2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 Random headlight issue.. Ideas please?
      07-30-2014, 04:41 PM   #1
suj999
Drives: F06 640d M Sport, F10 520d SE
Have a 2011 UK spec F10 with Halogen headlights that’s 6 months out of warranty.
The car’s driver side headlight shows up random faults intermittently. The faults will go away one day and come back the next. I tried changing the headlight (H7) bulb to a different make, makes no difference. At the moment it’s got a normal Osram H7 bulb. AFAIK the previous owner has never tried to install an after-market HID kit or any such.
The faults that come up on the dash are,
Fault 1: Headlight vertical aim control (pic below)
Fault 2: Driver side, side light faulty.
Most days neither of the fault shows up and everything works fine, some days fault 1 will show up and I can’t adjust the driver side aim but other than that lights work fine. On occasions fault 2 will show up and driver side LED angel eyes will blink for about 10 minutes and then will be back to normal. On rare occasions both faults will show.
Should I just take it to the stealers?? Anyone had any similar problems?
      07-31-2014, 03:46 PM   #2
pklaziemofo
Drives: n/a
Are you other lights function property?
DRL, Signal?
      08-01-2014, 02:54 PM   #3
suj999
If anyone comes here looking for the same info...
http://www.bmwland.co.uk/forums/view...24221#p1324221
      08-01-2014, 03:00 PM   #4
suj999
DRL, Signal?
Yes. Thanks, fixed it today. It was a water damaged control module in the headlight.
      08-04-2014, 01:34 PM   #5
pklaziemofo
Drives: n/a
I have the same problem, how much did you get the headlight module?
      08-05-2014, 07:58 AM   #6
suj999
Paid £175 for a complete 2nd hand headlight including the module and just swapped out the module
      02-06-2018, 03:58 AM   #7
Albertpeter
Drives: BMW F10
Headlight Module issue
I have had the same issue with my 61 plate BMW and this part has fixed
https://xenons4u.co.uk/bmw-tms-headl...6-7267045.html
