2010 2011 BMW 5 Series Forum F10 Jb4 535 can't change maps. |
02-27-2016, 03:33 PM | #1 |
Rep 70
Just installed jb4 F series on my 2012 535 but cannot change maps. Held the volume button down no flashing on the shifter. Got the harness type b everything is connected. Only 2 wires coming out of the box is power and ground.
Have tried it with the 4pin to obdii connector hooked up and disconnected. Still same results no flashing of the shifter. Can someone lend me some insight. The jb box is a long plastic cased rectangle with harness coming out with 2 loose wires power and ground. No serial cable like I have seen in many other installs. Last edited by DaHeadlightGuy; 02-27-2016 at 05:24 PM.. |
02-29-2016, 04:00 PM | #3 |
Joint Chiefs of Staff
24174
Rep 190,750
You can find everything that you need on this link
http://www.n54tech.com/forums/showthread.php?t=18588 If you are still having problems contact BMS technical support
