2010 2011 BMW 5 Series Forum F10 BMS Stage 1 Check Engine Light (n63) |
10-17-2015, 02:36 PM | #45 |
Rep 736
Actually I think it could be the work the exhaust shop did to my downpipes. They made some custom high flow cats.
10-17-2015, 06:06 PM | #46 | |
ZEROdoubleZERO
228
Rep 659
Just sayin..... Last edited by Teddylongtooth; 10-17-2015 at 06:08 PM.. Reason: Im regarded and can't splle |
10-17-2015, 07:05 PM | #47 | ||
Rep 736
Im 90% sure it's a leak dealing with the downpipe work I had done. After the downpipe work, the car would pull harder but shifting from 2nd to 3rd I could feel a harsh hiccup in the upshift. Never felt it before having the downpipe work done. I'm going to have the shop check it out for me. |
10-18-2015, 10:25 AM | #48 |
Rep 844
http://www.bavariantechnic.com/
If your car has issues and youre just brushing it off or pointing fingers at mods, eventually youre going to have an expensive garage weight holding the house down. Spend the money and get a scanner of sort because you know even if its the exhaust guys fault, hes not going to pay, and youre going to be stuck without a car.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
10-18-2015, 03:12 PM | #49 | |
Rep 736
10-19-2015, 07:57 AM | #50 |
Rep 730
hEY GUys i got the drivertrain malfunction , as well while aceelerating around 80mph , and my 550 started shaking, so then i turnd the car off and on again the light went off , and it was fine, wth is going on ,
10-19-2015, 11:16 AM | #51 |
Joint Chiefs of Staff
24174
Rep 190,750
You need to pull the codes
10-19-2015, 11:26 AM | #52 |
Rep 2,416
10-19-2015, 03:58 PM | #53 | |
Rep 736
10-19-2015, 10:52 PM | #54 | |
ZEROdoubleZERO
228
Rep 659
http://www.bimmerfest.com/forums/att...8&d=1363908210 |
10-20-2015, 12:24 AM | #55 | ||
Rep 736
Can someone explain this to me in laymans terms. |
10-20-2015, 01:33 PM | #56 |
Rep 844
Every car is different. Too much boost with not enough octane will cause detonation... Knock sensors may pull timing, but if they don't, the next issue is typically cracked pistons/rings, spark plugs destroyed, or if you're super lucky, head gaskets, cracked block etc. Thankfully the BMW knock system is quite sensitive, but its not fool proof.
10-20-2015, 01:46 PM | #57 | |
Rep 736
P1288: Switching solenoid for air assisted injection valves bank 2 control circuit signal low. |
10-21-2015, 12:17 AM | #58 |
Rep 736
Checked the settings on the bms . Boost over stock was set to 2.75 (set it back to 2.25) and future use was set to 1 (set it to 0)
Car still jerks hard under heavy throttle and check engine remains. T min and t max was not set at 1 and all the other settings were different values as well. (T map slew, maf offset, PID) . Are the values all supposed to be set the same or just the values in the red box (as shown in installation guide below). |
10-21-2015, 02:52 PM | #60 |
Rep 844
Unfortunately im not familiar with the BMS products, and even with adjusting my car to +4.5 lbs on E85 with the E-tronic, ive never had any issues, lights or limp mode. Best bet would be call Terry or someone more knowledgable on the BMS products and see if the Stage II modifies any factory variables that may affect that specific sensor or cause that fault code... if he says no, then theres a chance its an unrelated failure, or a failure that was caused by another component. I dont have access to the BMW procedure charts for fault codes so I couldnt even tell you what sensors are affected.
10-21-2015, 06:48 PM | #62 | ||
Rep 736
All the other settings on my interface, (t min/max, tmap slew, PWM Cap/Min and PIDs) aren't set to the shown values that are in the guide. But these values don't have a red box around them like with boost over stock and future use so I don't know if they need to be the adjusted to match the guides values (see image below). Check engine light gone, car drives good again, but doesn't feel as fast as I when I first installed the chip (it was running +2.75). Does +2.25 make that drastic difference in reduction of power from +2.75? |
10-21-2015, 07:07 PM | #63 | |
Rep 844
Short answer here is a half lb of boost is about 6-7 horsepower, it shouldnt make a world of difference. The thing you cannot overcome is the engines decision to override your input in order to save itself, which is why you should datalog what its doing and see if its pulling timing, if its lean, or if theres a problem that you cant see just by reading codes.
10-22-2015, 12:45 PM | #64 | ||
Rep 736
Took the car for a drive this morning and I drove it around in D , comfort mode instead of the usual DS and power gain feels much more noticeable. I guess the chip takes a little while to adapt. |
10-22-2015, 01:59 PM | #65 | |
Rep 41
I thought the new default psi on stage1 is 3.0? |
10-22-2015, 04:19 PM | #66 |
Rep 736
