2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding iDrive Screen Surface Scratched. Is BMW Kidding?
Closed Thread
      04-15-2012, 08:17 AM   #1
NYF32DRIVER
NYF32DRIVER's Avatar
Drives: 2016 428i X Drive
I took a VERY soft microfiber cloth to what I thought was a fingertip smudge yesterday, GENTLY rubbed and ended up with a HUGE SCUFF. I believe it actually removed the Anti-Glare surface !
WHY IS THERE NO protective surface over the iDrive screen as there was in past vehicles ??
What will this screen look like in 3 years ?
This is my 5th BMW with Nav or iDrive and I have NEVER had a scratched screen before.
And NO... I will not place protective film over the screen. This is something BMW needs to address NOW. This screen is WAY too fragile for normal use.
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008
      04-15-2012, 11:15 AM   #2
Needsdecaf
Needsdecaf's Avatar
6589
Drives: 2024 G80 Comp xDrive
Hmm. Maybe a bad screen? Never had an issue myself. Perhaps bring in the car with the cloth you used...
      04-15-2012, 11:15 AM   #3
E90Fleet
South Africa
1312
Never seen this.
Where there any chemicals on the cloth ?
BMW if you are reading, I need a job, Please.
      04-15-2012, 11:38 AM   #4
NYF32DRIVER
Originally Posted by E90Fleet View Post
Never seen this.
No...just damp
      04-15-2012, 11:40 AM   #5
NYF32DRIVER
Originally Posted by NYCE90DRIVER View Post
No...just damp
The thing that disturbs me is that there are many posts about this online and they all say that it needs to be replaced and cannot be fixed.
      04-15-2012, 12:42 PM   #6
the_rangdo
Drives: 528i F11 (2015)
Used MF cloths and damp leathers on mine, no marks
      04-15-2012, 02:01 PM   #7
NYF32DRIVER
OK... that's fine but what I'm saying is that there are MANY posts about this issue so I am NOT the only one.
      04-15-2012, 03:48 PM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
there were couple other threads having the same bad experience with screen scratching ... identical result.
Some went on by putting protected film, like the one used on smartphone or tablet. But then it's too late for some ...
Some tried to address the issue with the dealer to no avail. Not a warranty item.
btw, i did exactly what you did ... but my scratch was at the bottom part of the screen .. hardly noticeable .. lucky for me.
      04-15-2012, 10:53 PM   #9
NYF32DRIVER
So basically you are saying my situation is hopeless... but how about this: The scuff mark which I was trying to remove was not there until I sent the car in for Bodywork at a BMW "Certified Collision Center" and it was returned to me with overspray all over the wood trim on the inside of the cabin.
      04-16-2012, 06:32 AM   #10
bobblehead
bobblehead's Avatar
Drives: warp speed
Not sure it's hopeless. You can bring the issue with your dealer and see what they can do. I remembered a blogger went as far as requesting the entire screen be replaced and the dealer rejected his request without hesitation since it's him that scratch the screen.
Even if your dealer agrees to do something, the question is what & how are they going to remove the scuff mark ? They could do more harm than good. Just my 2 cents.
http://f10.5post.com/forums/showthre...v+screen+scuff
So basically you are saying my situation is hopeless... but how about this: The said mar which I was trying to remove was not there until I sent the car in for Bodywork at a BMW "Certified Collision Center" and it was returned to me with overspray all over the wood trim on the inside of the cabin.
      04-16-2012, 08:20 AM   #11
NYF32DRIVER
Thanks... actually I saw that thread and it made me quite depressed
      04-16-2012, 08:34 AM   #12
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
This thread and others are very worrying. I am not even going to dry wipe my screen with a MF cloth anymore in fear of scratching it. Wtf?
Maybe I will vacuum it from 6 inches away...
      04-16-2012, 08:51 AM   #13
bobblehead
bobblehead's Avatar
Drives: warp speed
I will wipe the screen with mf cloth but I do it as if I was a surgeon doing heart transplant .... lol.
      04-16-2012, 09:08 AM   #14
NYF32DRIVER
The point is the THIS IS A VEHICLE MADE TO BE DRIVEN. The screen is bound to get dusty or grimy and SHOULD NOT BE SO FRAGILE !!
      04-16-2012, 10:15 AM   #15
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Not saying it is acceptable at all. As a matter of fact, it it is as delicate as people are suggesting, it should be replaced. It should be even tougher than a laptop screen due to exposure to the sun, etc. Up until now, I was going to use one of those moist screen wipes to wipe down the screen, and now I am hesitant. My car is 3 months old so haven't had a need yet.
Has anyone used one of those screen cleaning wipes on the F10 screen?
      04-16-2012, 10:23 AM   #16
bobblehead
bobblehead's Avatar
Drives: warp speed
You are going to use WHAT ?
just kidding.
      04-16-2012, 10:49 AM   #17
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
just kidding.
No seriously, I was going to use those wipes that are designed for screens. I have been using them for years on my Lenovo and Apple Powerbooks. Never have I had an issue.
      04-16-2012, 11:42 AM   #18
the_rangdo
Didn't say you were the only one did I ?
Just pointing out that just maybe you might have a dodgy one. Or maybe I've got the only perfect one that doesn't mark
      04-16-2012, 11:54 AM   #19
NYF32DRIVER
NO, you didn't. But you are lucky at best. It's a known issue.
      04-16-2012, 12:24 PM   #20
the_rangdo
It may be a known issue but I would guess there are MANY more that HAVEN'T got the problem and will likely never let you know. I'd hazard a guess that you are unlucky rather than me being lucky - people generally don't post when they don't have an issue so the fact you can find MANY posts doesn't quantify the issue.
I've given you the info, you can choose to use it as you see fit and go see your dealer - have you actually spoken to them or are you just venting?
Either way don't get arsey with me about it, just trying to help
      04-16-2012, 01:51 PM   #21
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
Maybe the ones with no problem have protection from the DOT
      04-17-2012, 06:58 AM   #22
BMWrules7
Drives: 2015, 740 LdX, Alpine White
[intlink]568328;LCD Display Scuff Repair[/intlink]
Look, if the scratch really caused almost $3000 in damage then get a quote and file a claim with your insurance company.
It's really no different than the same size scratch appearing on the outside vehicle costing $3000.
If you file enough claims the insurance companies will start complaining to BMW.
You will have to pay your deductible.
Closed Thread
