12-11-2019, 03:23 PM | #1 |
Rep 33
Eibach Lowering Spring
I can't seem to find Eibach Pro-kit lowering spring for my 2016 535D. Can I use lowering spring from 535i to fit 535D? Is it the same lowering height for 535i and 535D when using Eibach spring from 535i?
01-18-2020, 09:41 PM | #2 |
Rep 658
No sir. Your diesel engine is significantly heavier than the non-diesels. If you were to put 535i springs on your car, the front end would squat much lower than the springs were designed to ride. I think it would be easier to compensate for this with a quality set of coilovers, rather than non-diesel springs. Hope that helps
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
