2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds CKS F10 Coilovers
      05-21-2014, 10:58 AM   #1
LACSTER
Drives: Hybrid
CKS F10 Coilovers
USD 1,650.00
✓ Will Ship
I have a brand new set of CKS Coilovers. Specs as followed. Retails for $1875.00
-mono-tube shock design (inner polished seamless 55mm steel tube)
-44mm linear characteristic internal piston
-Italian IP F.A 5W shock oil: very high viscosity index guarantees efficient shock absorbing movement at any ambient temperature.
-hard anodized forged aluminum upper mounts spring perch and lower mount
-24 way dampening adjustability with a 12kg spring rate on the front and 10kg spring rate on the rear, making these CKS coilovers a true set of fully adjustable coilovers
-double wishbone suspension can custom order it with forged aluminum shock body for weight saving
-new front sway bar links are included
78mao's F10 on CKS
IE92's F10 on CKS
      05-21-2014, 11:17 AM   #2
badblack550xi
badblack550xi's Avatar
fits F10 550xi ?
2011 550i RWD 60-130 7.35
      05-21-2014, 11:18 AM   #3
Hollywood Hogan
Hollywood Hogan's Avatar
98
Drives: Sold: '13 RS5
Do these fit on cars with EDC?
      05-21-2014, 11:25 AM   #4
LACSTER
Drives: Hybrid
Originally Posted by badblack550xi View Post
fits F10 550xi ?
This won't work on xi models
Yes however you'll lose your EDC feature like with any other coilovers offered for the F10.
      05-21-2014, 12:04 PM   #5
Hollywood Hogan
98
I probably should have rephrased. Do the coilovers come with the EDC delete so that no errors would pop up on the idrive?
      05-21-2014, 12:34 PM   #6
LACSTER
Drives: Hybrid
Oh gotcha! CKS does not have the EDC delete option but I think some of the local coders might be able to disable that for you.
      05-21-2014, 09:52 PM   #7
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
<<<<------- Must stop checking the classifieds...
      05-22-2014, 11:08 AM   #8
LACSTER
Drives: Hybrid
You get special pricing my friend!
