2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 550i review test drive by Motortrend: "Better In Every Way"
      05-13-2010, 11:04 AM   #1
Jason
Jason's Avatar
Drives: F80 M3
Cool F10 550i review test drive by Motortrend: "Better In Every Way"
Be sure to check out our F10 5-series Coverage for all the latest F10 news and info.
Also see our Official F10 INFO THREAD and F10 TECH SPECS THREAD
First Drive: 2011 BMW 550i
Source: http://www.motortrend.com/roadtests/...ive/index.html
More of the Same, Yet Better in Every Way
May 12, 2010
/ By Matt Stone
/ Photography by Matt Stone
So there we were at the Amelia Island Concours d'Elegance, ogling a new, preproduction metallic black (or really dark charcoal gray) 2011 BMW 550i, and our BMW pal said, "Hey, like to take it for a drive?" Got any more stupid questions? Gimmee that keyfob, Please. Scott Evans already ran down all the tech and spec stuff for you, so we'll focus on the actual piece in hand and the driving experience. The exterior design is ultrafresh and looks like a modern BMW without some of the overdetailing from which many of them have suffered. It's better balanced-looking than the outgoing 5 Series, but would never be mistaken for anything else. Underhood is the new, 400-horse, twin-turbocharged V-8, backed by ZF's new, and super high-tech, eight-speed automatic transmission.
This car isn't quick; it's genuinely fast, and smooth. We criticized this engine in the new 7 Series for a less than even acceleration curve and slightly jerky throttle response, but no such problem here. Perhaps BMW has evened out the engine's power delivery, or maybe the new trans calibrates the problem away. But the biturbo V-8's got power everywhere on the tach and is easy to drive slowly and smoothly and really gets with the program when you've got your toes into it. There's no turbo lag or jerkiness, just smooth power from a relatively low rpm, as there's meaningful boost available at low rpm. This powertrain makes that silky, turbinelike whirr we've come to expect from BMW V-8s, and it doesn't disappoint. While the result is exceptional, one wonders if this much expensive turbocharger hardware is needed or warranted to produce 400 horsepower. There are other V-8s that make as much power without all the technical complexity. Whatever, it sure works. As is typical of today's ZF automatic transmissions, this eight-speeder shifts smoothly without being mushy, and always seem to be in the right gear want a different one, just order up- or downshifts via the steering wheel paddle-shifter, or the throttle.
The interior is a higher-quality cabin than that of the outgoing 5 Series. And in the event you are/were an iDrive hater, you'll get along with this one better than previous-gen systems. Note that wide, high-def screen up high on the IP, easily in the driver's line of sight and very sharp and crisp to read. BMW seats are often on the sporty side of luxurious, and these are great chairs. Firm and supportive, but the bolstering is never intrusive, and the pinholed leather keeps you comfy in any weather. The highly lacquered wood trim looks great while still looking like wood, instead of shiny plastic, a fate that plagues some other luxury marques.
BMW has really nailed the ride/handling balance on this car too. It's quiet inside, but not overly silent (in a bad way). Wind noise is commendably low, and the big run-flat tires don't rumble much (more likely due to the fact that they are new and had few miles on them). Body motions are well controlled, the car never pitching much in corners, with plenty of grip on tap. Steering is more responsive and linear than in the outgoing 5. The ride quality is firm, but never harsh -- can't wait for the next M5 that'll be based on this chassis architecture!
The rest is all good: nicely weighted, responsive controls and driver inputs. Plenty of performance in every parameter. If you and three friends have a long way to go and a short time to get there, and want to do so in comfort and style, you won't go wrong here. Don't need 400 horses or want to spend quite as much? The new, single-turbo inline-six 535i should still more than get the job done.
Check on the Latest BMW News
      05-13-2010, 11:47 AM   #2
kred
kred's Avatar
Drives: '07 e92 328i 6mt
a v8 TT takes 6 seconds to get to 60 mph? if im not mistaken..the e60 550i was much faster than that
beautiful car tho! saw one yesterday in person for the first time and its sexy
2007 Space Gray 6MT 328i / BMW SSK
      05-13-2010, 11:55 AM   #3
BMW269
It takes 5.0 sec to get from 0-62 mph or 0-100 km/h.
      05-13-2010, 12:10 PM   #4
silvergray545
Skittles, OT OG
silvergray545's Avatar
Lebanon
2337
Drives: Lots of M cars
2016 BMW M3 ZCP  [0.00]
2000 BMW M Roadster  [0.00]
2004 BMW M3  [0.00]
2014 VW GLI  [0.00]
I'm sure this is a more accurate number. My 545i does 0-60 in 5.5 sec.
      05-13-2010, 12:16 PM   #5
kred
kred's Avatar
yes that sounds better..i was just confused when i saw 6.0 seconds up top in the article
      05-13-2010, 12:18 PM   #6
Vintage
Vintage's Avatar
Drives: BMW G80 (MT), 718 Spyder
I can't wait to drive one at the dealer.
