2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 535i Low RPM clicking noise
      05-12-2015, 08:12 PM   #1
al2fast
Drives: 2011 535i
Hello, searched the forum and the internet and cannot seem to find a match for this sound. Sounds like it's coming from the alternator/oil filter area. Only happens at low rpms, like coming off of idle. Giving it light throttle makes the sound more apparent, but if you stab the throttle you can hear it for a split second.
Now that the weather is nice and the windows are down it does it every time you take off. Now its got 106k and no warranty, a 2011. Does not make the noise at higher RPM's and doesn't seem to modulate with engine RPM. As you can see it happens at idle so it's not some suspension component or brakes. I could swear it is something loose that is rattling, but I haven't done much other than change the oil, filters, brakes, & plugs on this car. None of those were done recently.
Here is a quick video I took where you can hear the noise, almost sounds like you are welding:
Thanks for any input you have. I could swear it was coming from in front of the oil filter and not the alternator when I went to that side of the engine. However, in front of the oil filter there is that heat exchanger thing and I found a diagram online and doesn't appear there are any moving parts in there.
Joe
      05-12-2015, 08:39 PM   #2
combatbmw
Drives: 20' X3M CP
Damn that doesn't sound to good. Hope someone can help you find the answer.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
      05-12-2015, 09:00 PM   #3
badblack550xi
badblack550xi's Avatar
probably the alternator
2011 550i RWD 60-130 7.35
      05-12-2015, 09:19 PM   #4
al2fast
Drives: 2011 535i
Thanks, I sure hope so, definitely sounds like its coming from the top front corner by the alternator, just cannot pinpoint it.
However those suckers are not cheap. $600+ for a remanufactured one at ECS!
      05-18-2015, 01:10 PM   #5
al2fast
Drives: 2011 535i
I couldn't figure it out, took it in to the local shop and its just the tensioner pulley, WHEW! Having them throw on a new belt too while its apart, so with a new belt it will be a sub $300 total repair bill which is a pleasant surprise!
      05-18-2015, 03:13 PM   #6
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Wait...So no more noise after replacing the belt? Sweet! To me it sounded like the alternator was going out? Thankfully it was something simple!
      05-19-2015, 09:49 AM   #7
al2fast
Drives: 2011 535i
It was diagnosed by the shop as the tensioner pulley itself making the noise. $134 part they say they can only get from BMW and they said a new belt was $52 so I ordered one of those 2. They quoted me $60 in labor to do it so I said go right ahead. Part won't be in until later this week so the noise won't be fixed until next Tuesday. Will obviously verify at that point, but I have had really good luck with this place so far!
      05-19-2015, 08:16 PM   #8
lsturbointeg
Cool...Definitely let us know if the sound goes away after the work.
      09-23-2016, 03:47 AM   #9
Vihang Limaye
Drives: BMW 523i 2011 model
I have almost the same noise in my 523i 2010-2011 model.
Dealer says it might be timing chain,idler pulley,tensioner and belt or DME and coils. He wants to replace all!
Let me also add that my vehicle was sent for the VANOS bolts replacement on their recalling. After that I hardly drove a 1000Kms
Any solution got?
