2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BMS Stage 1 Check Engine Light (n63)
      10-22-2015, 09:25 PM   #67
550Reasons
550Reasons's Avatar
Drives: F10 550i
I have stage 1, but my box says N63-2, Im running 2.75 on 93 with no issues.
Maybe its 3.0, I gotta check.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      10-23-2015, 02:17 AM   #68
Zer0Cool92
Drives: blue metallic
My "future use" was set to 1, which is an m5 setting. That's probably what made my car act up. I can probably handle 2.75 but the power is pretty good at 2.25.
What does the future use setting do ?
      10-23-2015, 09:57 AM   #69
FenixMike
Drives: 2014 BMW M5 Competition
Have you verified that with data logging? Ive found that most people don't even know what detonation sounds like, nor understand the damage it does to an engine.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i
      12-07-2016, 10:39 AM   #70
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Originally Posted by Zer0Cool92 View Post
Checked the settings on the bms . Boost over stock was set to 2.75 (set it back to 2.25) and future use was set to 1 (set it to 0)
Car still jerks hard under heavy throttle and check engine remains.
T min and t max was not set at 1 and all the other settings were different values as well. (T map slew, maf offset, PID) .
Are the values all supposed to be set the same or just the values in the red box (as shown in installation guide below).
Does your box say N63-2?
      12-07-2016, 10:42 AM   #71
535_BiTurbo
I've read that the N63-2 boxes were 3.0 default and the older boxes were 2.25
"If you have the current version of the BMS JB Stage 1 tuner for the N63 (G3_V2 board w/latest firmware) the factory default boost setting is already +3.0 (not +2.25). You can go a little higher with race gas mix (say, to +3.5), but the tune at +3.0 is already quite strong."
      12-28-2016, 02:12 AM   #72
Zer0Cool92
i have the older one bms that suggests 2.25. So I should have no issues if I bump it up to 3.0?
      12-28-2016, 09:25 AM   #73
550Reasons
550Reasons's Avatar
Drives: F10 550i
Email BMS, say your feeling it a bit rough, or something, and they should send you a replacement with the new motherboard (n63-2)
2011 550i
2013 M5
2014 M5 CP
2016 550i
      12-28-2016, 09:41 PM   #74
Zer0Cool92
They said they'll upgrade my current one for 75 bucks. Whats new on the upgraded one?
Ive got catless downpipes, badblacks intake and an exhaust. What is the highest i can set the boost over stock without running any race gas?
      12-29-2016, 11:44 AM   #75
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
With all of those mods you should be running a JB4 not a Stage1. I imagine the rough running is from the intake and/or downpipes.
Mike
      12-29-2016, 11:46 AM   #76
550Reasons
550Reasons's Avatar
Drives: F10 550i
I think thats because there is no more Stage 2, now its the actual JB4
Before they would send you the Stage 2 box instead. I think for 75$ to upgrade to the JB4 will be good because you can run more boost and have more options in case you would like to run race gas
2011 550i
2013 M5
2014 M5 CP
2016 550i
      12-30-2016, 09:51 PM   #77
Zer0Cool92
What do you think is a reasonable boost over stock to have if I dont intend on running race gas? Im currently set at 2.25.
      12-30-2016, 09:53 PM   #78
Zer0Cool92
Mike
It turned out a couple settings on my bms stage 1 were not correct. Stage 1 had me at 2.25 lbs , how much higher can i go without running race gas? Plan on asking terry these questions too but thought I'd hear what you guys have to say as well. Thanks
      12-30-2016, 11:46 PM   #79
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
I have mine set to 3 and I have crap California 91. When I run a race gas blend sometimes I bump it up to 3.5, you will be good on 3.
      12-31-2016, 12:05 PM   #80
550Reasons
550Reasons's Avatar
Drives: F10 550i
Map 1: 4psi over stock additive
Map 2: 6psi over stock additive
I run Map 2 on 93 octane
http://www.n54tech.com/forums/showthread.php?t=40626
2011 550i
2013 M5
2014 M5 CP
2016 550i
