06-30-2016, 02:45 PM | #23 |
Rep 359
Drives: 19' M2C
I don't think there is any added benefit to this mod, I am pretty sure that this only applies to N63\S63 motors from what my dealer was telling me when I asked why the 2012 535i I traded in for the 550 did not have it. Just go into sport mode and hold the DSC button for around 10 sec and have fun!
07-01-2016, 10:40 AM | #25 | |
Rep 250
all good now with sport+ |
07-01-2016, 10:48 AM | #26 |
Rep 1,214
I myself love the shift paddles and use them frequently. I have a few complaints with them though.
If you don't have the shifter kicked over to M/S it will still upshift for you. Sometimes it upshifts for you at the same nanosecond you upshift, resulting in skipping 2nd gear and going to 3rd for example... this has happened a number of times and its annoying because 1--->3 is slooow. The other thing is that when you're negotiating a tight turn, or sliding with some opposite lock its difficult to use the paddles as your hands aren't likely to be in the correct position. As someone that has only ever owned manual vehicles in my life I have to admit the paddles make an automatic car at least a little fun. Before I coded 2TB and added the paddles spirited driving was kinda lacking any excitement. |
07-01-2016, 02:20 PM | #27 |
Rep 359
Drives: 19' M2C
07-11-2016, 10:03 AM | #28 |
Rep 30
07-11-2016, 01:26 PM | #29 |
Rep 250
Yes, once you have complete the first step of adding 2TB in VO, removing 205 in VO and saved new FA, go back to each of these 4 ECU folders under the coding menu in E-Sys and right click and code, do not right click on the under laying CAFD files. In my case i could only code 3 of the 4 ECU folders as one of the ecu folder didnt allow me to select "code" option.
07-18-2016, 11:09 AM | #30 | |
Rep 2
I have a f10 2012 without paddle shiffers. I code icm, kombi and egs. I can see a sport+ on kombi but the car dont leave select it. whats the problem? Thanks |
07-25-2016, 02:26 PM | #32 |
Rep 8,364
06-23-2017, 08:51 PM | #33 |
Rep 65
Does anyone have experience with this. I don't even have the rocker switch on my 2011 535 xdrive. I bought a superset one from ebay. Any help ? I'm new to BMW but not working on cars. I'd rather not do this myself. Thanks
06-27-2017, 07:15 AM | #34 | |
Rep 1,873
I'm working on a retrofit to an LCI steering wheel with paddles so I will likely be putting 2TB back in to get the paddles to work. I can't say I observed any different behaviour of the transmission in terms of shift points (i.e. what RPM shifts were performed) or shift program selection (i.e. what shift profile/program was used for shifts of various levels of aggressiveness). [ After getting my M Performance Exhaust I became aware that there's three major shift programs/types - a slow and lazy automatic shift, a faster shift that sounds almost like a manual transmission and a DCT-style "brap" shift. I sure wouldn't mind if I could code a preference for more aggressive shift programs in general. ] |
04-26-2018, 07:18 PM | #36 |
Rep 217
I have found an easy way to code sport transmission. BimmerCode has added it. After getting my car ungraded to the latest iStep last week at the dealer I was recoding the car to my preferences and noticed theyd added transmission coding. Love the faster shifts paired with MHD stage 2.
The traction struggle is real.... |
04-28-2018, 03:50 PM | #37 | |
Rep 1,873
As part of other warranty work I also got taken from a 2015-era istep to the latest in February and I noticed some changes in 1-2 and 2-3 shifts when really on it (i.e. the most aggressive shift program). When I refit my M PE for the summer I'll be listening to the sound of those shifts to see if I can further tell what's changed. |
jayster0966209.00 |
09-18-2018, 03:30 PM | #38 |
Rep 4
Can anyone help me out here?
I have coded the following via Bimmercode: ICM/3000 ICMKOD_B_SPORTLENKUNG nicht_aktiv ===> aktiv KOMBI/3000 FDS_MENUE_TEXT_1/2/3/4 menue_4 ===> menue_3 KOMBI/3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_4 ===> menue_3 EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv EGS/3000 Applikation -> LC -> aktiv SAT is enabled and working fine. I can see Sport+ when I hit the rocker switch, but I can't actually select it. The highest I can go is Sport. When I try to switch up to Sport+, nothing happens. Did I possibly overlook something? |
SonOfAnakin11.50 |
10-22-2018, 09:49 PM | #39 | |
El Conquistador
12
Rep 44
Drives: 2015 535i xDrive
Does the BimmerCode addition also enable Launch Control? That's really the big reason to enable this, in my opinion. Would like to know before I pay for BimmerCode. Already paid for Carly, unfortunately. |
02-29-2020, 05:17 PM | #40 |
Rep 2
Hi guys, i've readed whole threads and im trying to add sport+ to mines F11 3.0 d pre-lci.
What done i wrong? I've coded VO, changing 205 to 2TB, and coded ECU's are -EGS, -GWS, -Kombi, -ICM In CIC menu i can see only SPORT, and nothing more. Got SAT, when i pull lever left i got S1-S7, but still don't get SPORT+ I've done those steps: 205-> 2TB done, FA overwrited to my car, Loaded FA, Activated VA Right mouse click at Ecu's writed above, coded and i can't saw sport+ Can anyone help me? |
03-24-2020, 10:47 PM | #41 | |
Rep 423
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
08-02-2020, 07:30 PM | #42 |
Rep 10
No GWS?
Did a bit of coding today on my 2014 535, following your instructions for enabling sport+... I was able to code -EGS,-Kombi, and -ICM but GWS doesn't have a coding option, is that normal?
I tested and Sport+ does enable and seems to work just fine; just wondering if GWS was necessary? |
08-03-2020, 02:49 PM | #43 | |
Rep 5,394
08-03-2020, 04:54 PM | #44 | |
Rep 2,595
2015 BMW 535xi
