2010 2011 BMW 5 Series Forum F10 F10 HiFi Upgrade - A DIY Journey |
07-15-2014, 01:18 PM | #1 |
Rep 54
Like most of you, I found the standard HiFi system equipped F10 sound quality to be inadequate at best (lacking clarity and soul). However at this time, I’m not willing or have enough justifications to spend a lot of hard earned cash to upgrade the sound system on an already expensive vehicle. One would think or expect a $50K plus vehicle comes with some decent audio setup (I don’t mean BOSE). If you have not seemed the OEM speakers, you will surely be very disappointed on the quality of the speakers upon discovery (look at the size of the speaker magnet, they don’t even make good refrigerator magnet).
OEM Door and rear deck speakers There are a lot of decent aftermarket speaker out there (Focal, MB, Gladen, BSW, Eton, and etc.), however they are a bit pricey and not all are available in the US. Frankly, you are not going to maximize the sound quality by just upgrading the speakers. We all know that the weakness link in the system is the OEM amp (rated at 2 ohm) and there is no point in replacing the 8” woofers without an amp upgrade. However that does not mean we cannot achieve high quality sound without breaking the bank. The goals for my design are as follows: o Replacement speakers must be at least as efficient as OEM, (no loss of SPL from OEM amp), o Tweeter and mid play nice together to eliminate resister padding, o Low crossover component count to minimize cost and ease of installation, (first order preferred), o No modifications or cutting of door panel or rear parcel shelf, (everything must fit as OEM), and o All harnesses used will be plug and play (PNP) to avoid cutting factory harness and to be reversible if ever needed to go back to OEM. The hardest part of the design is to find the tweeter and mid combination that meet the design goals. There are a few highly regarded 4” (100 cm) mid that have very nice specifications but the efficiency is just not high enough or the depth is too tall to fit the bill. For the door application, the speaker mounting depth must be less than 50 mm, not good but better than F30 which is 20 mm less. Through many hours of research, I found a 4” (100 cm) mid made in Italy that has high efficiency (90 dB) and less than 50 mm in depth. It uses the more expensive neodymium magnet instead of ferrite. Focal uses the same type of magnet in its speaker for BMW application. The cost for the mid is reasonable given the neodymium magnet used. The cone is not made out of exotic materials, but with decent treated paper with rubber surround and stamped steel basket. The OEM rear speaker is also a 4” mid but the mounting point is smaller than the door speaker; therefore you can’t use the same mid in the door for the rear deck unless you want to hack up the rear parcel shelf which I’m not willing to do. Lucky, the same Italian manufacturer makes the exact speaker in a 3” variety. This is no sonic difference going from a 4” to a 3” mid. Since there is no depth constraint for the rear deck, I use the ferrite version as a cost saving. The OEM tweeter is a 1” textile dome and is wired parallel with the mid. All of the 1” aftermarket tweeters have a slightly larger overall diameter and will require some physical hacking to the sail pane and rear mount in order to fit in the OEM locations. So for the tweeter, I went with a ¾” soft dome instead of the normal 1”. Again there is no sonic difference between a ¾” and 1” tweeter, may even have better dispersion due to smaller dome. For the sail pane, simply pop out the OEM tweeter and hot glue the new tweeter in place. New Tweeter Hot Glued in Sail Pane Any visible gaps will be covered up by foam backing. For the rear deck mount, you will need to remove the existing hot glue used to hold the OEM tweeter and re hot glue the new tweeter in place. OEM Removed from Tweeter Mount New Tweeter Hot Glued in Rear Decker Tweeter Mount For the crossover design, I maintained the same topography as OEM, mid at full range and first order for the tweeter. This was done to reduce overall cost/complexity and simplify the installation. I used metallized film capacitor instead of the electrolytic, no reason here to save a penny or two for the capacitor. After many hours of listening and adjustment cap value, I settled on a crossover point that let the tweeter blends with the mid. HiFi equipped F10 also comes with a center mid and tweeter just like the one used in the rear deck, I just simply remove them since I didn’t found it necessary to have a center channel for sound/stereo imaging effect. I made my own PNP wiring harness and CNC plastic speaker adaptors for the door and rear deck. Plug and Play Wiring Harnesses The result is best described as fanatics; even other family members noticed the difference right away. The clarity on the vocals and individual instruments come through unlike the muffled sounds from the OEM speakers; you can hear the subtle details in the vocals and each string instrument in particular. The mid bass is much tighter than OEM, but don’t expect very low since the OEM woofers are still handling that range of frequency. The results definitely justify the minor investment (price to performance ratio vs. other aftermarket offering). I can live with this new setup for a long time without feeling the need to upgrade the OEM woofers and amp. Be warned, crappy recording will sound even crappier in the new setup than in the OEM. Please PM me if you are interested in upgrading your F10 setup, I can put together a package for you, front only or front plus rear (speakers, adaptors, and wiring harnesses as shown). New Mid Installed (front door) New Mid Installed (rear deck) New tweeter and mid (front door) New tweeter and mid (rear deck) |
07-18-2014, 12:48 PM | #3 |
V.I.P.
40
Rep 250
Drives: F10 535i 2011, F10 550i 2015
Cool DIY, do the speakers look any different once put into place? How is the sound difference, (% wise?) am pretty interested in upgrading.
