2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Headlight condensation
      01-12-2022, 03:42 AM   #1
e92liv
e92liv's Avatar
44
Drives: F10
Anyone else's headlamps full of condensation? I'm worried the water will get to the control board that's at the bottom of the unit and fry the board
      01-17-2022, 07:09 AM   #2
Biffa773
Drives: F10 528i Nov 2012
Have a 2012 SE here and have never seen condensation in the headlights in the time I have had it (from new).
      01-17-2022, 08:16 AM   #3
e92liv
e92liv's Avatar
44
Drives: F10
Ordered a replacement headlamp, tried to dry this one out with a hairdryer but it's too wet :
      01-18-2022, 01:40 PM   #4
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Same. I just changed the trap door and used some silicone seal around the round hole near the wheel well.
      01-21-2022, 12:27 PM   #5
robbiep
Drives: VW e-Golf !
All that is going to do is cause water to be retained in an area where it will then cause some other problem.
Yes, it'll stop water spraying up, but it'll also stop water flowing down. Unless you've got obvious signs of water ingress, and they are causing problems, it's a non-solution
      01-21-2022, 03:01 PM   #6
e92liv
e92liv's Avatar
44
Drives: F10
I managed to get a new Hella replacement from Amazon for £465 (for info the forum bmw dealer quoted £750)
You have to use some of your existing bits like the xenon bulb, led drivers, etc.
Took me a couple of hours
      01-21-2022, 03:51 PM   #7
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Too bad the bumper has to come off…If not I would have already replaced mine
      01-21-2022, 04:39 PM   #8
Sylverlee
Hopefully not. Will update you on that. But luckily our here in CA might be done with the rain season.
      03-07-2022, 09:39 AM   #9
diablorino
Drives: F11 530d
I saw this post and registered here, hoping my experience will help someone.
Sadly I didn't take any pics while fixing it.
My issue was that my right headlamp got full of condensation after driving in the rain, or washing the car. It has to be fixed soon, because otherwise the electronics inside will fail and that's another expense.
The issue is in the headlamp's design itself. If the upper seal isn't perfect, water will drip in because the joint where the clear plastic lens and the headlamp body meet is turned towards the front of the car and angled in a way that enables water to come in.
I managed to seal the upper part of the headlight with neutral clear silicone caulk, without removing the front bumper. It's advisable to do this somewhere warm, if it's too cold the plastic becomes even more brittle and it's much easier to break something.
Had to remove all the plastic clips and covers in order to gain access to the top of the headlight. Along with the two torx screws on top of the bumper, this enabled me to move the bumper enough to remove another plastic clip (or maybe rubber seal, I don't fully remember). The black metal clip on top of the headlight also has to be removed.
After I gained full access to the upper portion of the headlamp, I thoroughly cleaned the plastic around the seal, wiped it dry with a microfiber cloth and gave it some time to fully dry. Then I carefully applied silicone along the upper seal. I wasn't too stingy with it, I really didn't want to be doing it again.
Then I let the silicone dry for half an hour and reassembled everything back together.
To let the interior of the headlight fully dry, I removed the service access "door" while the car was parked. It fully dried in about two days of cold weather. I also used some silicone spray to lubricate those mechanisms in there.
It's been a while now and the condensation hasn't come back either during rain, or pressure washing the car.
Here's a pic of the fix I just took, you can see a bit of the clear silicone caulk.
      03-07-2022, 10:27 AM   #10
OnlyGerman
OnlyGerman's Avatar
I just had mine repaired for this issue. The bumper does NOT need to be removed, it can be done in place!
      03-07-2022, 10:28 AM   #11
OnlyGerman
OnlyGerman's Avatar
Not going to work, whole headlight needs to be addressed. Remove and get repaired.
      03-08-2022, 06:01 PM   #12
diablorino
Drives: F11 530d
Argue your case my friend, because it is working.
      03-28-2022, 03:30 PM   #13
BMWMDS
Drives: Bmw f10
Have a 2014 SE and never seen condensation
