2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      09-30-2016, 12:08 PM   #199
Carlos528i
Drives: 2013 528i
2013 BMW 528i  [0.00]
Thanks!
So got the full file and updated all the listed ECUs, took a little over an hour. (I had done NBT separately) Car drives a little different, seems comfort mode was dialed up some toward sport mode? Hope it does no change my fuel economy, I'm getting 23.6 MPGs in Atlanta traffic.
Airbag light is flashing but I recall reading this to be common after ECU flashing, searching for the info on how to clear it.
Thanks again for the link to the file.
Carlos
Originally Posted by shawnsheridan View Post
PM sent.
      09-30-2016, 03:12 PM   #200
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by Carlos528i View Post
Thanks!
Carlos
It is found on the flashing guide on page 12.
If coding ACSM, the airbag needs be locked. This can be done by using the following procedure (src:
E-Sys Transmitter:
1) Click "External Applications" in the left menu.
2) Click "External Application"
3) Double-click "Transmitter"
4) Double-click "ACSM verriegelung_schreiben"
Tool32 (Alternative to E-sys Transmitter for ACSM):
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\ACSM4.prg
4) In the "Select Job: F01" window, select steuern_verriegelung_schreiben
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
      09-30-2016, 04:51 PM   #201
Carlos528i
Drives: 2013 528i
Almaretto,
Thanks for the info; I just tried the E-Sys Transmitter but didn't clear it. Tried both, ACSM verriegelung_schreiben and ACSM verriegelung_schreiben_new with no luck.
Any idea where to get TOOL32 ?
Thanks.
Carlos
E-Sys Transmitter:
2) Hit F3
5) Hit F5
      09-30-2016, 05:26 PM   #202
Almaretto
Almaretto's Avatar
2374
Almaretto,
Thanks.
Carlos
PM Sent. Another helpful resource is the following:
Guide: Selecting the correct .PRG file for Fxx Jobs in Tool32
      10-01-2016, 07:49 PM   #203
Carlos528i
Drives: 2013 528i
Was able to clear the error code but not sure if the airbag is locked, Job Status returns "ERROR_ECU_REQUEST_OUT_OF_RANGE"
I ran the following TOOL32 Jobs:
Clear Fault Codes:
Hit F3
Load C:\EDIABAS\Ecu\F01.PRG
In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
Hit F5
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
Lock ACSM:
Hit F3
In the "Select Job: F01" window, select steuern_verriegelung_schreiben (steuern_verriegelung_schreiben = control locking write)
Hit F5
Any ideas?
      10-02-2016, 05:09 PM   #204
Almaretto
Almaretto's Avatar
2374
Do you know if you flash programmed ACSM?
      10-02-2016, 05:21 PM   #205
Carlos528i
Drives: 2013 528i
All ECUs were flashed to v.59.4
All show green when compared to that version. I'm getting Rheingold to run diagnostics. Airbag indicator is gone, car runs great.
      10-02-2016, 05:23 PM   #206
Almaretto
Almaretto's Avatar
2374
With each ISTA-P release, there are not always updates for every ECU.
I am glad to read all dash faults are gone.
      10-11-2016, 11:29 AM   #207
Danburns91
Drives: Space Grey Metallic F10
Coding West Midlands
can anybody code either in the Midlands or surrounding area? Willing to pay and don't want too much done. Mostly DRLS without the headlamp on.
Cheers
Dan
      10-11-2016, 11:57 AM   #208
Almaretto
Almaretto's Avatar
2374
Cheers
Dan
Is this for an F10? Do you want brighter DRL's? Front and rear DRL's?
      12-29-2016, 02:22 PM   #209
jpatel27
Drives: BMW 535 ixDriver
My car(2013 535 ix) recently got "updated" by the dealership and unfortunately all my coding went away. Does anyone know if there is an updated software that I can use? I tried to code it again and it would not work. It won't read anything from my car
      12-29-2016, 02:35 PM   #210
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      02-09-2017, 04:10 PM   #211
traskix
Drives: (F11) 2012 520D SE Jet Black
Exclamation Problem with ZGW_SEARCH.EXE
Hi Guys,
Just been reading through your forum and gathering info on coding for my f11 520d 2012. I've got the software and the cable and I followed the step by step guide but have a problem detecting the connection. When I click the ZGW_SEARCH.EXE it comes up with UDP_PEER error saying that some file may be missing and gives me the name of that file as MSWINSCK.OCX and this file is actually right above the .exe file so not sure why it says it is missing. Anyway, because of that I cannot proceed any further. Any ideas??? Anyone with similar problem????
Thanks guys
      02-09-2017, 04:15 PM   #212
shawnsheridan
Originally Posted by traskix View Post
Hi Guys,
Thanks guys
You have way outdated software, and ZGW_Search is not required nor used. You need to remove it all and get the latest.
You cannot send or receive PM's yet. Send me one when you can.
      02-10-2017, 04:32 AM   #213
traskix
Damn. It just tells you how much I know about. I thought I was doing quiet well OK. Looking forward to hearing more about this. My E-Sys is 3.18.4 and psdzdata _47.5 - are those really way behind?
Cheers mate will PM when able to
      02-10-2017, 04:58 AM   #214
Almaretto
Almaretto's Avatar
2374
Latest E-sys is 3.28.1 and Psdzdata 3.60.4. But, you only need to update if your I-Step >= downloaded Psdzdata. If it is, you get "not found [C012]" errors when you attempt to "Read Coding Data."
If you are using Psdzdata >= v3.54.1, it is recommended to have latest Launcher for added stability, enhancements, and CAFD mapping.
      02-10-2017, 03:13 PM   #215
traskix
Noted.
      02-12-2017, 03:52 PM   #216
traskix
Smile
shawnsheridan you are THE DUDE !!!!!!!!!!!!!!
Got it all installed. Just having an issue with the cable giving me an intermittent connection - must get a new one before attempting coding.
Out of curiosity - what is the worst case scenario if coding goes wrong?????
What if you ran out of juice whether in your car or a laptop during coding????
Thanks
      02-12-2017, 05:47 PM   #217
shawnsheridan
Thanks
Normally, if connection to car is lost during an ECU Write operation, ECU becomes corrupt, but is recoverable. In rare cases, ECU actually becomes Bricked.
      02-23-2017, 09:00 PM   #218
johnhva
johnhva's Avatar
Drives: 2014 535ix
14 BMW 535ix  [0.00]
04 BMW 325cic 5MT  [0.00]
16 BMW R1200RT  [0.00]
Can I get a link to ESYS software for F10 coding?
TIA!
      02-23-2017, 09:52 PM   #219
shawnsheridan
TIA!
PM sent.
      03-01-2017, 11:04 AM   #220
johnhva
johnhva's Avatar
Drives: 2014 535ix
14 BMW 535ix  [0.00]
PM sent.
Thanks much, got it.
I've got the software installed successfully (forwarding the PC date for Esys Launcher Premium car select) and a cable and I'm able to connect so I'm good to go.
There are probably 10 or more mods I'd like to code eventually but I'm looking first for the specific code and step-by-step procedure to delete S5AP and enable the Euro anti-dazzle LED high beam function on my LCI 2014 F10. I've found code for Enable auto high beam default but not specifically for the anti-dazzle enable. Anyone have a link?
