2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum removed neg from battery and now can't open boot
      06-28-2015, 05:14 PM   #1
tintin1012000
Drives: bme 320d
Hi. Guys. So I was finishing up the vial wrap on some interior parts carbon effect. And I decided to do the plastic piece around the base of the steering wheel airbag. I disconnected the battery negative as advised and then closed the boot and went about my way. Put back the airbag and then went to open the boot but could not. .. I was expecting to see a key over ride on the boot somewhere.but no luck... eventually had to remove rear seats to gain access. If there an easier way??? I will post pics of the wrap results tomorrow
      06-28-2015, 05:38 PM   #2
OEMonsterz
OEMonsterz's Avatar
Drives: 535D M Sport
Dude.. did you take the physical key out of the key fob and use it on the boot as you would with any old car?
      06-29-2015, 01:40 AM   #3
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
Did the same on my E70 when I removed the battery to charge it. The only way to get the trunk open was to get into the trunk from the cabin and use the manual lever, because as you say there is nowhere to physically insert the key in the trunk from the outside. Pretty sure the F10 is the same
      06-29-2015, 04:20 AM   #4
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
That was a bit silly wasn't it?!
Should have left the boot open really. You'll know for next time. Lesson learned.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      06-29-2015, 08:46 AM   #5
Bbb34
Drives: '11 535i 6sp. DHP/RWD
No, not at all, I have to do this later this week, so I'm glad I've seen your post first, otherwise it'd be me posting the same thing.
      06-29-2015, 08:46 AM   #6
OEMonsterz
OEMonsterz's Avatar
My BAD OP... I personally haven't noticed this foolish design from BMW. Some things should remain as standard. One of those things should be the option to insert a key in the door and the frickin boot. Anyway you have two options:
1.You can hook jumpers up to the terminals in the engine bay... try this first.. get a boost from a neighbor.
2. Strip out the rear seats.
Refer to this thread if you need info on seat removal. Hope this reaches you in time.. before the crow bar comes out.
http://f10.5post.com/forums/showthread.php?t=795284
      06-29-2015, 10:24 AM   #7
Dave4501
Drives: F10, E70, E64, and E60
That's just crazy. Isn't there a simple way to get trunk open if battery is disconnected?
My 07 530i still had a key hole in the trunk. Some things shouldn't change.
'12 535i,
'12 X5,
'15 Boxster
RETIRED: '08 650i, '07 530i, '06 330i, '00 323ciC
      06-29-2015, 01:47 PM   #8
The Beast
The Beast's Avatar
The E70 seats folded from the cabin so not an issue, can see how this would be a problem with the F10 whereby the seats fold from the trunk
      06-29-2015, 03:02 PM   #9
493263
493263's Avatar
71
Drives: 2011 550i xDrive
That would suck if you have an F10 without fold down seats lol.
But seriously, BMW should put the physical key hole under a moveable BMW emblem.
      06-29-2015, 03:57 PM   #10
The Beast
The Beast's Avatar
I'm pretty sure that even if they do fold they only fold from levers in the trunk
      06-29-2015, 04:02 PM   #11
OEMonsterz
OEMonsterz's Avatar
From trunk only
      06-29-2015, 05:38 PM   #12
Pimpsy
Drives: 2019 M5C
Can't you just jump the battery to the terminals in the engine bay?
