2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Fog light bulb compatibility check
      04-23-2012, 03:49 AM   #1
darrko
darrko's Avatar
Drives: 2016 M5 Comp. Ed.
2016 BMW M5  [0.00]
I found this while searching for replacements for the fog light bulbs to match the Osram CBI for a non M-sport F10.
http://www.autobulbsdirect.co.uk/HB4...b_search=c2247
Can anyone confirm if this will be an error-free match?
On another note, why do most websites list the 2011+ 5-series saloon as having a D2S headlight bulb connector whereas I have repeatedly viewed members here specifying it as D1S?
Current:
2012 520d
2016 M5 Comp. Ed.
2020 Porsche 911 Carrera S (retired)
2023 X5 xDrive45e
      04-23-2012, 06:51 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
I thought the non Msport fog light uses H8. Not HB4. You better double check.
As for D2S, BMW has not use D2S for many years. D2S is for headlight with reflector. D1S for projector.
D1S is the correct headlight bulbs, which I currently use for the Osram CBI.
      04-23-2012, 09:19 AM   #3
darrko
darrko's Avatar
2016 BMW M5  [0.00]
D1S is correct for the bi-xenons right? I went through the "bulb selector wizard" on at least 2 websites and they both got back to me with D2S, even though I selected 5-series saloon/sedan 2011+. I don't get it.
And you say H8 and I am sure you are correct but the website says HB4. Where are these websites getting their information?
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-23-2012, 09:29 AM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
For North America, Sylvania is the guide.
http://www.sylvania.com/en-us/applic...n.aspx#fldYear
You should check your manual as well. But then I don't see why South Asia version BMW is made any differently.
      04-23-2012, 09:30 AM   #5
E90Fleet
South Africa
1312
For your F10
Xenon bulbs = D1S
Regular fogs = H8 (M Sport fogs = H11, and the E60 used HB4)
Those websites are often very wrong
BMW if you are reading, I need a job, Please.
      04-23-2012, 09:53 AM   #6
darrko
darrko's Avatar
2016 BMW M5  [0.00]
Yeah had me worried since I've already bought the Osram CBI with D1S connector and am having it shipped.
Thanks guys.
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-23-2012, 09:57 AM   #7
darrko
darrko's Avatar
2016 BMW M5  [0.00]
Any opinions on these?
http://www.autobulbsdirect.co.uk/H8-...-Bulb-NEW.html
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-23-2012, 10:03 AM   #8
E90Fleet
South Africa
1312
Originally Posted by darrko View Post
Not road legal (as per description)
Will also cause a bulb warning message if its resistance is not the same as the regular bulb
      04-23-2012, 11:09 AM   #9
bobblehead
bobblehead's Avatar
Drives: warp speed
they are not bright at all.
+1 on the error. It may not give you the error message right away, but over time after having continuous use.
      04-23-2012, 12:00 PM   #10
darrko
darrko's Avatar
2016 BMW M5  [0.00]
Noted and avoided, thank you. Any other LED options that will work? I've been advised no normal bulbs will match the Osram CBI color.
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-23-2012, 12:31 PM   #11
bobblehead
bobblehead's Avatar
Drives: warp speed
Not sure if you want to consider this. I have never used them but the pic (not sure if it's photoshopped or not) shows promising matching ??
As typical like all others, they are colored coated bulb
http://www.ecstuning.com/News/Ziza_H8_Bulbs/
      04-24-2012, 02:25 AM   #12
darrko
darrko's Avatar
2016 BMW M5  [0.00]
What are the chances of them throwing an error?
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-24-2012, 05:45 AM   #13
bobblehead
bobblehead's Avatar
Drives: warp speed
None.
Identical to stock. 12volt 35watt
      04-24-2012, 11:26 AM   #14
darrko
darrko's Avatar
2016 BMW M5  [0.00]
Ok cool, they aren't expensive so I can give them a shot. As long as there are no sparks involved!
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-24-2012, 11:37 AM   #15
bobblehead
bobblehead's Avatar
Drives: warp speed
^ now you mentioned, maybe you should check your car insurance policy first ... LOL
      04-24-2012, 11:54 PM   #16
darrko
darrko's Avatar
2016 BMW M5  [0.00]
I would rather get some first-hand feedback from someone who used these bulbs.
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-25-2012, 03:58 AM   #17
darrko
darrko's Avatar
2016 BMW M5  [0.00]
What about these, even though it says 4150K on the box. Is PIAA a reliable brand? "Extreme white" seems to be more a marketing term than fact!
http://www.ebay.co.uk/itm/PIAA-H-457...item2c6311052b
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      04-25-2012, 06:59 AM   #18
bobblehead
bobblehead's Avatar
Drives: warp speed
^ Piaa ... I used that before, not white at all. Has the dull yellowish look in it. Tiny/marginally better than stock dull yellow.
You need at least 5500K in order to achieve that white/bluish look.
      04-25-2012, 09:45 AM   #19
darrko
darrko's Avatar
2016 BMW M5  [0.00]
Oh man. Thanks buddy.
Current:
2012 520d
2016 M5 Comp. Ed.
2023 X5 xDrive45e
      05-24-2012, 09:10 AM   #20
fastNugly
Drives: 2017 BMW M4
Originally Posted by E90Fleet View Post
For your F10
Xenon bulbs = D1S
So to confirm, the M Sport fogs = H11 and not H8 as indicated in the sylvania.com link?
