2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Help!! 535i Xdrive ,Message: brake system drive moderately replace brake pad
      08-23-2016, 10:59 AM   #1
kevinwang65
Drives: 535i
I have a 2011 535i Xdrive. I went to service last month. The BMW service told me I need to change brake pad after 3000 miles.
I got the message brake system drive moderately replace brake pad" today after I drove about 500 miles. Do I need to change the brake pad or any possible something wrong in the sensor?
Do I need to change the brake pad in the service center of BMW? May I change it at Jiffy Lube?
Thanks.
      08-23-2016, 11:23 AM   #2
Bbb34
Drives: '11 535i 6sp. DHP/RWD
You can change them anywhere of course, many owners are changing brakes by themselves.
I've been sticking with the dealer and OEM parts personally.
Keep in mind these are heavy cars though, you want to use quality parts wherever you go.
      08-23-2016, 11:23 AM   #3
ALPWhite
Drives: 2013 Alpine White 535iX MSport
If out of warranty, which I presume you are unless you have a third party or extended one from BMW got to them otherwise find a reputable independent repair shop that works on BMW's and have them check/replace.
Please don't go to Jiffy Lube.
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      08-23-2016, 12:46 PM   #4
kevinwang65
Drives: 535i
Why don't go to Jiffy Lube? Thanks.
      08-23-2016, 01:31 PM   #5
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Because he does not want to die. Dealer is the safest bet, I would by the OEM brake pads from like ECS tuning or Turner motorsports then take those to the dealer and have them do it, by buying the OEM parts saves you money and the sometimes dealers gives you crap if you don't have the OEM parts.
      08-23-2016, 02:40 PM   #6
kevinwang65
Drives: 535i
I got the message "brake system drive moderately replace brake pad" red light. Can I still drive the car? Any risk? Thanks.
      08-23-2016, 03:53 PM   #7
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
It's fine, just means that you've triggered the brake sensor in the pad. The idrive is just an estimate, this warning comes up when the pads physically trigger the sensor at a set wear level. I've easily done 500 miles after this has been triggered and could have driven further but didn't want to chance it wearing through and ruining my disks...
      08-23-2016, 06:21 PM   #8
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
get them changed now before you forget and then you need new rotors
      08-23-2016, 10:02 PM   #9
Check the many reviews. They've been busted many times for not doing the work that was paid for. They are one of the may places I wouldn't let check the air in my tires. Pep Boys, Jiffy Lube, Sears, Firestone, Midas...
Tags
535i, brake pad change