PM a price for front, and for front and rear. Thanks.
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1 F10 535i Alpine White/Oyster BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC |
07-23-2014, 11:26 PM | #4 |
Rep 54
IMHO its 100% better than OEM HiFi, of course I’m a little biased. I have forgotten the awful OEM sounds and would never go back. If anyone in the OC area and would like to do a comparison with their OEM, HK or other PNP OEM amp systems, I’m open to a local meet and listening evaluation. I interested in getting honest feedback from other forum members since sound quality is very subjective.
09-19-2014, 01:23 PM | #5 |
Rep 54
By your description, it sounds like you're using the FaitalPRO 4FE32 speakers for the front doors, and the 3FE25 speakers in the rear deck. Is that correct? If so, nice find, as those are a very inexpensive upgrade, only costing $37 per 4" neodymium midrange, and $19 per 3" ferrite mid.
Which tweeters did you go with? |
09-19-2014, 02:08 PM | #6 |
Rep 54
Yes, you are corrected. The FaitalPro are not the best looking speaker out there, but you can't see them behind OEM grills, completely stealth installation. They sure sounds very nice with emphasis on vocal range. I'm using the Dayton 3/4 silk dome tweeter to argument the very upper frequency and to keep the impedance to 2 ohm as OEM.
12-11-2014, 05:40 PM | #7 | |
Rep 767
12-11-2014, 07:43 PM | #9 | |
Rep 767
01-09-2018, 01:19 PM | #11 |
Rep 294
Where can we buy the center dash speaker mid adaptor and the door mid speaker adaptors?
what about the wiring with builtin capacitor for tweeter? what else is needed?
2019 F90 M5 Competition - Marina bay Blue Pearl - Executive and Bowers & Wilkins package
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
01-13-2019, 05:46 AM | #13 |
Rep 1
Is there any way to improve sound of quality of the car? Hifi is terrible for me. Unfortunately my budget is limited and I can not afford for expensive speakers. What do you suggest guys? :/
BimmerOwner45.50 |
03-13-2019, 08:58 PM | #17 |
Rep 116
"If you replace the amp that goes with the Hifi-system, can you use the power-wire from the original amp? Or do you need to run a new one with heavier fuse?"
The Match UP 7BMW comes with the harness... No power wire needs added. The amp seems like its twice as heavy as the stock 205w amp though they are similar in size. The Match UP 7BMW has the same basic hardware as the Revenant Amp that Bavsound just introduced. I just purchased and installed the Revenant Amp, but it is too early to give any thoughts other than I don't like their preset calibration - sounds way too bright. The amp has several DSP technologies, some of which are poorly setup at this time, IMHO. I have confidence in the hardware, and I think I can get the calibration improved by eliminating some of the DSP enhancements and changing the EQ to solve the treble. The amp seems to have PLENTY of power. Last edited by SC300T; 03-13-2019 at 09:03 PM.. Reason: quote |
03-14-2019, 01:32 PM | #18 |
Rep 965
When we're referring to hifi this is the HK (though not labeled) option right? Can tell by having the triangle tweeters in the door? Thought you couldn't replace that amp.
03-15-2019, 12:18 AM | #19 | |
Rep 4
03-16-2019, 05:50 AM | #20 |
Rep 500
Upgraded HK speakers with Faital Pro 4FE32 and Eminence SD28
Just done the upgrade from stock BMW HK speakers to Faital Pro 4FE32 and Eminence SD28 tweeter. I'm using 2nd order crossover around 3khz. My initial assessment is for lower volume, I can't hear much difference compare to stock speakers. But once I turn the volume up more than 50%, I can hear the new setup sounds more compose and willing to go louder without distortion. Normally for stock speakers once I hit 75%, will sound harsh.
Note that if you want to use 4FE32 for center channel and rear channel, you need to cut both lower mounting arm. Last edited by pierreye; 03-16-2019 at 05:56 AM.. |
03-21-2019, 12:41 PM | #21 |
Rep 116
"Hi, I also have a Revenant Amp as well. And I installed it on my 2013 F10 with the Bavsound tune file for OEM hifi speakers. I found that with this tune file, my center channel actually has no output or at least it has been tuned quite low. Is it the same with your center channel?"
I'm returning mine largely because it has zero adjustability. The sound is far too bright. It does have lots of power and clarity, though. As far as the center channel, mine has some output, but not terribly noticeable. The electronics do a good job of summing center channel signals and blending it with the left and right. I think the soundstaging / imaging is very good. I'll just get the 7UP BMW version so that I can tune it. The other thing that I don't like is that it has a variable high pass filter on the sub channels that is designed to limit excursion of low bass at high levels. You can definitely hear the drop off in the low bass at high levels. I'm sure this is on purpose to prevent overdriving the stock subs. |
03-21-2019, 05:56 PM | #22 |
Rep 500
You can disable the sub channels protection for high levels.I would only do that if swaping out the stock underseat sub. As for the sound too bright, try to slope down 5 khz and above to 20 khz with 3db. Check out Harman target curve or JBL curve. I also found out that stock speakers do sound harsh and too bright at high volume. You might want to try out silk tweeter.
