2010 2011 BMW 5 Series Forum F10 M5 style 345 wheels on an F10 528i? |
08-07-2012, 12:39 PM | #1 |
Rep 21
Hello all, I have not posted anything in a long time. My 528i just got rear ended pretty bad 4 weeks ago and I decided to pull the trigger and start the mods. I ordered the M-sport kit and the body shop is currently installing and painting, by the end of the week I should have my car. I am planning to buy the new M5 345 style wheels for my car but I am not sure if it will fit.
M5 345 Specs: Front alloy wheels: 19x9" ET32 Wheel part number: BMW 36112284250 Rear alloy wheels: 19x10" ET34 Wheel part number: BMW 36112284251 Current set up: V Spoke (Style 328) 18 x 8.0 light alloy wheels, 245/45 run-flat1 performance tires, with offset 30 all around I believe. Any help is appreciated, I have been very depressed without my car for a month so I am looking to have it reborn!!!! Please please help!!!! Last edited by F10aljay; 08-07-2012 at 12:48 PM.. |
08-07-2012, 12:54 PM | #3 |
Rep 937
They should fit fine. Pretty similar to offsets on the same size wheels I just ordered this morning. Rear offsets are a little lower than what I orders so the fitment will be a little more aggressive but should be fine.
I ordered +30 to +35 in front (Forgestar is going to spec based on my car) and the rears are +38 with the same size wheels as what you are looking at. |
08-07-2012, 01:12 PM | #4 |
Rep 21
I just want to know for sure because one dealer I called already told me that it will not work, sorry I do not know anything about offsets and what wheels / tyres should fit and not fit, thanks for the help...
08-07-2012, 01:42 PM | #5 |
Rep 4,721
btw, they are made by BBS.
Any idea how much is Tischer is quoting for a set ? I got quote last week from another online BMW dealer and it was $2230 for a set + shipping (using USPS). |
08-07-2012, 01:50 PM | #6 | |
Rep 21
What's your car and do you know if it fits your car? I want to lower it later using KW V1s or V2s. |
Enpethan9.50 |
08-07-2012, 01:56 PM | #7 |
Rep 4,721
I was just doing researches into oem wheels & aftermarket ones. I have 550.
08-07-2012, 02:18 PM | #8 | |
Rep 21
08-07-2012, 02:42 PM | #9 |
Rep 29,202
Take a look here, pics of the 20" M5 343M wheels fitted, same rear offset as the 19" 345M.
http://f10.5post.com/forums/showthread.php?t=693143 I know the front 19x9 ET32 will fit, cause this F11 has the 408M, and that's also 19x9 et32, with 255/40/19 tires. http://f10.5post.com/forums/showthre...=657121&page=2
08-07-2012, 04:26 PM | #10 | |
Rep 21
08-07-2012, 06:01 PM | #11 |
Rep 29,202
If you go with 275/35/19 in the rear, I really doubt you will rub.
Here's a thread with some pics of a F10 with OEM 19" 351M wheels running 18mm spacers all around and dropped on H&R sport springs. That's makes it 19x9 ET26 275/35/19 in the rear. http://f10.5post.com/forums/showthre...mm+351m&page=2
08-07-2012, 06:41 PM | #12 |
Rep 4,721
One thing I would like to point out is the poster with F10 528 M style 350 wheels to begin with
They are f: 18 * 8 et 30 r: 18 * 9 et 44 Therefore, when they switch over to the M5 343M wheels, f: 20 * 9 et 34 r: 20*10 et 34 The calc. shows f: -17mm clearance from strut/+9mm extension of wheel outward. r: -3mm clearance from strut/+23mm extension of wheel outward. As for the 345M wheels, f: 19 * 9 et 32; r: 19 * 10 et 34 The calc. shows f: -15mm clearance from strut/+11mm extension of wheel outward. r: -3mm clearance from strut/+23mm extension of wheel outward. Last edited by bobblehead; 08-07-2012 at 06:52 PM.. |
08-07-2012, 11:13 PM | #13 |
eM Power Me
748
Rep 698
Drives: '23 AW i4 eDrive40 M Sport
You shouldn't have an issue given those specs. My BBS CH-Rs are slightly more agressive in offset and I haven't had any issues.
Will -
'23 Alpine White G26 ///i4 eDrive40 M Sport '23 Brooklyn Grey G20 ///330e M Sport '20 Alpine White F97 ///X3MC '20 Alpine White F39 ///X2 M Sport X |
08-08-2012, 04:17 AM | #14 | |
Rep 21
08-08-2012, 10:58 AM | #15 | |
eM Power Me
748
Rep 698
The car is lowered on H&R springs at the moment which lowers it about 1.4" and has no issues at all. I do wish the springs lowered it a bit more, but its still very noticable better than stock. I do plan on replacing the springs with KW V3's sooner than later though.
Will -
08-08-2012, 08:09 PM | #16 | |
Rep 21
I called a local Americas Tire since they offer good warranty and free repairs. They recommended these tire sizes for my 345 M style rims on my F10 528i, F: 245/40/19 and R: 275/35/19. The OEM fitment on an M5 is F:265/40/19 and R: 295/35/19. What do you think about their recommendations? The guy recommended Hankook Ventus Evos as a good all rounder tire since the Michelin PSPs don't last too long. I told him that I am very particular with quality, good handling, quite road noise, and long lasting. I don't care much about pricing as long as they are worth it. |
08-08-2012, 09:31 PM | #17 | |
eM Power Me
748
Rep 698
Tire size recommendation is fine, but I prefer a 285/30R19 on the rear as my rear is a 10.5.
Will -
08-08-2012, 09:37 PM | #18 |
Rep 937
For the same size wheels, I just ordered 245/40/19s and 285/35/19s, same Hankooks. Going with the 285s should make my speedometer read more accurately, and also will make the rears ever so slightly taller than the fronts. For 275/35/19s I've looked at, the 245/40/19s are taller.
08-09-2012, 05:02 AM | #19 |
Rep 29,202
You basicly have three choices,
1. 245/40/19 + 275/35/19 2. 245/40/19 + 285/35/19 3. 255/40/19 + 285/35/19 I'd probably do 1 or 3.
08-23-2012, 08:32 PM | #20 |
Rep 21
Finally installed
Finally got some stuff done, installed M-sport kit and the M345 wheels, still waiting for my M5 grills cause it's on back order. Am running 245/40/19 Michelin PSS on 19 x 9 in the fronts and 275/35/19 Michelin PSS on 19 x 10 in the rears.
I want to thank everybody: Evan at Tischer, Remmib, Will Pwr, bobblehead, snj1013, your help was very appreciated and I am so happy with my car. My car was in the shop for 6 weeks from a hit and run and I almost pulled the trigger on a Panamera 4 because I was going nuts waiting, so glad I did not - I am totally in love with my car again. Sorry for the low quality iphone pics, I am going to save up for some KW V1s in the near future. Any input on the KW V1s? I know most people will recommend V2 or V3s but the reality is I will put it on will not mess with it or track it. Just want a more stable / sporty drive aside from the sport suspension. |
08-24-2012, 05:43 AM | #22 |
Rep 29,202
Those turned out great on your car.
