2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tires Size with 20's
      09-28-2016, 12:40 AM   #23
ENDY03
Drives: 2009 BMW M3 E92 White
Hi guys,
I know its an old thread, but its in the same topic so might as well.
Will I have any issues if I run 255/40/20 & 295/35/20 set? Please advise. Thanks!
      09-28-2016, 05:05 AM   #24
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
no issues on mine......except slight rubbing on the rear with a fullload ie. 3 passengers in the back and load in the boot
I got a set of 20" vorsteiners.
9 at the front 10.5 at the rear
and am running that set up on stock suspension.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      09-28-2016, 09:03 AM   #25
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Hasser, did you realise that the OP was asking for advice with higher profile tires? 255/40-20 front and 295/35-20 rear.
I think you run 255/35 and 295/30?!
      09-28-2016, 09:10 AM   #26
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
255/40 and 295/35 are possible on F10 but the wheel offsets, are crucial, especially the front. Or else the front tires will rub.
This photo show 255/40-20 on 8.5x20" wheels with ET32, less than 1/10" clearance with the car on the lift and rubs with the weight on the wheels.
The front offset needs to be around 25-27, lower and the tire will rub the fender liner and higher the tire will rub the steering knuckle.
295/35-20 rear will probably fit, but I wouldn't use wider wheels than 10" and offset close to 40 or maybe a few millimeters lower.
Don't take decision only based on my advice, I use a square 255/40 setup not staggered with 295 rear tires. Also remember that these tires are about 5% taller than OEM sizes.
      09-28-2016, 09:47 AM   #27
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Oh yeah. Good point. Missed that slight technicality
2014 M5
1999 E38 728i -sold
M235i - sold
      09-28-2016, 10:46 AM   #28
PJinCA
USAF Pararescue Veteran
Drives: F10 535
my question about that tire size would be: wouldn't that affect the speedometer? that would be outside the typical 3% of oem diameter, isn't it?
I run the following sizes:
front: 20x8.5 with 245/35/20, et 19
rear: 20x10.5 with 295/30/20, et 35
      09-28-2016, 11:17 AM   #29
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Yes these tire sizes affects the speedo, but to the better.
With OEM sizes the speedo show about 2 mph higher than actual speed at 60, with 255/40-20 the error will be less than 1 mph (on the lower side).
remmib1567.50
      09-28-2016, 11:27 AM   #30
5eries619
Drives: 528i x drive
a little off topic here but I need some education. I ordered a set of rims and obviously I took the advice of the "professional" but why 30 wall in the rear and 35 in the front? I haven't dropped my car yet but I kinda thought after I installed them that more rubber would have reduced the gap.
any reasoning behind this?? thanks
front 245/35/20
rear 285/30/20
      09-28-2016, 11:37 AM   #31
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
First number is section width in millimeters, the second number is side wall height in percent of section width.
I.e.
245 x 0.35 ~ 86 mm
285 x 0.30 ~ 86 mm
      09-28-2016, 10:16 PM   #32
xxpanipuri
Drives: 550i
that should work just fine. depending on offsets you may even be able to go 255 and 295 Michelin PSS
thats what i did f/r, no rubbing at all
      09-30-2016, 10:36 AM   #33
007F10
007F10's Avatar
63
Drives: 13' 535i Msport AW
Originally Posted by ENDY03 View Post
Hi guys,
I think that might be a little tall but I am running 255/35/20 and 295/30/20 on OEM 303m with ACS springs. Math says it is 1.3 percent larger then stock size if I'm not mistaken but, No issues what so ever. fills some of the gap that was left. I love it and plan on running the same when I need to.
Kumho ecsta ps91 btw
2013 535i Msport
RIP: '95 E36 M3 | '90 E30 325is | '87 E30 318i
      11-28-2016, 11:44 AM   #34
Thieutje
24FITcoach
Thieutje's Avatar
Belgium
32
Drives: BMW F11 M550xd
What is the width of the rims if i may ask please?
      08-26-2019, 11:07 AM   #35
clone000
Drives: F10 | N20
Hi guys,
Ditto here. I want to run 245 / 40 in the front and 285 / 35 in the rear.
is the Ratios ok 40 front and 35 rear?
2013 M Sport 528i
- HM Style Carbon Fiber Front Lip | Dual Slat Gloss Grill w/ M colors |H&R Front / Rear Sways |Downpipe (Catless) | Afe Intake
      10-17-2019, 10:49 AM   #36
aikhan4
Drives: 2011 BMW F10
Running 285/35 on my vossen cv5 lowered on Megan Coilovers, no issues
      10-18-2019, 07:16 AM   #37
Proimport
Drives: 2014 BMW 535i
I'm running 255/285
      10-26-2019, 12:43 AM   #38
maurer
maurer's Avatar
Croatia
Drives: BMW F10 2013
Hi,
I am interesting for JR21 wheels. Which rims and tyre dimension (front and back) would you suggest for my BMW 5 F10 (non M version, 525d) ?
It would be great if will fit 20x10 front and 20x11 rear
https://jr-wheels.com//towar.4797.ja....5x120.hb.html
Thank you.
      10-28-2019, 12:03 PM   #39
docjavier
docjavier's Avatar
Spain
1108
Drives: G80 M3 F10 535i
Originally Posted by Proimport View Post
I'm running 255/285
I run this same set up on Forgestar F14 20" super concave w Michelin Pilot 4S lowered on KW no rubbing.
2023 G80 M3 C/XD SMB, 2012 F10 535i M-Sport, BM3 stage 2. 2014 Porsche Cayenne GTS.
      10-30-2019, 11:17 AM   #40
5fifty
Drives: BMW 550i Alpine White,
Vertini Light Brushed Bronze
I am running 20x9 and 20x10.5 with Michelin Pilot Sport
255/35-20 and 295/30-20
No rubbing, Stance looks amazing with Dinan Springs and Ride Handling
      10-30-2019, 07:09 PM   #41
NaviCG
NaviCG's Avatar
Drives: 550i
Any chance you can post a pic? Not the entire car... just wanted to see the clearance with your wheel/tires set up with the Dinan Springs, which I know are supposed to be a .5 inch drop. Looking to get 20’s as well. Thanks in advance.
      10-30-2019, 08:27 PM   #42
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
Running 255 + 295.
      11-03-2019, 02:22 PM   #43
Luky
Luky's Avatar
Drives: 2016 550i M Sport
I'm running 255/285
What width and offset are your front wheels? Are they flush? I'm trying to decide between 20x9 et20 and 20x9 et35 with 255/35-20 tires in a square set up. I think both will fit, just dont know how flush the et20 would be...
      11-29-2019, 03:15 AM   #44
maurer
maurer's Avatar
Croatia
Hi, this is the problem with my choice of wheels, because I am scared if will not fit well.
Could you tell me parameters for 20x10 wheels?
ET? Tyre dimensions? etc.?
Thank you.
