03-21-2014, 09:02 AM | #1 |
Rep 123
Wheel fitment
So, I'm hoping to get some advice from some of you experts out there.
I'm looking into purchasing a new set of wheels and need to provide them with my preferred custom offsets. I currently have a MY11 550 w/ M Sport package and the car is lowered on Eibach springs. I'm currently running OEM 351s with a 12mm spacer up front, and an 18 mm spacer in the rear (could probably bump this to 20 mm) - the setup is very flush. Specs are as follows: Front: 20x8.5 et 21 (et 33 less the 12mm spacer) Rear: 20x9.5 et 26 (et 44 less the 18mm spacer) I'm looking to purchase a new set of 20" rims with the following basic specs: Front: 20x9.5 Rear: 20x10.5 To maintain the same flush setup, according to my calculations I should purchase the following offsets: Front: et 34 Rear: et 45 Is that right? To throw a wrench into this, I've heard that there are other members that are running these exact rims with the following offset: Front: et 25 Rear: et 35 Granted, the other members have a 535, or do not have Msport suspension, but do either of those matter? Are the offsets different on a 535 vs 550, Msport vs standard suspension? Any comments, suggestions or advice is greatly appreciated! Thanks gang, Pete |
03-21-2014, 11:57 AM | #2 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
I would recommend a ET30-32 in front and ET35-40 rear. Now you can run the two setups mentioned above but the second one will just be close and will risk having a little bit of rubbing.
03-21-2014, 12:21 PM | #4 |
Rep 6,811
03-21-2014, 04:47 PM | #5 | |
Rep 123
Regarding your recommended offsets, I can bump up the front to et 30-32, no problem. But I'm already at the max offset of et 35 for the rears, unless I bump up to an 11" rim (which appears to be possible, but I'd really rather not, if given the option...) Thanks again! |
03-21-2014, 04:48 PM | #6 |
Rep 123
03-21-2014, 04:53 PM | #7 | |
Rep 6,811
03-21-2014, 05:04 PM | #9 |
Rep 123
03-21-2014, 05:08 PM | #10 |
Rep 123
03-21-2014, 05:10 PM | #11 |
Rep 6,811
If you need help understanding offset for this setup or future setups you can always shoot me a PM and I can try my best to explain it to you.
03-21-2014, 05:17 PM | #12 |
Rep 8,279
03-22-2014, 01:30 PM | #13 |
Rep 29,202
It also depends on the tire size. What sizes are you getting?
03-22-2014, 03:34 PM | #14 |
Rep 123
