2010 2011 BMW 5 Series Forum F10 Has this happened to anyone? |
09-08-2015, 09:48 PM | #1 |
Rep 201
Drives: E92 M3 | F15 X5 | G30 M550i
Has anyone else had this problem? It is a 2011 535i.
https://pbs.twimg.com/media/CObbAzuWEAACjbS.jpg I will be taking it to a dealership soon. I just don't know what to expect. It only has 35k miles. Thanks! |
09-09-2015, 08:20 AM | #3 |
Rep 1,472
I had the same warning when my rear pads were worn out.
Ii think it's normal iDrive warning when your brakes are due to get serviced...unless of course something is wrong with the sensor. |
09-09-2015, 06:44 PM | #5 |
I am groot
25
Rep 149
Take a look at your front wheels and look thru the wheel to see if your front pads are almost touching the rotors, it could be the wear sensor telling you the brakes are due. If the fronts pads look like they have meat on them like let's say 1/2 inch then it's prolly not the fronts pads, make sure to check all the brakes right and left, front and back. Let us know what you can see.
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order |
09-10-2015, 05:34 AM | #6 |
Rep 1,873
That seems to clearly be an ABS error. Maybe a fuse, wheel sensor, or something way more expensive. Detailed codes will be stored and should be read.
It doesn't look like a wear limit or CBS warning |
