2010 2011 BMW 5 Series Forum F10 F90 M5 Vent Style Front Bumper Conversion(Updates pg3) |
01-28-2020, 07:42 PM | #89 |
Rep 2,416
im torn apart do i do this also or stay the way i am haha
2011 550i RWD 60-130 7.35
lsturbointeg9166.50 |
01-28-2020, 11:22 PM | #90 |
Rep 14,521
Looks badass bro!!!
01-28-2020, 11:23 PM | #91 |
Rep 14,521
I have my car in Instagram and it gets a lot of compliments and praises!
01-29-2020, 10:12 AM | #92 | |
Rep 2,595
You rattle canned a whole bumper? Holy crap your poor poor index finger
2015 BMW 535xi
01-29-2020, 10:57 AM | #93 | |
Rep 534
PDC The bumper has indents on the backside for PDC sensors, it was pretty easy to find and drill out. I used a stepped drill bit the size was 18mm for the sensor holes. If I were to do it again I would order the PDC sensor bunch as I found the Drill bit to be a little bit of a hassle. Also my stepped bit ended at 20mm so I was concerned about making the whole too large accidentally. Painting There are plenty of instructions on how to paint plastic parts online so I won't bore you with the process but I'll drop the materials i used below if anyone wants to tackle this job on their own. I painted the front and rear bumpers of my car (PO had the rear bumper refinished due to a shopping cart incident but the shop painted it BSM instead of Jet Black. Subtle difference but noticeable to the trained eye.) so I had to order quite a bit more product but I would say the split is something like 45/50 F/R in terms of product needs. Paint 12oz Sandable Acrylic Lacquer Primer - Black (3) 12oz Aerosol Spray Paint - Jet Black 668 (5) Sp*****x 2k Urethane Clear Coat (3) Misc Materials Grey Scuff Pad 1000 grit sand paper Tack Rags Plastic Drop Cloths My work area was a little dirty for painting and i sprayed at a little bit colder of temp than recommended but all in all i'm happy with the results. I'll probably compound and polish the bumpers this weekend but all in all I was happy with the minimal orange peel after the paint cured for 24hrs.
Frozen Black Widebody E92 : VRSF CP, N54Tuning Downpipes, Tial BOV, DCI, MHD Flash, Aquamist HSF-3 Meth kit Dual Nozzle, Megan Racing Toe Arms,Megan Racing Camber Arm, Megan Racing Trailing Arm, IND Delrin Subframe Bushings, M3 Control Arms,Fortune 500 Series Coilovers, Square 18x11 Apex Ec7 w/ 315/30/18 Hoosier R7's
01-29-2020, 08:27 PM | #94 | |
Rep 5,399
02-10-2020, 10:54 AM | #95 |
Rep 232
the new front bumper conversion looks insane.. really like it.. only if you can upgrade the front mount intercooler so it can show more...
13'- F10--> Work in progress: V-Style front lip, HAMANN roof spoiler, M5 grill, high kick trunk spoiler, H&R sport springs, C-quence Drilled front rotors, VRSF Catless DP, VRSF charge pipe.
02-10-2020, 06:03 PM | #96 |
Rep 14,521
I think our radiator since in front of the IC I believe?
05-04-2020, 10:15 PM | #97 |
Rep 174
Finally got around to spraying and installing my bumper. A couple of problems that I ran into:
1) Needed to trim 1/8 off of the rubber seal that mates up against the kidney grills 2) Needed to but 1/8 inch off the corners of the physical aluminum bumper bar. Yes. The bumper bar. Crazy stuff. 3) Needed to shave down the bumper at the top 6 torx bolts. For some reason 3 of the holes had a built in step that prevented the bumper from seating properly. The OEM bumper did not have these steps. 4) The new bumper does not have a mounting surface to screw in the lowest screw of the fender liner. Strange. 5) The foam bumper bar insert did not fit the bumper... AT ALL! It's twice as thick as it should be. I tried trimming it, no dice. With all this being said, the fit to the fenders, headights, and hood is is 9.0/10. Not bad for an aftermarket bumper. Photo:
Monaco Blue E92 // BMS JB4 G5 ISO // BMS Backend Flash // Dual Cone Intake // ER Chargepipe // Dual HKS SSQV BOV Setup // BMW Performance Spoiler // 19" v710 Dolphin Grey // Aero Front Lip // M3 Sideskirts // Mtech Rear Bumper // Quad Tip Diffuser // Quad Exhaust // |
05-05-2020, 12:11 AM | #98 | |
Rep 14,521
2) no issues with mine 3)no issues with the step lip, I don't think mine had that 4)had the same issue but I would have to take a look under to see what I did to remedy that 5) same here, couldn't use the foam bumper support. I did have to remove what looked like an air dam on the bottom left as I couldn't get the bumper to go on with that air dam. Probably could have shaved it but with that big opening I just removed it Agree with the fitment tho. Everything lined up nicely. Other than that your car looks sweet!
05-10-2020, 04:30 PM | #99 | |
Rep 115
05-15-2020, 11:56 PM | #100 | ||
Rep 174
And thanks, yours too Quote:
A few more pics for those who are interested. I think the upgraded iconic style halos are a must with this bumper:
05-16-2020, 08:00 AM | #101 |
Rep 14,521
Did you do this yourself? I'm worried about dissembling the lens and ruining it
08-20-2020, 02:31 PM | #102 |
Rep 1,933
08-27-2020, 06:54 AM | #104 |
Rep 14,521
They are currently out
08-27-2020, 09:06 AM | #105 |
Rep 418
08-29-2020, 07:14 AM | #106 |
Rep 14,521
i paid $400 through a "offer bid"
08-29-2020, 09:00 AM | #107 |
Rep 418
08-29-2020, 11:42 AM | #108 |
Rep 14,521
yup free shipping. i've had guys on Instagram DM that they've been looking for this bumper for a few months now with no luck
08-29-2020, 10:49 PM | #109 |
Rep 418
08-30-2020, 06:39 AM | #110 |
Rep 14,521
you have to send your headlights in for this upgrade. i looked them up. pretty expensive mod i think my quote was around $2k for what the customization i wanted. on the bottom of the mod list
