2010 2011 BMW 5 Series Forum F10 Xenons - Daytime Driving Lights setting? |
01-29-2016, 10:59 AM | #1 |
Rep 3
I've just taken delivery of a 520d SE with standard Xenons. In my previous 2011 F11 (non-Xenon) I could set Daytime Running Lights in iDrive settings. In the new car there isn't this option in my iDrive Settings under Lights - even the owner manual says there should be this option.
Does anyone have Xenons with Daytime Running Lights set in iDrive? Am I missing something? My workaround is to leave headlight switch permanently on. Living in the countryside I am a big believer in daytime running lights. |
01-29-2016, 11:32 AM | #2 |
Rep 605
The reason there is nothing in iDrive is that you aren't allowed to turn them off nowadays. If this is a new car they will be on all the time whether you want them or not. If they are not coming on with the engine, check the fuses.
http://www.theaa.com/motoring_advice...ng-lights.html |
01-29-2016, 12:28 PM | #3 |
Rep 5,093
are you saying thay they are not on with the switch in "0"?
I know it can be coded but you should not have to resort to that for a new car.. this I assume is a uk new model ? |
01-31-2016, 05:53 AM | #4 |
Rep 46
they will be turned on by default and even if the headlight switch is on the 0 . one way to be sure is to start the car and turn the headlights to 0 and walk around to the front and check!
As far as i know the headlight switch makes no difference, as soon as the engines turned the DRL will turn on . |
02-02-2016, 12:50 PM | #6 | |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
The DRL setting in your old car just set the headlights on all the time. As the LED DRL's fitted to LCI F1X models are designed to be used as that, they are bright enough to not need the headlamp as well, hence the option in iDrive was removed.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
