2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Factory 19in Xdrive setup for F11?
      01-11-2018, 03:20 AM   #1
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Hi,
Cant seem to nail this one definitively and need advice.
For winter I have 18x8 ET33 all around. Tyres are 245-45-18.
I also own a set of 245-40 R19 Michelin pilot sport tyres. What 19in rims are supposed to be a square fit that matches factory xdrive fit?
I heard it is 19x8.5 ET 33 or would it still be 19x8 ET 33? Please help me clarify this. Wanna buy the 8.5 rim ET 33 for a square setup but not sure if this is correct and inline with factory settings.
Dont want to go staggered on my car as not in specs per 19in wheel sizes to the best of my knowledge.
Bad experience here also fitting breyton GTS 20x8 ET 35 over brand new brakes. Not enough clearance. Had to sell em, not a fan of spacers.
EDIT: Answer confirmed: 19x8.5 ET33, and 245-40 R19 tyres.
F30.F11.E86.E90.E90.E36
      01-11-2018, 10:18 AM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Originally Posted by Tallest View Post
Hi,
Square OEM 19" fitment on the f10/11 is 19x8.5 ET33.
      01-11-2018, 02:00 PM   #3
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Thank you! Will 245-40 19 tyre be a good fit close to OEM?
      01-11-2018, 02:25 PM   #4
remmib
remmib's Avatar
Norway
1568
Yes, 245/40/19 is the OEM size for the 19x8.5 wheels.
      01-11-2018, 03:27 PM   #5
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
      01-23-2018, 02:18 AM   #6
Techgeek80s
Drives: 2013 silver 535xi
I have 2013 msport how do i kmow of my rims are staggered all my tires are the same size. BMW are idiots I give them the vin and still can’t give me answers
      01-23-2018, 04:13 AM   #7
BMW Collector
Drives: 535
X Drives are usually unstaggered. Rim sizes are stamped inside of the rims.
      01-24-2018, 05:53 PM   #8
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Usually is the key word here. The M550d is staggered and 4wd. Go figure. So are the X5 and X6 models which are 4wd and take factory staggered setup. But 5 seires - only M550d is staggered to the best of my knowledge.
Too bad for you, mine since confirmed also the 8.5x19 ET33 and 245-40-19 Tyre.
      01-29-2018, 02:02 AM   #9
Techgeek80s
Hi,
Why are you not a fan of spacers just out of curiosity
      02-07-2018, 03:26 PM   #10
Walt White Coupe
Walt White Coupe's Avatar
221
Drives: 2013 650ix Coupe, 23 C8 Vette
If all your tires are the same size then you have a "square" setup. It's that simple.
      02-11-2018, 11:48 AM   #11
hichamaziz
Drives: my car is best
thank you for thread
      02-13-2018, 03:21 AM   #12
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Because of the extra pressure it adds on the hubs and because I dont feel comfortable putting one rim on top of some non OEM made component that I have no idea where it comes from. Its just me. I can put a taiwan produced plastic grilles, but when it comes to brakes, tyres, etc, I like to stick with OEM. BMW never puts spacers on stock cars.... There are other schools of thought on this, like if you drive daily it doesnt matter. But why add extra weight and risk some bolts snapping... Also, where I live winters are bad, so all the salt, corrosion there.. just not for me.
      02-16-2018, 01:36 PM   #13
Techgeek80s
I was gonna go with 20 by 10 all the way around bout wanted a LI more pole on the tears so was just gonna Tun spacers on the back
      02-16-2018, 01:37 PM   #14
Techgeek80s
Very good points and I’m from Jersey so winters are bad here too. Thought I had decided on my wheels tire setup by this throws me off
      02-17-2018, 07:43 AM   #15
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
As a M550D owner of 4 years, I can say that they come with square 18"/19"/20" as stock, but there is a staggered option in 20" running 245/275 tires.
Mine has square 19" 245 setup, but I will get staggered 20" this year.
However, any x-drive F10/11 should be able to run the same staggered set.
      02-17-2018, 01:39 PM   #16
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Ah, ok, hear you. Well, alright but on mine the staggered is never an option...
      02-20-2018, 09:13 AM   #17
Noggie
Noggie's Avatar
Norway
285
There is only a couple of wheel designs that are available as staggered.
The style 434 and 356 comes as 8,5x20 et 33, and 9x20 et 44, the style 610 comes with same spec in 19".
All other 19" and 20" are square.
Though 0,5" difference front and rear can hardly be called staggered
Also the offset looks weird. The square setup is 8,5" et33mm all round.
But the 9" staggered one is 44mm.
0,5" wider wheel is 12,5mm wider, if it had remained at 33mm it would have "poked out" 6mm more than the square setup.
But then BMW change the offset to 44mm, moving the wheel inwards 11mm.
Essentially making the staggered rear wheel sit 5mm further in than the square one.
