2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Question for exhaust experts!
      03-23-2014, 01:27 AM   #1
550toronto
Drives: 2014 F10 550ix
I have a 2014 550 and I purchased a M5 DTM diffuser ! I know this brings the exhaust closer to centre ! How much closer? And should I be buying an exhaust for a 550 or a M5 because of my diffuser choice?
Thanks!
      03-24-2014, 12:18 AM   #2
550toronto
No one?
      03-24-2014, 12:32 AM   #3
james23
Drives: BMW 550i M Sport
http://f10.5post.com/forums/showthread.php?t=959277
This thread shows the difference between the 550i diffuser and the M5's. However, the car is a 535i with a Remus exhaust. I'm assuming the placement is very similar though.
      03-24-2014, 10:46 AM   #4
550toronto
Yeah, they are not quite center using the M5 diffuser......What is the difference in the tube diameter? from 550 to M5.....If I order a M5 exhaust over a 550 exhaust I will probably have to reduce....Because from reading it seems the M5 Tube are 3" and the 550 is smaller but I'm not sure by how much.
      03-24-2014, 05:19 PM   #5
james23
I believe the M5 is 76mm dia (about 3") and 550i is 70mm ( about 2.75").
      03-24-2014, 05:56 PM   #6
CaliE90
CaliE90's Avatar
354
2021 M550xi  [0.00]
Thanks!
You will want to buy a M5 exhaust.
Most 550i exhaust will not fit a M5 diffuser unless you modify it. It also won't look as good as a M5 exhaust.
Retired- '14 F10 535i -- 3 2 1 | '08 E90 335i -- 4 3 2 1 |
