2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
05-02-2018, 11:30 AM | #287 |
Rep 6
Thanks Shawn.
I plan to flash my NBT HU since the bluotooth support are not so good, is it best to flash to the lastest version or are there limitations in this that make the internet by bluetooth tethering not work ? |
05-02-2018, 11:32 AM | #288 |
Rep 40,793
Drives: 2018 Alpina B6 650ix GC
I am not aware of any limitation.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
05-03-2018, 01:39 PM | #289 |
Rep 6
Ok good, Thanks Shawn !
I started the flash process but during TAl calculation I got a varning -3 Tal lines have been set to "NotExecutable" during TAL calculation [C384] And after this a new pop up massage -1 WARN events during TAL generation [C383] Any idea what the problem is ? |
05-03-2018, 02:09 PM | #290 | |
Rep 40,793
05-03-2018, 03:09 PM | #292 |
Rep 40,793
Yes, start it.
05-04-2018, 02:57 PM | #293 |
Rep 1
Hi Shawn,
Got 2014 F10 530d and looking to get some things enabled. Ordered cable on Amazon and now looking for latest software and guides. Also, is there any difference if it's UK car? Thanks in advance. |
05-04-2018, 03:08 PM | #294 |
Rep 40,793
No difference. PM sent.
06-10-2018, 01:18 AM | #295 |
Rep 2
Hello, I'm new here too. Could I also get a copy of the cheatsheet for an F10 please. I have the cable and some software but not sure if its the correct.
Any help would be appreciated. Thank you |
06-10-2018, 08:17 AM | #296 |
Rep 40,793
PM sent.
06-18-2018, 02:41 AM | #298 |
Rep 4
Hi there!
I have 520d Bimmer 2012 F11. madeup ENET cable, installed INSTA-D INSTA-P and E-sys plus have a 10A charger. Have a few problems: Need to determine accu state (afraid of 30% life, it`s didn`t change from the very beginning) Also need to check AGR state About coding: Tell me where to look - I changed the bumper to M5 (without fogs) - respectively, they must be turned off, a permanent error. Prompt where to find. The rear camera is also of interest in motion; lowering the limiting speed of the dead zones (up to 25 km) see \ change the time the headlight washer is switched on check the ability to assign a button (that belongs to front fogs) to another function activate the Internet and all related functions (CIC native, wide monitor, not NBT ) Will be very thankfull for any help |
06-19-2018, 01:20 AM | #299 |
Rep 4
Hello!))
Updating.... I found some features, and want to share About rear camera in motion: PDC 3009 D_SCHWELLE_2 FF 0A max distance in meters to disable rear camera view - Change to Werte = FF PDC 3009 V_SCHWELLE_2 FF 0F max speed to disable rear camera view - Change to Werte = FF test it - have only one bug - if do all this - rear camera didn`t switch off by itself when you put reverse, and then forward. I`ll do it manually, button)) Dead lane \dead spot system ICM 3000 Daten, F8 Hc2_i_CPar_Aktiv_v_low 30 50 Works. But I did 30km/h, when it was 25 - have errors, so I don`t recommend to do it lower than that =================== All other things are still in search... Looking for help...Anyone? |
06-19-2018, 06:22 AM | #300 |
Rep 8,364
07-11-2018, 02:10 AM | #301 |
Rep 659
Hi all
have been coding my F06 with success, however for the life of me i cannot get the indicators in the HUD KOMBI => 3008 => HUD_PIA_BLINKER => aktiv KOMBI => 3000 => BLINKER_HUD_ENABLE => aktiv HU_NBT => 3001 => HUD_TURNSIGNAL => aktiv is whats noted in the cheat sheet however i noticed min is held under DKOMBI xxxxxxxxxxxxxxxx
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5, Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff Last edited by MARKPRIOR; 07-11-2018 at 02:20 AM.. |
07-11-2018, 03:09 AM | #303 |
Rep 659
yeah thats the one, i also have the digital cluster which after some reading may be the issue ?
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5, Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff |
07-11-2018, 03:24 AM | #304 |
Rep 8,364
07-11-2018, 03:35 AM | #305 |
Rep 659
07-12-2018, 07:51 AM | #306 |
Rep 659
next coding question
Reverse also illuminates door LEDs, couldnt find this for the F10 code list, (im actually coding my F06) just using the f10 sheet
07-12-2018, 01:12 PM | #307 |
Rep 40,793
Not possible in F1x (FRM based) car.
