2010 2011 BMW 5 Series Forum F10 Headlight Vertical Adjustment |
09-20-2011, 11:58 PM | #1 |
Rep 89
Hi there. My headlight on the passenger side seems slightly low and would like to adjust the vertical height. I want to confirm (from pic below) that the arrow pointing to the hex screw is the one that adjusts the vertical height? Can someone please confirm before I muck with it? And is it clockwise that raises it or CCW? Thanks.
09-21-2011, 02:37 PM | #2 |
Rep 28
Drives: F10 525d
Make sure the light switch is set to position 2 before adjusting if you have the adaptive xenons, as the Auto setting affects both height and width of the beam pattern.
09-21-2011, 03:05 PM | #3 |
Rep 89
BMW550mike28.00 |
09-21-2011, 05:50 PM | #4 |
Rep 13
I need to do this also what is pos 2
My light switch 1 to left is auto 1 to right is parking 2 to right is headlights adaptive is only to left pos 1 auto, and is up adjustment clockwise |
09-21-2011, 10:29 PM | #5 |
Rep 89
09-29-2011, 11:32 PM | #6 |
Rep 89
Hi Bimmertaxi. question: so I adjusted with the light in position 2. As days go by, I realized I positioned it to high... so opened the hood and did several adjustments over a period of time... BUT i freakin forgot to move the light switch to position 2 (i.e. left it in Auto setting) and probably affected the width of the beam (how to confirm?). If I turn clockwise, does it make the beam width smaller or larger?
09-30-2011, 02:05 AM | #7 |
Rep 28
Drives: F10 525d
You really should use a headlamp aimer for this job.
When the headlamps are in auto mode it depends on the angle of the steering wheel, the speed of the car and a couple of other factors how the headlights will turn. Your BMW service center shouldn't use more than 5 minutes to get this right. I don't know any details on how to adjust the headlights. Edit: I don't think the beam width of the individual headlights are adjustable, but the combined beam will be affected. |
11-05-2013, 04:17 PM | #8 |
Rep 2,323
I figure I revive this old thread instead of starting another one. The headlight height screw is a 6mm hex screw, does anyone know what the 2.5mm hex screw does in the center of that 6 mm height adjustment hex screw? I adjusted the 2.5mm by accident, but I counted the turns and I think I got it back to its original position.
