2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Engine went into a stall during cold start
      10-03-2011, 08:40 PM   #1
RR80
RR80's Avatar
17
Drives: F10 535i
This morning when I start my engine the rev goes up and down for 5 sec then the engine went into a stall with no code. I restart the car and the rev goes up a little bit than everything go fine. It happen once awhile when the car is cold...! I already let the BMW service guy check but he said he can't do anything with no code. Anyone have any idea of what problem?
PS. mine is a 535i
      11-17-2011, 09:59 AM   #2
vdubturbo
Drives: E90, E36, 997
PS. mine is a 535i
Mine does the same thing from time to time, but it doesn't stall. I thought it was awfully odd for a brand new 5-series to have a bouncy cold-start idle. I haven't taken it in, yet.
      11-17-2011, 11:47 AM   #3
ibimmer954
Drives: '23 i4 M50, '15 M3, '18 911
I had that issue in my 535i for the first time last week. I have the 6MT. Cold start the 535i, clutch in, shifter in neutral... and it stalls out after about 5 seconds. Start it again, stalls out in about 5 seconds. After starting again, I gave it more gas and I was able to get going. Weird. But it only happened that one time.
It's not like I live in a cold climate or anything.
      11-17-2011, 12:22 PM   #4
AlexK
Uzbekistan
Drives: 2012 X5d, 2013 C63
Potential repeat of HPFP issues (the one the 3-series used to have)?
      11-17-2011, 12:55 PM   #5
SomeRandomer123
SomeRandomer123's Avatar
England
307
Drives: F30 328i Luxury - Sport Auto
Well its the same engine isn't it... N55 is still very prone to HPFP failures.
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      11-17-2011, 07:40 PM   #6
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
No.
It's pretty repeatable and only happens in certain patterns. No HPFP issues.
      11-18-2011, 12:26 AM   #7
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
Mine takes longer to crank in the morning when its cold. But cold where I am is 40-50, nothing below. I hope its not an HPFP issue.
      11-18-2011, 12:48 AM   #8
raleedy
Drives: 2016 228i 6-speed
Who has actual evidence of HPFP issues with the F10? I've seen nothing of the kind.
      01-10-2017, 03:34 PM   #9
gerbs
woof
gerbs's Avatar
Drives: M6
So sorry to hit this thread again but I am having the exact same issue on my 2014 F10 550i. Did they ever fix it? What was the resolution?
Thanks
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      01-10-2017, 06:29 PM   #10
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Thanks
The bouncy idle is most likely the engine management software dropping into a routine to prevent the stall.
At some point, the predicted RPM thresholds are determined to be too low for continued operation, so the system calls another routine to stop the engine before the stall. This prevents hiccups like detonation.
Since the engine properly responded to the termination routines, no diagnostic codes are generated.
While no codes are left, the engine logs (accessible by BMW) may have some artifacts.
Now, if this same condition persisted multiple times, then you might see some codes.
      01-10-2017, 07:31 PM   #11
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I have experienced that, but only after i had the cold start deleted. There are no codes, but since the hpfp is a free-bee might as well see if that helps. Not likely, but fuel delivery when cold is suspect. Ive also noticed if i keep the rev to about 800-1000rpm for about 20-30 seconds before i take off the stall never happens. The warm up theroy.
Maybe your cold start is not working as intended??
IG: @bmwdoubles
      01-10-2017, 09:41 PM   #12
top ramen
Drives: Schwarz II 535i
I had this happen to me last weekend when the temperature drops below freezing at night. Wierd thing is that my car was in the garage and when I went to startup the car up in the morning and it wouldn't crank. Battery discharge came on so I turned off the car and tried a few minutes later. On the 4th try the car finally cranked over. Google around found that this happens a lot when the temps drops below freezing. Went on amazon and purchased a CTEK battery charger/trickle charger with recondition from amazon prime and got it the next day. I would recommend every member to get one for the winter.
I also found a technical service bulletin(tsb) on the issue. Just to let everyone know, tsb is not a recall but a issue that BMW knows about and trying to find a resolution for it. Here's a link to the tsb with the service bulletin number and summary.
https://www.automd.com/tsb/bulletin_b359772/
      01-13-2017, 04:12 PM   #13
Panos5
Drives: F10 535i
http://f10.5post.com/forums/showthre...ghlight=recall
There is a recall of the fuel pump as of Oct 2016 on certain 2011-2012 535 models and the symptom can be a stalling engine. There is not yet a solution issued. I've heard this means the redesigned pump has not reached dealers in the US yet. Keep an eye here to check if you qualify and for recall status:
http://www.bmwusa.com/standard/conte...tyrecalls.aspx
