2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Retrofit M5 f10 cluster on 523i
      07-24-2019, 03:49 PM   #1
The King 464
The King 464's Avatar
Drives: Bmw 523i F10 2011
Hi guys
i just want to ask if anyone can help me to retrofit a m5 cluster to my car
and help me with the coding or give me instructions on how to code it
like this one on the photo
is it possible like this guy just did
https://www.bimmerfest.com/forums/sh...d.php?t=786565
Thanks in advance
      07-26-2019, 08:40 AM   #2
bmwf10projects
Drives: F10
I did it and it works. I also did shifter too.
Klerin106.00
      07-26-2019, 09:18 AM   #3
Klerin
Klerin's Avatar
Drives: 2014 550i M-sport
is this very time consuming? do you have an HUD?
Thanks!
      07-26-2019, 02:51 PM   #4
The King 464
Can you help me doing it cause I'm new to these stuff
just give me the steps and ill figure it out
or the values that need to be changed
and how did you write the vin number to the cluster
Thanks
      07-26-2019, 07:29 PM   #5
bmwf10projects
Drives: F10
Thanks
Hello
I have both M5 and N20. I did HUD, Shifter and Cluster. I spent like 4 months to figure out. These are the pictures[IMG][/IMG]
      07-27-2019, 12:12 AM   #6
jonobro
Drives: bmw f10 535i
Thanks
Hello
If you retrofittted HUD doesn't that mean you would have to change the whole dash ? haha
      07-27-2019, 01:11 AM   #7
Klerin
Klerin's Avatar
Thanks
Hello
yeah I think I came across your build. you went all in! like middle console and everything did you not? pretty sick, in my opinion. regardless of what people think!
      07-27-2019, 09:17 PM   #8
bmwf10projects
Drives: F10
no, I just coded HUD, replaced Cluster and the shifter
      07-27-2019, 09:18 PM   #9
bmwf10projects
Drives: F10
yes, I built a complete M5 in my backyard. Car is for sale for anyone interested !
      11-11-2021, 07:02 AM   #10
ccfj1
Tinkerer
ccfj1's Avatar
Drives: F25 X3 M-Sport
Sorry to resurect and old thread.
bmwf10projects any chance you could share the love mate?
I have an f25 (2tm 8speed sport tranny) and can pick up an m6 kombi up cheap, any help on how you did this would be great.
2014 F25 X3 335d M-Sport:
      03-12-2023, 03:48 PM   #11
slobo7x
Drives: 2016 550 F10
I would love to hear more about this too, I’m getting no gear position display at all and transmission error code..
      03-17-2023, 12:17 PM   #12
Unspec
Unspec's Avatar
1303
Drives: 2015 BMW 535xi
Notice how their photo shows no gear. This is because it is not possible to get gear information on a non-M5 car, as the gear information comes from an entirely different ECU that non-M5 cars don't even have.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-17-2023, 06:13 PM   #13
slobo7x
I am working on this as we speak, waiting for some harness pigtails to come in to connect additional wires to icm and dme, &dme2.
The problem is not the cluster itself as the wiring to it is the same across the board, it’s the gear shifter and dynamic control board that has to be rewired. I’ve done a lot of research on this and looked at wiring more then I’d like to admit, M5 Cluster is not enough for a fully functioning retrofit. This is where most make a mistake trying to get the cluster to work with some random coding in E-Sue to hide gear shift errors, etc.
will make a post or reply here once I’m done as most people who have tried have either failed or do not respond.
There is a YouTube video of a guy from overseas retrofitting gear shifter and controls but he’s using 6WB cluster not M5 one so no issues there. I don’t see the point of this really without the cluster, but to each their own.
      03-17-2023, 08:51 PM   #14
Unspec
Unspec's Avatar
1303
Yep, needs a bunch of wiring work as you mentioned. If you can get the gear information correctly to the cluster, it'll work. That is what I meant, apologies if I was unclear.
2015 BMW 535xi
      05-05-2023, 04:36 PM   #15
slobo7x
I just did a video of mine, all working.. This took a lot off work and coding, but really an amazing outcome..
      05-09-2023, 09:28 AM   #16
ccfj1
Tinkerer
ccfj1's Avatar
Amazing mate. Can’t wait to see what’s needed.
I have a m5 cluster and gear shift ready to go. Hoping it will work in my f25.
      05-20-2023, 07:19 AM   #17
ruben_17non
Drives: BMW E92 LCI / BMW X4
I try retrofit m5 panel
But original HUD not show nothing
Anyone can help?
      06-05-2023, 04:44 PM   #18
coasts
coasts's Avatar
Drives: 2015 535i xDrive
Thinking about doing this. To anyone who has successfully done this retrofit, please let me know what needs to be coded because I assume its not just PNP.
      12-29-2023, 09:56 AM   #19
slobo7x
No, not PNP for sure lol.
Do a lot of research, it can be done it's just how much work are you willing to put into it to get it working?
      04-06-2024, 02:54 PM   #20
GabiSibiu
GabiSibiu's Avatar
Drives: F13 640i
slobo7x
hi, the video is no longer valid, can you give me some details on how to get my gears to appear on the dashboard? I too have a F13 640i and have M6 cluster . Thanks
      04-06-2024, 04:28 PM   #21
slobo7x
You cannot code gears into the cluster to show up, I’ve done extensive work and research and we just don’t have the hardware on non-M models to make that happen.
This requires a physical hardware adapter to get to work.
Do a search on f30 m3/m4 cluster adapter and that’s what you need, it’s about $350.
Good luck
      04-07-2024, 02:51 PM   #22
GabiSibiu
GabiSibiu's Avatar
Drives: F13 640i
I kept trying to search, but I can't find it available…
