2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions any tip on removing adhesive smear after debadging?
      06-13-2014, 06:57 PM   #1
Ben2k9
Drives: 2011 BMW 550i M-Sport
So I recently removed an annoying dealer badge that was on my 535i. Heated with hair dryer and then separated the badge with floss. Came right off, however, there's still a bit of a smear that has not come off from the adhesive. Can anyone recommend a product that might take it off?
      06-13-2014, 07:04 PM   #2
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
Goo gone!
      06-23-2014, 08:50 PM   #3
wicked5
Drives: 520d SE
or a simple wax on a warm day will remove it, just keep rubbing
      07-29-2014, 06:16 AM   #4
FeckinSpaceman
FeckinSpaceman's Avatar
270
Drives: 22' M240i
2022 BMW M240i  [0.00]
Originally Posted by ///SAL View Post
Goo gone!
+1
Goo gone, soft rag, and some elbow grease. ......the longer it's been there the longer you have to work
Use your finger under the rag and keep dabbing the goo gone then use small circular attack.
2022 M240i Thundernight Metallic / Oyster
Previous
2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i
      08-07-2014, 12:27 PM   #5
PR_F10_535
PR_F10_535's Avatar
Drives: 2011 f10 535i
3m adhesive remover will do the trick as well
      08-07-2014, 01:27 PM   #6
Sabo
Drives: F21 M140i
Autosmart Tardis tar and glue remover would do a great job if available there but any other T&G remover should be fine.
      08-15-2014, 10:17 PM   #7
dpouncey
DINAN free flow/BMS stage 2/ STIR PLUS- AL Priorit
Drives: 2011 BMW 550I m sport
3M adhesive remover is the best/ safest way. We use it all the time at the Body Shop
      09-19-2014, 09:08 AM   #8
E92TTKING
E92TTKING's Avatar
Greece
250
Drives: e92
Goo goone
      11-12-2014, 01:51 PM   #9
satzinger
Old BMW Fan
Drives: BMW 550i 2013
Best I have ever experienced is Starter Fluid!
      11-14-2014, 06:38 PM   #10
marshak
Drives: 2013 528xi
WD-40 will work as well
