2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Commercial Marketplace - F10/F11 Classifieds AutoTalent | DINAN | Exhaust | Intake | Performance Tuner | F10 550i, XDrive 2014+
      11-15-2015, 04:10 PM   #1
AutoTalent
AutoTalent's Avatar
2310
Drives: e92 M3 6mt | e60 M5 6mt
AUTOTALENT | DINAN | F10 | 2014+
Please PM or E-Mail
Golan@AutoTalent.com
for Pricing and Info!
ABOUT DINAN
Founded in 1979, Dinan® is well established as North America’s premiere BMW tuner. Dinan develops, manufactures and markets a comprehensive line of high performance products and systems, distributed through a nationwide network of Authorized Dinan Performance Centers that includes select BMW Dealerships and Independent BMW Service/High Performance facilities.
DINANTRONICS Performance Tuner
STAGE 1 | STAGE 2 | STAGE 3
Stage 1 - Maximum Power: 506 HP, 547 lb-ft of torque.
Stage 2 - Maximum Power: 520 HP, 560 lb-ft of torque.
Stage 3 - Maximum Power: 544 HP, 583 lb-ft of torque.
The DINANTRONICS™ Performance Tuner is a highly engineered and sophisticated piece of computer hardware and software that enhances engine performance, without negating or voiding your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device emissions legal in all 50 states. The ultimate objective of developing this piece of technology was to provide the ability to control every signal entering and exiting the BMW factory Engine Control Unit. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package.
Dinan® Free Flow Stainless Exhaust
Dinan's Free Flow Exhaust improves exhaust flow by reducing back pressure, resulting in increased power output and a great sporty sound that is civilized when you want it to be and pleasantly aggressive under harder acceleration with zero drone. 100% stainless steel construction and exacting specifications ensure that the system fits correctly using the factory hangers and will resist corrosion for years to come. An vacuum controlled butterfly valve is utilized to improve flow at wide open throttle while keeping things civilized and "drone" free throughout. The design reduces overall weight as well and features 3.5'' polished tips for a tasteful high performance look.
Benefits of the Dinan® Free Flow Exhaust for the F10 550i:
+ Sportier sound
+ 100% 304 stainless steel construction
+ Bolt-on installation
+ Four 3.5” stainless steel polished & laser engraved exhaust tips
+ Add 10 Horsepower when used in conjunction with the Dinan Performance Software Upgrade
Dinan® Carbon Fiber High Flow Air Intake-Strut Tower Brace
The Dinan® carbon fiber intake looks as good as it performs, allowing more outside air to be pushed into the engine via twin-ducts while also providing structural stiffness to the strut towers. Two new air inlets are added, each with its own high flow filter mounted into the mouth of the carbon fiber inlet. The stock air inlet is fully functional to provide four intakes into the engine for maximum airflow. The filtered air passes from the inlets into the black powder coated ducts then directly into the engine.
The Dinan® Engineering team had a special challenge with the F10 550i. With very little room to work with under the hood the team came up with the ingenious idea of combining the shock tower brace and the inlet tube into one part. The results are beautiful and purposeful looking.
Benefits of the Dinan® Carbon Fiber High Flow Air Intake – Strut Tower Brace for the F10 550i
+ More Power: +13 HP & +10 lb-ft of torque when used in conjunction with the Stage 2 DINANTRONICS™ Performance Tuner as well as Dinan exhaust.
+ Beautiful Dual Carbon Fiber Inlets
+ Integrated Strut Tower Brace
+ Stock System Stays Completely Functional
Dinan® High Performance Air-to-Water Intercoolers
More power, great looks, more consistent performance and no downside by upgrading to the Dinan High Performance Intercoolers for the N63TU V8. Heat is the enemy of horsepower, beat it by replacing the air-to-water intercoolers with larger units from Dinan to reduce the charge air temperature. Add an impressive 23 horsepower and 15 lb-ft of torque when used with the DINANTRONICS™ Performance Tuner as well as Dinan intake and exhaust. This additional cooling is even more important in hot climates where the inherent power loss is much higher.
The two intercoolers are beautiful and purposeful looking, wrapped in black powder coat and laser engraved with the Dinan® logo.
