2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW M5 m343 rims on a LCI 550i xdrive with spacer question
      11-15-2023, 01:30 AM   #1
SocomCA
Drives: BMW M6
Hey guys,
I have a 2016 BMW 550i xdrive with 343m M5 F10 rims and since its a LCI 550i xdrive it requires a spacer to clear the caliper.
I was wondering, what spacer do you guys who have the same 343m wheels on their lci 550.
I know there are hub centric spacer and regular ones. I'm not sure what to get. I have a 5mm spacer now and I do feel vibration. These are the spacers: https://www.turnermotorsport.com/p-5...2-f10-f13-f25/
Online on tunermotorsport for a 5mm spacer it says:
"This spacer slips on the existing hub lip and leaves some lip left over for the wheel to rest on. This keeps the wheel hubcentric*.
* - To avoid vibration, 3mm spacers work best with wheels that have a flush mounting surface. Wheels that have a bevel around the mounting surface will not be fully seated on the hub and a vibration may result."
1. Does the 343m have a bevel?
2. Do you recommend a hub centric or not hub centric spacer for this issue?
      11-15-2023, 12:56 PM   #2
Unspec
Unspec's Avatar
1304
Drives: 2015 BMW 535xi
343M has a bevel. That said, I ran a 3mm spacer with no vibrations.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      11-15-2023, 02:08 PM   #3
SocomCA
Drives: BMW M6
Which spacer/brand spacer did you use? I am having vibrations with 5mm spacer
I ordered this 3mm spacer to be installed: https://www.turnermotorsport.com/p-5...-1-pair-black/
What are your thoughts on it?
      11-15-2023, 03:18 PM   #4
Unspec
Unspec's Avatar
1304
5mm will not let you sit on the hub properly. I used the turner ones.
2015 BMW 535xi
      11-15-2023, 03:28 PM   #5
SocomCA
Drives: BMW M6
Do you think this would work: https://www.turnermotorsport.com/p-599059-dr-series-wheel-spacers-3mm-1-pair-black/
      11-15-2023, 11:49 PM   #6
Unspec
Unspec's Avatar
1304
Originally Posted by SreeM View Post
Probably, but I'd skip any spacer that lacks a cutout to fit a screwdriver into on the "back". They're going to corrode to the hub eventually, and without that cutout, it's devilishly hard to remove them.
These are the ones that I got when I used to run 3's. Note the cutouts on the back that I refer to.
2015 BMW 535xi
      11-21-2023, 07:14 PM   #7
SocomCA
Drives: BMW M6
Do they call more vibrations?
      11-28-2023, 01:34 AM   #8
Unspec
Unspec's Avatar
1304
None that I could tell.
2015 BMW 535xi
Tags
343m, 550, f10, spacer
