2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions ANY DIY for installing Front Spoilers/ rear Diffusers?
      11-09-2016, 11:09 AM   #1
Merciless58
Merciless58's Avatar
66
Drives: 2012 F10 M sport
Topic.
Thanks,
      11-09-2016, 11:10 AM   #2
Merciless58
66
I have a CF 3D design rear diffuser and pending purchase of a CF front M performance Spoiler... Looking to do the installation myself if its easy...
      11-09-2016, 12:09 PM   #3
The_M6
The_M6's Avatar
Drives: 2013 M6
I just posted pics of my carbon front and rear setup. They're very straight forward and while the front lip may take some modification and drilling, not difficult at all. If you have a higher quality setup they should fit better than most Ebay items.
Assuming you have an M-Sport
For the rear, there are 3 or 4 screws underneath and a handful of "push pins" holding it on. Remove those and then pull gently towards you and out starting on one side of the bumper cover and then the other. It should just pop right out, only held on by simple tabs. Once it's off the carbon one goes on just as easy.
The front will take more work depending on the fit but it should be straight forward as well.
      11-09-2016, 12:11 PM   #4
thebmwjunkiee
thebmwjunkiee's Avatar
240
Drives: 2016 535d M-Sport
It is pretty easy, Ill look around for a DIY as I have seen a couple on the forums. I recently installed a vorsteiner lip and would recommend you get a second person to help. If you have some blocks to raise the front end up, that helps. You basically just need a few self tapping screws, as the front lip should have pre cut holes underneath which you simply screw up into the bumper. The "difficult" part is keeping the lip in place while you install the screws. I only had myself, so I wedged a stack of books up under the lip to keep it in place while I secured the screws. It came out a little lower than I wanted, but its on securely.
And I also just did a diffuser install, which is extremely easy. There is 4 or 5 pins on the underside which you simply pop out first. Once those are undone, the diffuser has clips all the way around the top and sides, but these pop right out with a soft pull. Work your way around starting on one side, and with a little pulling it will fall right off. I'd recommend having a towel underneath in case you drop the diffuser, although its very light so it's not likely you will
2016 535d M Sport, Space Gray/Mocha
Past: '14 328, '08 335, '04 525, '91 M5, '95 525
      11-09-2016, 12:17 PM   #5
Merciless58
66
Thanks Guys, the front is OEM Performance lip, so fitment shouldn't be an issue. I'll play with that this weekend. I look forward to the DIY if you ever find it, BMWJunkie.
Thanks
      11-09-2016, 12:19 PM   #6
Merciless58
66
Yes, have the M sport. Sounds simple. Would love to engage with it over the weekend, but I don't have quad tip mufflers so it will look strange... lol. Waiting on purchasing some mufflers with quad tips.
So, I don't need to remove the bumper cover at all? nice
      11-09-2016, 12:21 PM   #7
The_M6
The_M6's Avatar
Drives: 2013 M6
http://f10.5post.com/forums/showthre...3#post20828763
No need to remove the bumper covers...either of them.
      11-09-2016, 12:23 PM   #8
thebmwjunkiee
240
No, its not necessary to remove the front bumper. Just try to park somewhere where you have enough room to get under and operate the drill straight. For now, heres the diffuser video I used
Diffuser install:
      11-09-2016, 12:31 PM   #9
Merciless58
66
WOW! Thanks. Looks super easy.
      11-09-2016, 12:40 PM   #10
TTG
TTG's Avatar
Drives: M340
Thanks
Even OEM front lip is not that straight forward due to its shape and how it is installed.
Like others stated, it helps to have another person and elevate the front of the car.
Also, you might consider using betalink.
Please keep us posted.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      11-09-2016, 01:50 PM   #11
The_M6
The_M6's Avatar
Drives: 2013 M6
This is what a test fit looks like with no help...
      11-10-2016, 09:35 AM   #12
Merciless58
66
nice spoiler. is it the Arkym?
      11-10-2016, 09:37 AM   #13
Merciless58
66
Thanks, I will. I am buying from another forum member locally. it comes with the 3mm tape. Will that be sufficient? The splitter/spoiler comes with 5 pre drilled hole. 2 on each splitter and one on the middle. Are they meant to be used with the same fasteners under the bumper cover?
      11-14-2016, 03:23 PM   #14
ALPWhite
Drives: 2013 Alpine White 535iX MSport
Rear Diffuser
http://f10.5post.com/forums/showthread.php?t=887130
http://f10.5post.com/forums/showthread.php?t=950378
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