      05-13-2010, 12:23 PM   #7
JoeyBananaz18
JoeyBananaz18's Avatar
398
Drives: metrocard
yeah the 0-60 will definitely be less than 6.0. 5.0 sounds much more realistic. and if 5.0 is anything other BMWs' notoriously conservative numbers, this could be ever lower- 4.8 maybe? The M5 just may be able to crack the 4.0 mark. wishfull thinking.
im surprised they didnt talk about the amount of torque it makes. i understand that there are other V-8s out there that make as much power as this TT does. but 450ft/lbs of torque is pretty impressive.
7/18/09- I pick up my baby- 2009 E92 335i Xdrive, Space Gray over Coral Red. Premium Pkg, Cold Weather Pkg, M-Sport Pkg, 193Ms, Gloss Black grills, Custom Gloss Black Mirrors, Performance shift and E-brake boot, M3 spoiler, Euro fog switch, gloss black interior tim, Coco-Mats (red/black), H&R coilovers, 19'' Alufelgen SF-71s......
      05-13-2010, 01:06 PM   #8
SleepTight
SleepTight's Avatar
Drives: 2013 BMW M5
They obviously liked it, but they almost damned it with faint praise. I was expecting them to find the F10 550 positively revalatory. Maybe a more in-depth review will do that.
On the other hand, I think the 550 is always going to get a less than full-throated endorsement from the reviewers since they have to leave some enthusiasm for the M5.
      05-13-2010, 01:20 PM   #9
lesha
lesha's Avatar
79
Drives: 2009 - 335 coupe
why are the stock rims so ugly
      05-13-2010, 01:33 PM   #10
BMW Fanatic
Drives: slow
+1.. no m-sport or sport package maybe?
      05-13-2010, 02:25 PM   #11
EmPower
EmPower's Avatar
Drives: 2014 X5 xdrive 35i
This engine as good as it is is going to take a spanking from the 4.7TT from Benz that replaces the 5.5 unit from its lineup. The state output of that motor is 425hp and a monstrous 512 torques. That motor is almost as powerful as the unit found in the E55 AMG not too far into the past.
92 Mazda Mx6 (sold), 00 VW Jetta (sold),
07 BMW 335i (sold), 10 VW Jetta (sold),
14 BMW X5 35ix (sold), 18 VW Jetta (totaled),
19 Audi SQ5 (sold), 20 Audi S6 (sold),
22 Audi SQ5
      05-13-2010, 02:38 PM   #12
hinckley
hinckley's Avatar
3493
Drives: '24 M4C Conv
Funny - the car has those ugly stock rims, but it's equipped with the sport package (see the shadowline and "sport" steering wheel). Should have 19" 332s (only a bit less ugly).
      05-13-2010, 03:59 PM   #13
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
As usual, Benz is a little late to the party. That engine you're talking about won't surface in an E-Class for at least a year from now. By the time the 2012 models arrive next fall (or thereabouts), I'm sure BMW will be doing some "tweaking" of their own.
      05-13-2010, 05:24 PM   #14
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
fabulous . loving it more
      05-13-2010, 05:35 PM   #15
Oulixes
Oulixes's Avatar
22
Drives: 330xi, 335i
+1, it is a bi-turbo V8, very nice in black.
      05-13-2010, 06:14 PM   #16
GreenPlease
GreenPlease's Avatar
Drives: BMW 335i e92
I get the feeling that BMW is being ridiculously conservative with its 0-60 numbers. Perhaps the tires are a limiting factor...
Cars>Women
      05-13-2010, 06:15 PM   #17
bigrobb2
bigrobb2's Avatar
Drives: 2019 X5 40i
Is it just me or has BMW been dishing out some ugly rims as of late?
Audi,infiniti, and MBenz stock their sportier cars with nicer rims.
Brushed aluminum at that.
      05-13-2010, 07:50 PM   #18
lesha
lesha's Avatar
79
yeah bmw is behind in the wheels department, if you want something nice and OEM have to custom order from bmw catalog
      05-13-2010, 08:17 PM   #19
bobbyd1961
Drives: 2009 M3 sedan LeMans Blue
6 seconds?! i dont think so more like 5
      05-13-2010, 08:49 PM   #20
MI6
The World is Not Enough
MI6's Avatar
Drives: Aston DBS-R
Read the post guys- it says 0-60....... 6.0 MT (est).
Est. means estimate
This was a Motor Trend First drive, NOT an actual road test with gear etc...
      05-13-2010, 09:37 PM   #21
Technic
Technic's Avatar
2295
Drives: 2021 i3S, 2024 i4 M50
BMW already has a Performance upgrade for this V8 TT (448hp, 480lbft) in the X6, so it is just a matter of time that it will be offered in all V8 TT models.
      05-14-2010, 07:49 AM   #22
pharding
Drives: 23 Audi Q4 e-tron + 14 X3 28i
Motor Trend does not know cars very well, if they estimate that the F10 0 to 60 mph time is 6 seconds. For a magazine geared toward the performance car enthusiast that is a rather fundamental and stupid error.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3
Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del
