2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications EVC Meisterschaft's...do i need the rest of the exhaust?
      06-12-2017, 07:56 AM   #1
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Hey guys! so i'm in the middle of getting things ready here. i'll be ordering the Wireless EVC wiring kit from QTP here shortly. I can't believe GTHaus almost wants $100 more dollars for the kit vs getting it directly from QTP?! QTP basically said you're paying $100 for the Meisterschaft logo on the remotes lol! anyways, i was just gonna have the mufflers slapped on but started thinking if i should order the rest of the pipes that go all they way up to the DP's. car is bone stock right now and maybe down the road i'll finally get around to getting a tune, DP and CP. but that's a big "IF"? Is there really any benefits to getting the rest of the pipes or should i leave as is? really appreciate all the input out there from you guys...Bmw doubles, Stuck, ect...
      06-12-2017, 08:15 AM   #2
kstorm93
Drives: 2013 535i
go all out! that exhaust is awesome!
      06-12-2017, 09:07 AM   #3
lsturbointeg
yeah! i'm stoked!
      06-12-2017, 10:23 AM   #4
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I'd say if you can; go all out.
Also what is the Wireless EVC wiring kit for exactly?
      06-12-2017, 12:07 PM   #5
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
What is the diameter of the piping on the full Meisterschaft system? Our stock piping is 2.25", so if the full system is 2.5" or larger, it will play a small difference in outflow on the exhaust. Since you're not pushing any additional boost (read: not tuned) then I wouldn't worry as much. IMO, pay an exhaust shop to go 2.5" all the way back, tune it, and reap the gainz and sound.
      06-12-2017, 12:49 PM   #6
lsturbointeg
it allows you to open and close the valves on the exhaust itself. with the wireless kit i don't have to run a wire to the front and drill a hole somewhere for the switch. instead, the wireless remotes will open/close the valves at any time. the wire only needs to be hooked from the acuator to the battery which happens to be in the trunk
here's the actuator that opens and closes the flap:
valve closed:
here it is installed on one side of the exhaust which will open/close that side:
      06-12-2017, 12:52 PM   #7
lsturbointeg
2.5 for our 535's but the piping diameter on the Meisterschaft's is 2.75 since it came off a 550i. i'll need to have the muffler shop use a transducer for the connection. it's been done 1kx so no problem there. i'll look into the shop and see what they'll charge to go 2.5" all they way back cause i know the crush bends kill any performance
      06-12-2017, 01:00 PM   #8
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
The stock tubing is plenty up to the task of handling extraction for the amount of power we're making. Just do the axle backs as you have planned.
      06-12-2017, 01:03 PM   #9
lsturbointeg
ok cool!
here's the Meisterschaft piping. i don't think just a muffler shop can do work like this tho?
front pipe:
mid pipe:
      06-12-2017, 07:41 PM   #10
Stück
Stück's Avatar
That is mandrel bent stainless steel, artfully TIG welded to perfection and priced accordingly.
Most muffler shops use crush bent aluminized steel and hopefully have someone reasonably proficient with a MIG.
The two are worlds apart.
      06-12-2017, 07:50 PM   #11
lsturbointeg
Yup! They are bada$$ looking! Wondering if its worth it as far as gains are concerned? I emailed GTHAUS so hopefully I'll find out how much?
      06-12-2017, 10:00 PM   #12
Stück
Stück's Avatar
I can't imagine there being any performance gains over factory exhaust unless you're already maxed out and full bolt on with an upgrade turbo.
Your car is essentially stock no?
      06-12-2017, 11:15 PM   #13
lsturbointeg
Eventually I'll get some kind of tune...JB4, Race Chip, Dinan? And than probably DP, CP and so on.
      06-13-2017, 01:41 AM   #14
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Your stock engine or with all the mods you can throw at it won't need the pipes, and no matter how good they look nobody will ever see them except the grease monkey doing your oil change
      06-13-2017, 07:00 AM   #15
lsturbointeg
haha right!
so *uck me here's the email i got from GTHaus!
Hello Gene,
Sure thing, we can sell you the front pipe portion of the exhaust systems (Front pipe + Mid Y pipe section),
We have them in stock, ready to ship and The pricing would be $1898.00 + $149 shipping.
Let us know if you have any questions / would like to proceed with this unit order, thank you !!
Regards,
Product Sales Division
351 Country Club Dr. Bensenville IL. 60106
Tel : 630.787.1600 ext 8617 Fax : 630.787.1603
      06-13-2017, 09:40 AM   #16
Teddylongtooth
ZEROdoubleZERO
228
Originally Posted by lsturbointeg View Post
haha right!
Hello Gene,
Regards,
Ya and then there is that!!!^^^^^^^^^^^^
You can get polished stainless steel exhaust pipe and have a exhaust shop/fab shop make that section for way less money, but why? Unless you're planning on 400+ horsepower its not necessary. It just doesn't seem worth it for something no one is going to see. It may have a better sound, but I would install the axle back as is and hear how it sounds first then decide if its needs more work, money and aggervation of tracking down the right guy for the job.
      06-13-2017, 10:07 AM   #17
lsturbointeg
that's pretty much what i'm going to do. i figured i'd inquire just to see how much those pipes were gonna be but no way i'll spend that much for pipes when the gains are minimal and that i'm really not going all out or tracking/racing the car anyways. money can be used else where
      06-17-2017, 12:28 PM   #18
exia_m3
exia_m3's Avatar
181
Drives: 2017 F80 ZCP MW/SO
2013 BMW E92 M3  [0.00]
2017 F80 M3  [0.00]
I thought you installed them when you refinished the tips
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs
@drivingwithbenny
      06-17-2017, 08:54 PM   #19
lsturbointeg
Lol i was suppose to but my projects got put at the bottom of the to-do list
