2010 2011 BMW 5 Series Forum F10 2 much boost and my car pooped out the ceramic cats! |
05-06-2015, 12:05 AM | #1 |
Rep 2,416
hahaha i thought it was wood inside my exhaust at 1st.
2011 550i RWD 60-130 7.35
05-06-2015, 12:27 AM | #2 |
Rep 18,682
@badblack550xi wow, lucky nothing bad happened.
Time for catless now, hahaha.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-06-2015, 12:32 AM | #3 |
Rep 2,416
well im sure some is still stuck inside my pipes
05-06-2015, 08:47 AM | #4 |
Rep 18,682
Uh, need to clear them out before it becomes a problem.
05-06-2015, 09:41 AM | #5 |
Rep 2,416
wonder if manufacturer will take care of it....
05-06-2015, 09:44 AM | #6 |
Rep 844
05-06-2015, 09:53 AM | #7 |
Rep 2,416
imatalking about the Performance Catted down pipes i got and not a cheap knock off.
05-06-2015, 10:03 AM | #9 |
Rep 249
Realistically, I'm not sure what they could do. Large pieces hung up where you can see them in the mid-pipes, possibly can be retrieved. The rest of the cat material has been blown to the resonator/mufflers. Even removing the exhaust sections doesn't help much without making cuts before resonator or before mufflers.
Likely you won't notice performance problems, though if only one side is like this you'll get a check engine light with associated emissions codes for the affected side. You may however get rattles at certain resonances due to the pieces vibrating inside whichever portions they got hung up in. I would think over time the pieces would vibrate and crumble to the point they get blown into the mufflers. As far as the downpipes are concerned, I would think the manufacturer of the downpipes would offer some compensation, or at least a new set of downpipes for the trouble. You haven't had them that long, what two years? No reason the cat material should have failed this early.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
05-06-2015, 02:13 PM | #10 |
Rep 1,250
Drives: 20' X3M CP
Yes dude, they have too.
AR right? email them
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
05-08-2015, 12:24 AM | #12 | |
Rep 18,682
05-08-2015, 12:35 AM | #13 |
Rep 2,416
basically
