2010 2011 BMW 5 Series Forum F10 Do you experience any of these glitches? |
06-01-2012, 10:08 AM | #1 |
Rep 100
My SA has advised to bring the car in for a day so they can look at these things (that's when I asked for a software update which they do not perform unless there is a problem that needs to be addressed).
So before I do, can you guys confirm that you DO or DO NOT exhibit these glitches. Or if you had them, were they fixed? Thanks. 1. Sometimes when I pull out of my garage in the morning, the computer will somehow mistakenly dim the white dash illumination into a barely visible, darker tone of gray, making the dash look not only less clear but almost "dead" (or dying). The red temperature display on the climate control on the central console is also much darker and almost invisible. When I go to my car at lunch and start it up, things usually return to normal but a simple ignition off and on does not quickly fix it. I've observed it three times by now. Adjusting the illumination knob does not help (it doesn't do anything). 2. Comfort access has a delay before it allows me to lock the car. I shut the door, press the stipe and nothing happens. Instead, I have to shut the door, wait for about 2 seconds, THEN press the stripe and it will lock. It is quite annoying as it simply does not permit closing the door, touching and walking away - one has to close, WAIT, then touch and walk. 3. The iDrive screen forgets my last function intermittently. I typically have it set on the nav while driving and while most of the time it will display the same nav screen when I return to the car, 4/10 times it will not (it is basically random). Those 4/10 times will bring me back to the main menu forcing me to select nav and hide the left hand options.
06-01-2012, 10:53 AM | #2 |
Rep 4,040
1. Mine doesn't do that (or I haven't noticed)
2. My CA lock as soon as I like it to 3. I haven't noticed I have a 2012 528 |
06-01-2012, 03:43 PM | #4 |
BMW Enthusiast
25
Rep 303
1. no (turn off your automatic headlights and that might solve the issue)
2. yes (I feel like I have to arouse the handle in order for it to work) 3. Haven't noticed.
2022 X5 sDrive 40i Carbon Black | Ivory White Vernasca Leather | Aluminum Tetragon Trim | ZMP | ZPP | ZLS | ZPK | 337 | 4NB | 3M2 | 4HB | 7M9 | Black Kidney Grills |
06-01-2012, 09:09 PM | #6 |
Rep 228
No, Yes, Yes. #3, idrive, I've found that when I start the car and back out of a spot, the camera comes on then when I put the car in drive and the camera goes off, the idrive screen returns to where I left it. However if I start the car and drive off forwards and so the camera doesn't come on, often the idrive comes up at a top menu, not where I left it. I find the idrive having a mind of it's own a bit annoying.
06-03-2012, 12:55 PM | #8 |
Rep 260
No, no (no comfort access), yes either under hard acceleration or left turns. Dealer updated software and some sort of reset, although they claimed they couldn't replicate the issue... Useless in a word, now just accept it...
06-09-2012, 12:34 PM | #12 |
Rep 25
Drives: '11 550i & '11 X35i
1. Nope
2. Yep (I've had my batteries replaced to no avail) CA on my E93 was more reliable 3. Yep |
06-10-2012, 03:24 AM | #13 | |
Rep 18
2. No 3. No |
06-10-2012, 07:24 AM | #14 |
Rep 21
I have only noticed #2. If you close the door, it seems you have to wait until the soft close mechanism is done, regardless if you allow soft close or slam the door, then it will let you lock. I have the soft-close option, but unsure if the same thing would apply without the soft-close.
