2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY Leaky Turbo Lines 550i (n63)
      05-07-2015, 11:46 AM   #1
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
So kept smelling a toxic burning plastic smell and thought it was some of the brittle plastic clip holders that break last time I changed the vacuum pump seal, but lo and behold it was the turbo cooling lines on top!
Symptoms also include seeing some green crud around the fittings and obvious dripping.
BMW Wants about 400$ for all the lines but it seems like the only parts that leak are between the rubber hose and the metal line. Can you say "new hose clamp" ??
So i did that but after a time leaks again. So it seems the hoses them self break down and you just need to change them. The whole job will cost you less than 20$.
One of the pics below you will see how the hoses can really start to crack and break down.
Need to get some lower profile screw type hose clamps for the "T" connection.
Sorry the first pic is the completed job. I attached it wrong on my phone.
      05-07-2015, 12:08 PM   #2
gclions
gclions's Avatar
78
Drives: 2011 550i
Did the same thing on three of the hose ends. It's a shame that these are failing so quickly, but the replacement/repair is pretty straightforward.
Thanks for posting.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      05-08-2015, 05:48 PM   #3
///M5Driver
Drives: gaggle of BMW's
Nice DIY.. i had the burning smell too. BMW of NWA couldn't reproduce the smell lol. Baron BMW in KC knew what it was in 15 seconds of popping off the engine cover.. in the parking lot.
      08-14-2015, 09:10 PM   #4
rolbaeza
Drives: 2011 BMW 5501
Great Job Posting this!!!!
Stealer quoted me $400 for lines and $600 for labor.... I almost fell out of my desk at work!!! I am going to do this DIY job myself.... Stealer sure does take advantage of people, I been looking at different threads today.
      09-18-2015, 11:25 PM   #5
Autobuffoonery
I am groot
Autobuffoonery's Avatar
25
Drives: 550I M SPORT
Damn it I paid the dealer $480 to replace the oil and water lines to the turbos! They made it sound like you had to remove the engine to replace them. I could've easily replaced them myself, Lying D'bags. well it stopped the burning oil smell the car had, I've never let anyone work on my cars before
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order
      09-27-2015, 08:34 PM   #6
peter91118
peter91118's Avatar
29
Drives: '01 325xit, '09 335i
This should all get replaced under the CCP
      09-27-2015, 09:30 PM   #7
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
Don't think they do
      09-28-2015, 05:40 PM   #8
peter91118
peter91118's Avatar
29
Originally Posted by dadysev View Post
Don't think they do
Nope, you're right.
Seems like they only get replaced if you are lucky enough to need your chain done
      09-29-2015, 10:00 AM   #9
General_Keller
General K
General_Keller's Avatar
46
Drives: 2013 Sapphire Black M5
Having this issue now, about to do this same fix. Quick question whats the size of the rubber hosing? Inner and outer diameter? You think upgrading to silicone is a good idea because of the heat? THanks!
-KC
      09-29-2015, 11:27 AM   #10
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
-KC
i think i used 3/8 I honestly can't remember.
      10-14-2015, 08:08 PM   #11
sweetazzj186
Drives: 2011 550 xi
The hose size should be 1/2 inside diameter. I just tried 5/16 and 3/8 and they were both too small. I ordered 1/2 now.
      04-04-2016, 02:03 PM   #12
VinoFiveFiddy
VinoFiveFiddy's Avatar
Drives: 2011 550ix
I just got quoted $690 to replace the turbo coolant lines by my dealer. I'm going to diy this. Seems super simple.
2011 550ix M-Sport/Carbon Black/Black Grills w-TriColor/18% 3-M tint/CF Performance Spoiler/Coded/ Philips 5000K fogs/CF side turn cover/Painted Reflectors/20" staggered BMW 356's/BMS 15mm rear spacers/BMS Stage 1/M5 Exhaust/Custom Ram Air
      05-30-2016, 04:00 PM   #13
Chickenmusket
Drives: 2012 550i, 2015 i8
Leaking Turbo Coolant lines
Nice thread, check hose ID, I used 1/2 inch and they were big on the metal pipe side, will re-do using 3/8 and let everyone know.
      06-07-2016, 12:46 PM   #14
jph641
Drives: BMW 750Li xDrive M Package
Hey any update on hose line size ? Im about to do this project this week and wanted to know what size hose to buy.
Thanks
      06-07-2016, 04:41 PM   #15
FiveFiftyEye
Drives: 2011 550i M Sport
Got a quote for a whopping $1800 to replace coolant lines and turbo coolant lines. The pipes are likely good, ill just redo the fasteners. I got a powertrain malfunction…took it in and was informed the fuel lines failed. They were replaced as part of the CCP last year so they're covered under bmw warranty but Im concerned theyl fail again...so I'd better get extended warranty. The cars only got 40k miles on it, these types of critical parts should not fail. Thanks for posting the DIY!
      07-02-2016, 04:37 PM   #16
BMW UDM
Drives: 550i 2011 DS2
Hose ID Size
Same issue. 1/2" seems to big. Is 3/8" ID working ? Thanks.
      07-04-2016, 01:16 AM   #17
Paul1994
Drives: 2018 BMW M4 comp -- BMW x5 G05
  [0.00]
Joining the party
After a couple of days of smelling burnt coolant I decided to go exploring. I thought i may have spilled some on accident and it would burn off. I was wrong. After finding this thread I went exploring. and found this.
Has anyone ordered the OEM parts yet and did it that way?
http://www.realoem.com/bmw/enUS/show...diagId=11_4190
If not i will be buying some hoses and do this myself too.
      07-04-2016, 07:23 AM   #18
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
I believe the hoses are about 400 -500 $ but then they leak again. Thats the only thing i have heard.
      07-06-2016, 10:39 AM   #19
BloomingtonFPV
Drives: 2011 550i xdrive
I'm having a similar problem (see pictures). I'd like to DIY it. What clamps should I use, and what is the inner diameter of the hose for the two short sections that attach to the Tee connector?
      07-08-2016, 09:11 PM   #20
Sunnyc123abc
Drives: 550xi
Make sure to check the y hose connector in front of the driver side turbo. Mine basically disintegrated to dust. Pain to change out but doable.
http://f10.5post.com/forums/showthread.php?t=1275796
      09-08-2016, 03:58 PM   #21
Paul1994
  [0.00]
Just an update for me at least. I ended up taking the beast to the dealership 3k later I think I am back to square one. I really love this car but repairs like this are going to kill me.. I do have a aftermarket warranty but guess what they don't cover hoses/pipes..
      09-16-2016, 07:28 PM   #22
Sunnyc123abc
Drives: 550xi
Yea, my warranty (safeguard) wouldn't cover my rubber hoses as well. What did the dealer replace?
