's and ultra low profile tyres...
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
03-17-2015, 03:22 AM | #25 |
Rep 267
TPM comment last summer - had hit a helluva pothole & the TPM sprang into action - no damage but made me realise it wasnt a good substitute for a real check !
http://f10.5post.com/forums/showthread.php?t=1000692
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2 |
03-17-2015, 04:13 AM | #26 |
Rep 1,597
I guess it's primary function is to monitor a sudden loss in pressure, BMW only installed these as standard when they moved to run flats as it is not immediately apparent if you get a flat.
You need to upgrade to the full system which displays tyre pressures in idrive if you want to monitor small fluctuations in tyre pressure |
03-17-2015, 04:42 AM | #27 | |
Rep 15,858
TPM (Tyre Pressure Monitoring) is the direct system with pressure sensors, much easier to keep an eye on current tyre status. HighlandPete |
03-17-2015, 04:09 PM | #28 | |
Rep 1,597
03-24-2015, 05:27 PM | #29 |
Rep 619
I need to sort this...I have 19" 351's, what pressures should I run, mainly me only in the car. Thanks chaps
03-29-2015, 06:02 AM | #31 |
Rep 5,090
Well I've tried 2.3 bar all round and I think I've noticed an improvment in terms of less tramlining. So that's up 0.1 bar on the front wheels .
I'll see how it goes but it feels encouraging so far, can that small change really make a difference? |
03-29-2015, 10:37 AM | #32 | |
Rep 15,858
When I first tested RFT shod BMW models (E60 was the first) I had no idea that the working parameters of the run-flat can be so tight, compared to non run-flat tyres. Wasn't until getting my E91 330d and discovering the problems and how 0.1 - 0.2bar could make a marked difference to how the car drove, did I realise that a lot of my test drives (when I found all sorts of weird characteristics) and got put off models, wheel and suspension combinations, was possibly influenced by the wrong tyre pressures. It is the working pressure which is key to getting it correct, the run-flat typically take longer to warm up, when cold and wet can have a completely different feel than when fully warm. Much more marked than the conventional tyre. HighlandPete |
