2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA Hong Kong 528i m sport
      11-30-2012, 11:16 AM   #1
ks1117
Hong Kong
Drives: M
Hi, everyone mine comes with a m sport 18" rim, wanted to change 19". For the org. 19' m sport, can I get it not from the hk dealer???? Any recommendation???
thank you
      12-02-2012, 10:52 PM   #2
AC_S5
AC_S5's Avatar
9
Drives: 2011 F10 523i
the 19 doesn't make a huge difference in terms of looks. Opt for 20 if you are going to swap out.
2011 F10 - Sophisto Grey / Cinnamon Brown
You can find me in E60.net too!
Gone (but not forgotten)
2005 E60 523i, 1999 E39 523i, 1998 E46 323i
      12-03-2012, 09:49 AM   #3
ks1117
Hong Kong
Drives: M
but I like the org. m sport rim, and together with the tire, 20" is really expensive......
      12-03-2012, 09:00 PM   #4
RR80
RR80's Avatar
17
Drives: F10 535i
The Msport 19" might cost more than aftermarket 20"... and the price for the 20" tries went cheaper lately.
2003 E60 530i - PSS9 Coilover/M Kit/BBS GT-RS 19" wheels - retired
2006 E91 335i - Procede V5/Forge DV & FMIC/Bastuck quad exhaust/P1 Steering Wheel/Sachs Coilover/M kit/19" RS wheels - retired
2011 F10 535i - Stock
      12-04-2012, 12:30 AM   #5
AC_S5
AC_S5's Avatar
9
Getting new wheels is never cheap.
You may regret not getting bigger, look wise it doesn't have a real striking effect.
      12-04-2012, 02:37 AM   #6
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
19" and 20" tires have very little difference in terms of cost. Some brands even cost the same.
If you like OE style then the M sport rim is a good choice. But they weight more than most aftermarket rims. It's your choice. 20" is the minimum size for swapping, if I swap now I might even go for 21".
Try Wah Kee at Gloucester Road for the price of the M sport wheel.
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      12-04-2012, 09:58 AM   #7
ks1117
Hong Kong
Drives: M
hey, thanks for the info, just checked the price for OEM msport 351M, cost hkd4xxxx, w/ tire
anyway, is MK kwok wa ok??? the one across of MK police station.
thanks again
      12-04-2012, 11:03 AM   #8
BigP535I
Cambodia
18
Drives: F10 AW Mtech
why dont you check out classified, I see folks selling them for $1500 US or less, another couple hundred bucks for shipping to hk should save you more then half.
      12-04-2012, 11:08 AM   #9
ks1117
Hong Kong
Drives: M
thanks for the advice, but anyway, buying these heavy stuff oversea makes me worry, what if the rim is not nice enough and have problem? shipping these stuff back is not worth.
I only had experience buying some items oversea.
anyway, thanks again for the advice
      12-04-2012, 11:16 AM   #10
BigP535I
Cambodia
18
ok, well I seen some for sale that were taken off the car as soon as it was bought but again thats something you have take the sellers word for it, knowing the crowd here I would tend to believe it
      12-04-2012, 07:15 PM   #11
RR80
RR80's Avatar
17
Drives: F10 535i
thanks again
kwok wah kei, he is good! Me and my friends get wheels there before!
      12-04-2012, 08:19 PM   #12
AC_S5
AC_S5's Avatar
9
thanks again
Some stuff at Kwok Wa is expensive, but they are reliable and no shady stuff but need to compare prices. Otherwise Wa Kee is also a good choice.
4xxxx for OEM 19" sounds right, but for that price can buy a set of 20" wheels.
But if you really like the look of OEM wheels and not care about the performance like RC, go for it.
I got the 351M and i am perfectly happy with it.
      12-04-2012, 08:35 PM   #13
mlai
mlai's Avatar
Hong Kong
168
Drives: 650GC/E93M3/Lexus LS600HL
thanks again
That's about the right price, depending on the tires....
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      12-06-2012, 01:45 AM   #14
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Bro, are your referring me? My wheels are actually lighter than the OEM since they are flow formed. But the wider tires may suffer a bit on acceleration and fuel, not sure since I have not record them. Handling and cornering much better though.
      12-06-2012, 01:50 AM   #15
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
thanks again
$40K? Should get aftermarket IMO. Mine cost $30ish back then, may raise now.
Tires x 4 should cost $15K or so, ultra performance like PSS, Pzero.
      12-06-2012, 08:06 PM   #16
AC_S5
AC_S5's Avatar
9
You run 275 in the back wheels right?
If so the 351M runs the same setup so performance wise will still choose your wheel over the OEM wheels.
      12-06-2012, 09:46 PM   #17
ks1117
Hong Kong
Drives: M
and I have another question, if we change the rim, is the tire pressure monitor still working??? is there any sensor needed to be installed in the tire or rim???
thank you
      12-06-2012, 10:09 PM   #18
AC_S5
AC_S5's Avatar
9
and I have another question,if we change the rim, is the tire pressure monitor still working??? is there any sensor needed to be installed in the tire or rim???
thank you
We don't have the Tire Pressure Monitor Sensor in the wheel like the ones in USA.
After swapping wheels or changing tires, just reset your flat tyre monitor and you are all set
      12-07-2012, 09:24 AM   #19
ks1117
Hong Kong
Drives: M
oh, thanks for the explanation, thank you.
      12-07-2012, 10:23 AM   #20
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
255 front and 285 rear, sort of the same.
      02-04-2013, 03:30 AM   #21
bm1318
Drives: bmw
you can order the OEM M351 from BMWHK via your garage at a lower price.
