2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 2015 520 m-sport want to add sport+
      05-31-2020, 04:15 AM   #1
kennytheone
England
Drives: bmw 520 m/sport
hi all i have a 2015 m-sport it has the sport comfort and eco but wanted to know if i can and how i can add sport+ mode to my car i have a vgate icar pro but i dont see the sport+ in the bimmer app is it only in the the expert mode any help would be great thankyou in advance
      06-05-2020, 08:33 AM   #2
bfleming
Drives: Merc, VW, Porsche, Suzuki
Sport+ is an Auto-only option, so... is your car an auto? If it is, you should have option 205 or 2TE (use mdecoder and the last 7 digits of your VIN to find your options). To add sport+ you'll need to replace 205 or 2TE with 2TB using eSys.
Happy to help if I can!
Audi A4 Quattro 2.0TDI 177 2012/12
VW Golf GTE Advance 2017/67
Porsche Boxster 986 2.7 2000/X
Suzuki GSXR 750 2004/04
      06-06-2020, 10:40 PM   #3
kennytheone
England
thankyou
thankyou for reply i do have an auto the 2Te i have the paddles etc was hoping it was a bimmer code job is there a step by step for the eSys way of doing it
      06-08-2020, 04:16 AM   #4
bfleming
I'm happy to do it for you if you fancy a trip to Hertfordshire (M1 J10)?!
If you already have eSys, there are a number of online guides for coding. This is a good place to start: https://f10.5post.com/forums/showthread.php?t=1079869
      06-10-2020, 02:33 PM   #5
kennytheone
England
thankyou
well i have tried doing it with the bimmercode i get the sports+ i can see on dash when i press the rocker switch but i also get this message up constantly under speedo (Driving stabilisation drive moderately). but might take you up on your offer when you around and thankyou for your help. i have got the ESys on lap top and the lead just don't fancy messing car up
      06-11-2020, 05:51 AM   #6
bfleming
I think that Sport+ message is normal (I'll check mine later on); basically in Sport+ the driver aids are disabled to a degree, and the message is there to tell you just that.
      06-11-2020, 10:07 AM   #7
kennytheone
England
pic of message
https://f10.5post.com/forums/attachm...1&d=1591887857
      06-11-2020, 02:55 PM   #8
bfleming
On mine, this is what it looks like in Sport:
Then I select Sport+:
The Mode table disappears first, followed a couple of seconds later by the "Dynamic Traction Control activated" message, leaving me with:
As I'm not sure which modules you coded, can you confirm it was EGS, ICM, and KOMBI?
      06-11-2020, 08:25 PM   #9
wcr3d
Drives: 2013 535i XDrive M Sport
Sorry if I am butting in, but you two have different clusters.
Notice the difference in gauge rings and the space between the two mains?
Otherwise it looks like he has the job done.
FYI, his is a newer one and called a “6WA”, yours is older, I don’t know it’s referenced number.
      06-12-2020, 03:07 AM   #10
kennytheone
England
EGS/3000 Applikation -> LC -> aktiv
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
ICM/3000 ICMKOD_B_SPORTLENKUNG nicht_aktiv ===> aktiv
KOMBI/3000 FDS_MENUE_TEXT_1/2/3/4 menue_4 ===> menue_3
KOMBI/3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_4 ===> menue_3
the above i changed on bimmercode app
      06-12-2020, 03:10 AM   #11
kennytheone
England
your not butting in all help truly welcome
      06-12-2020, 07:37 AM   #12
bfleming
Yes, I have the basic cluster, he has 6WA, but that has nothing to do with the issue.
      06-12-2020, 07:45 AM   #13
bfleming
I think you're missing 2 lines...
ICM/IcmKod_B_S2TBA -> verbaut (you're telling the ICM module you have 2TB now)
ICM/IcmKod_B_S2TEA -> nicht_verbaut (effectively disabling the old 2TE option)
Hope this helps.
      06-12-2020, 12:54 PM   #14
kennytheone
England
i have this option to change ICM/IcmKod_B_S2TBA -> verbaut (you're telling the ICM module you have 2TB now)
but i dont have this option ICM/IcmKod_B_S2TEA -> nicht_verbaut (effectively disabling the old 2TE option) to change in the bimmercode app
guess it needs the eSys doing to sort that from 2Te to 2Tb
      06-15-2020, 06:44 AM   #15
bfleming
How about ICM/IcmKod_B_S205A -> nicht_verbaut
      06-15-2020, 12:41 PM   #16
kennytheone
England
yes tried that to still the same
      08-17-2020, 03:53 PM   #17
bfleming
I did one of these tonight; the owner had retrofitted the mode selection switch, so I coded 2TB (to replace his 205), and in SZL set paddles to active. Worked a charm. Let me know if I can help you out.
      09-07-2020, 10:16 AM   #18
jmmdm2
Drives: 2015 528i xdrive M-Sport
2019 BMW M550i  [0.00]
I contacted BimmerCode about adding Sport+ to my 2015 528i. They returned my inquiry... that function is not supported in the 5 series through BimmerCode though I might be able to code it in expert mode. I didn’t even bother to question why they’d exclude the five serious. Ridiculous in my opinion. I did ask for a guide to perform the coding in expert mode, no reply yet. I’ve been studying every thread I can find relative to adding sport+ the 528 or similar 5 series. I’ve yet to find a cheat sheet for the F10 which isn’t derived from the F30. The code is similar in the F10 but it’s not an exact match. A search within expert mode shows where 205 and 2TB exist. I’ll modify these lines of code after I’m sure it’s the correct location... IcmKod_B_S205A is one of the lines I’m looking at.
      02-03-2021, 02:44 PM   #19
consamo
Ireland
Drives: BMW 520M LCI 2014
Hi.
May be is too late but just today i found the right configuration for sport+ activation
ICM/3000 ICMKOD_B_SPORTLENKUNG in nicht_aktiv
Thank you!
      03-28-2022, 03:35 PM   #20
BMWMDS
Drives: Bmw f10
l'll try,the good post
