2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: BMW Performance Black F10 Grille Install & Removing Bumper Silver Trim
      08-22-2010, 11:46 AM   #1
LACSTER
Drives: Hybrid
Post DIY: BMW Performance Black F10 Grille Install & Removing Bumper Silver Trim
Okay so with many pm's asking how to install these grilles I decided to go out today and do the process agian with pics so fellow members can see how easy this is to do. All you need is a Torx-20 screwdriver and about 20 minutes.
First off remove rubber strip in the center on the hood right in front of inside bumber.
Once done you should see two hex bolts underneath.
Now you can start removing the 6 hex bolts using the Torx-20 screwdriver. The 2 in the center is straight forward but the two right on top of each headlight has a cover the needs to be removed first.
There's two clips/locks holding the cover in place. All you need to do is with you fingers just pull the center pin up ( real easy )
Below. Repeat on other side
Once all screws are removed you'll need to pull the center of the front bumper forward to remove chrome grilles. There's nine clips holding it to the bumper. With one hand just pull the grill out on the portion of the grill where you are pushing the clip down with your other hand.
Once both grilles are removed you'll see this.
Now time to install BMW Performance Grilles.
Side by side comparison.
Time to put everything back. The two hex bolts on top of the headlights need to be put on first before the clips/lock pins.
Then place the clip/lock pin in and press down then put lock pin in to secure.
The center piece removed in the beginning need to snap back in.
Now the extra....... Painting silver trim near the fog lights.
All you have to do to remove the mesh is take two fingers and pull forward on each corner to remove the mesh.
Unclip the three parts holding the trim to the mesh.
Paint trim with matte black or gloss spray paint. Your choice. I used matte black then reverse process and install.
Here's the completed look.
Hope this helps all the DIY'er.
Kevin
DonJkZ9.50
John H.230.00
Jamesmick131.00
      08-22-2010, 07:14 PM   #2
Jimefam
Drives: 2011 550I Msport
Awesome thanks for this as it's the first thing I'm doing to my car when I get it.
      08-22-2010, 07:47 PM   #3
ibimmer954
Drives: '23 i4 M50, '15 M3, '18 911
Another alternative for the fins on the lower grills is to get them vinyl wrapped. When I got my car tinted, the tint shop also does vinyl wrapping. I had them wrap the fins in a shiny black vinyl. Looks good so far, and it's reversible. We'll see how the wrapping holds up in the long run, though.
      08-22-2010, 10:57 PM   #4
LACSTER
Drives: Hybrid
Glad I can help
Yep that's another route you can take. I painted mine because the trim pieces are pretty cheap so I can always get new ones. Probably won't need them in the future because I spy an M sport bumper coming
      08-23-2010, 02:10 AM   #5
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
thanks for your photo demonstration
      08-23-2010, 08:16 PM   #6
SCPACKAGING
Drives: 2011 BMW 535
As usual Kevin, looks great! Thanks for taking the time to do this.
ibimmer346 - can you post pictures of your wrapped fins?
I am still undecided if I want to go flat black to match the mesh or glossy to match the kidney grills above!
      08-23-2010, 10:26 PM   #7
geneatals
Ninja
geneatals's Avatar
Drives: 2019 530e
nice DIY..
on a side note, if one is already having the lower grills wrapped in black vinyl, why not just do the same for the kidney grills as well....
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i
      08-24-2010, 03:55 PM   #8
bavarian19
bavarian19's Avatar
Drives: Car
Nice! I did this with my E92, and one of the best mods I did!
      08-24-2010, 04:00 PM   #9
antzcrashing
antzcrashing's Avatar
Drives: 2018 BMW 440i GC
nice job, looks great. I love my blackout grill too (e46)
      08-24-2010, 05:03 PM   #10
uhn2000
Big K...
uhn2000's Avatar
Drives: M3CS BX7
Awesome!
Many fun toys... M3CS XB7 FTW!
      08-24-2010, 05:08 PM   #11
BGM
Drives: F20 M140i
kind of a shame about the diagonal bits on the radiator..
apart from that, looks great
      08-24-2010, 05:18 PM   #12
Dackelone
European Editor
Dackelone's Avatar
Germany
10532
Drives: N54 e82
I like IT!!!!!!
      08-24-2010, 05:22 PM   #13
OwnAge
Gourik
OwnAge's Avatar
Drives: soon
2009 328i  [8.90]
Sick. Keep it up!! Useful DIY.
      08-24-2010, 06:36 PM   #14
Moko
Drives: 335i
look sick with the black grillz
      08-24-2010, 07:16 PM   #15
Oulixes
Oulixes's Avatar
22
Drives: 330xi, 335i
Very clear description of the procedure and a good result. Thanks.
      08-24-2010, 07:45 PM   #16
akhter
akhter's Avatar
419
Drives: 911 992 C2S
this combo works nicely because the leftover white/silver in the headlights matches with the alphine white body.
Current 2021 Porsche 911 992 C2S
Sold 2021 X7/2018 X5/2014 X5
Sold 2013 520i/2010 325i
Sold E90 335i M Sport Alpine White|Tokyo
Sold E36 328i Jet Black|NYC
      08-24-2010, 08:57 PM   #17
Imola.ZHP
Imola.ZHP's Avatar
Drives: 2014 BMW i3 BEV EE
Nice work! Much cleaner!
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17-
- 2015 CPO i01 BEV Laurel Grey Tera World, '17-
- 2015 i01 REx Laurel Grey Tera World, '15-'17
- 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15
      08-25-2010, 12:56 AM   #18
Sylon
Sylon's Avatar
Drives: 2011 135i, SG/CR, 6MT, M-Sport
2011 135i  [9.20]
Now I know I come from the 1 series community, but we have the same directions for the kidney grill install, and I still dont understand the purpose of removing the rubber seal at the top of the bumper. Its not necessary. Just push down on the grill clips and pull the grill out. Thats how it was on my car, never had to remove any screws or seals.
Just take a flathead screwdriver, press down on the plastic tabs in the clips, pull the grills out. The new ones just snap right in.
2011 BMW 135i | Space Gray | ///M-Sport | BMW CCA #450291
Facebook / Instagram / YouTube / Twitter
      08-25-2010, 02:32 AM   #19
modestforest
modestforest's Avatar
Belgium
Drives: F10 520 D
what's the price of the kidneys ?
btw verry nice car !
      08-25-2010, 09:16 AM   #20
LACSTER
Drives: Hybrid
Are you saying to bypass removing the rubber strip and the hex bolt and just use a flat scredriver and pry the grilles out?
I think they run around $85 each side. I'm not too sure just contact BMW parts dept.
      08-25-2010, 09:30 AM   #21
Sylon
Sylon's Avatar
2011 135i  [9.20]
On our grills, there are no bolts, screws or anything other than clips holding the grills into the bumper (and it doesnt look like yours do either). So why do you need to remove screws and bolts when they don't do anything to hold the pieces in?
So, the tabs that slide into the slots that surround the cavity the grills fit into and the only things you need to pop out. Stick a flathead screwdriver in between the slits in the grill, or a hooked tool, and press down on each tab, gently pulling the grill towards you (to prevent the tabs you just popped out from snapping back in). As you work your way around, the grill piece will eventually pop out.
The directions from BMW on our grill installation also include removing the screws and rubber seal, but as more and more people have done the install on our 1ers, we've figured out that those steps are pointless. Some brave souls just take a firm grip on the grills and just yank them out without damaging the bumper at all.
      08-25-2010, 06:53 PM   #22
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
What is that little camera for in this picture. Is it for night vision, never seen that...
