2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 535i Stock Exhaust Tip Size
      01-01-2013, 01:47 AM   #1
hufington
hufington's Avatar
3117
Drives: 2022 X5 m50i
Does anyone know the diameter of the stock 535i exhaust tip? Thanks.
2022 BMW X5 m50i
2024 MB S63 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
      01-01-2013, 12:55 PM   #2
Mr. Grumpy
BMW Enthusiast
Mr. Grumpy's Avatar
Drives: 2022 X5
3"
2022 X5 sDrive 40i Carbon Black | Ivory White Vernasca Leather | Aluminum Tetragon Trim | ZMP | ZPP | ZLS | ZPK | 337 | 4NB | 3M2 | 4HB | 7M9 | Black Kidney Grills |
      01-01-2013, 01:29 PM   #3
hufington
hufington's Avatar
3117
Thanks. Are they welded or clamped on? My car is still 25 days away but I am trying to figure out what I can do with the tips.
2022 BMW X5 m50i
      01-01-2013, 02:39 PM   #4
VWtoBMW
VWtoBMW's Avatar
Drives: 2021 X5
They are clamped/screwed on
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black
      01-01-2013, 09:39 PM   #5
Sharbotcom
Sharbotcom's Avatar
Drives: 2011 535xi M Sport
They are 3" with a 2 1/4" inlet. They are welded on not clamped.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
      01-01-2013, 10:03 PM   #6
hufington
hufington's Avatar
3117
I will start looking for some larger (4"-5") chrom tips with 2 1/4" inlet that can be welded. I don't want any added noise and will go for cosmetic change only.
2022 BMW X5 m50i
      01-01-2013, 10:05 PM   #7
Sharbotcom
Sharbotcom's Avatar
Have you considered going quad tip? A lot of the guys have done that with great results (me included see: http://f10.5post.com/forums/showthread.php?t=685790).
      01-01-2013, 10:13 PM   #8
hufington
hufington's Avatar
3117
Quads look awesome, but I don't know any good shops here in NJ, that can install quads and cut the diffuser perfectly.
2022 BMW X5 m50i
      01-02-2013, 04:36 PM   #9
Mr. Grumpy
BMW Enthusiast
Mr. Grumpy's Avatar
Drives: 2022 X5
Please keep us informed on this mod. I've been thinking of switching to a 4" Crome tips and replacing the center silencer (resonator) for a cross pipe for a better exhaust sound.
      01-02-2013, 04:44 PM   #10
hufington
hufington's Avatar
3117
Will do.
2022 BMW X5 m50i
      01-03-2013, 12:36 PM   #11
2005x
Drives: 2005 X5
I believe you can get the 550 Diffuser(which has a bigger opening)and you won't need to cut anything(all depending of course on the size of the tips you get). anything over 4" would look ridiculous on a stock 5 series. Also you can get the m5 diffuser but then you will need to modify the mufflers and possibly move them back as the tips will stick out to much. Do keep in mind the length of the tips, as most aftermarket tips are way longer than factory.
      01-03-2013, 12:39 PM   #12
Sharbotcom
Sharbotcom's Avatar
From what I remember the diffuser only works with msport bumpers. So if the OP has msport he is good to go otherwise I think you need to cut or change the bumper. Someone please correct ot verify my statement.
      01-03-2013, 02:46 PM   #13
Mr. Grumpy
BMW Enthusiast
Mr. Grumpy's Avatar
Drives: 2022 X5
You are correct, the only way to change the diffuser is if you have the M-sport package. Judging by the op's avatar picture it looks like he doesn't have that option.
      01-03-2013, 03:26 PM   #14
hufington
hufington's Avatar
3117
How about the standard 550 non-Msport diffuser? How wide is the opening for the oval standard tips?
2022 BMW X5 m50i
      01-03-2013, 03:41 PM   #15
Mr. Grumpy
BMW Enthusiast
Mr. Grumpy's Avatar
Drives: 2022 X5
IMHO if you're going to spend money buying the 550 rear bumper might as well buy the M-sport so you can change diffusers when ever you want to. For what I've seen the 550 bumper can accommodate a dual exhaust tips with no problem but I don't know the dimensions for the exhaust opening.
      01-03-2013, 04:02 PM   #16
hufington
hufington's Avatar
3117
Logical. As much as I love the front bumper design, I am not a fan of the rear M-Sport bumper though. That's why I am trying to find a way around it.
And i have just seen the eisenmann double 102mm (4") exhaust setup online and the single 4" tips on each side looked too bulky. Maybe because it was a touring.
2022 BMW X5 m50i
      04-29-2013, 03:34 AM   #17
shihwei
Drives: F10 520d
Can someone please help me verify whether F10 exhaust tips are clamped/screwed on or welded on? I got confused by the discussion in this thread. (and according to realoem, 535i looks like it has slip on tips.) Also anyone know where I can find inlet diameters to all other F10 models? Thanks in advance.
      04-29-2013, 10:14 AM   #18
Mr. Grumpy
BMW Enthusiast
Mr. Grumpy's Avatar
Drives: 2022 X5
It depends on the model. The 550i are welded, the 535i are slip on. On the 520d it looks like it might be slip on's.
I removed the tips on my 535 by twisting it and the pulling it, they're only secure by 3 pressure clamps.
      04-29-2013, 10:55 AM   #19
hufington
hufington's Avatar
3117
Do you know the length of the tips?
2022 BMW X5 m50i
      04-29-2013, 06:40 PM   #20
Sharbotcom
Sharbotcom's Avatar
Let's make sure we are talking apples and apples. The exhaust tips (covers) are clipped on to the tail pipes (slides over) on the 535 but the tail pipes are welded on to the muffler. So if you are going to replace the singles with doubles you will need to cut the tail pipes off and weld the dual tips on. If you were swapping the chrome (or black) tips (covers) then they can be twisted on and off.