Benefits of Dinan's High Performance Air-to-Water Intercoolers
+ Replaces factory air-to-water intercoolers with 23% larger units.
+ Black powder coated and laser engraved intercoolers.
+ Includes silicone hoses, coolant lines, mounting brackets and hardware.
+ Maximum gain of +23 hp and +15 ft-lbs (when used together with the DINANTRONICS™ Stage 3 Performance Tuner as well as Dinan intake and exhaust)
Unmatched Warranty
Dinan's comprehensive warranty program, introduced in 1997, provides superior warranty coverage to that which you would find elsewhere. If your vehicle is currently covered by the vehicle manufacturer's new car limited warranty, Dinan® products are warranted for the remaining term of the vehicle manufacturer's new car limited warranty. The manufacturer's new car warranty is limited to 4 years or 50,000 miles (80,000 kilometers in Canada), commencing on the date of first retail sale or the date the vehicle is first placed in-service as a demonstrator or company vehicle, whichever is earlier. Dinan's warranties are transferable when ownership of the vehicle into which the Dinan® products were originally installed is sold. BMW automobiles can now be performance-tuned without the associated concern of negatively affecting the new car warranty coverage.
How to Place Your Order:
Phone Domestic: (310) 231-0292
Phone International: (310) 231-0292
E-mail: Golan@AutoTalent.com
Website: www.AutoTalent.com
Payment:
Installations:
Feel free to visit us at our 20,000 square feet facility in Carson, CA.
We install everything we sell.
20780 Leapwood Ave
Carson, CA 90746
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
      11-30-2015, 05:43 PM   #2
AutoTalent
AutoTalent's Avatar
2310
Bump!
      12-07-2015, 01:58 PM   #3
AutoTalent
AutoTalent's Avatar
2310
Bump!
      12-29-2015, 07:14 PM   #4
AutoTalent
AutoTalent's Avatar
2310
End of the year specials! PM for more info!
      01-06-2016, 08:11 PM   #5
AutoTalent
AutoTalent's Avatar
2310
Bump!
      03-07-2016, 01:13 PM   #6
AutoTalent
AutoTalent's Avatar
2310
Bump!
      03-14-2016, 04:49 PM   #7
AutoTalent
AutoTalent's Avatar
2310
Bump! Please PM with any questions!
      04-04-2016, 01:59 PM   #8
AutoTalent
AutoTalent's Avatar
2310
Bump!
      04-18-2016, 08:20 PM   #9
AutoTalent
AutoTalent's Avatar
2310
Bump!
      05-17-2016, 04:16 PM   #10
AutoTalent
AutoTalent's Avatar
2310
Bump!
      05-25-2016, 07:28 PM   #11
AutoTalent
AutoTalent's Avatar
2310
Bump!
      06-06-2016, 01:04 PM   #12
AutoTalent
AutoTalent's Avatar
2310
Bump!
      06-27-2016, 12:11 PM   #13
AutoTalent
AutoTalent's Avatar
2310
Bump!
      08-04-2016, 06:36 PM   #14
AutoTalent
AutoTalent's Avatar
2310
Bump!
      10-13-2016, 08:08 PM   #15
AutoTalent
AutoTalent's Avatar
2310
Bump!
      11-01-2016, 03:59 PM   #16
AutoTalent
AutoTalent's Avatar
2310
Bump!
      11-14-2016, 05:42 PM   #17
AutoTalent
AutoTalent's Avatar
2310
Bump!
      12-05-2016, 06:43 PM   #18
AutoTalent
AutoTalent's Avatar
2310
Bump!
      01-03-2017, 06:46 PM   #19
AutoTalent
AutoTalent's Avatar
2310
Bump!
      01-11-2017, 06:13 PM   #20
AutoTalent
AutoTalent's Avatar
2310
Bump!
      01-24-2017, 07:22 PM   #21
AutoTalent
AutoTalent's Avatar
2310
Bump!
      02-07-2017, 03:53 PM   #22
AutoTalent
AutoTalent's Avatar
2310
Bump!
Tags
autotalent, dinan, ecu, exhaust, intake
