2010 2011 BMW 5 Series Forum F10 Installed M5 Exhaust this weekend |
04-12-2017, 06:04 PM | #24 |
Rep 1,154
btw here's the part # (in this thread) for the cross members/nuts/bushings
http://f10.5post.com/forums/showthread.php?t=963730 |
04-26-2017, 09:19 PM | #25 |
Rep 237
So I installed M6 mufflers and the sounds is great. I'm currently working on something that will an a vacuum option to the rear (535i don't have this). Along with the OEM valve I hope to complete in 2 weeks. I'll keep you posted.
If anybody know the pigtail/harness for the OEM valve, please let me know. |
04-26-2017, 11:44 PM | #26 | |
Rep 1,890
04-27-2017, 03:33 PM | #29 | |
Rep 554
'If the mounts are present, I see no reason you couldn't add the vacuum actuated valves to each side. That would be a cheap junkyard part. The next step would be routing a vacuum line from the engine to the trunk space to interconnect to the Pierburg Vacuum Switch (cheap to buy). Then you would need to connect the muffler valve vacuum lines to the Pierburg Switch. After that you could install an ExhaustMeister. Since your car lacks the switch from the factory, you would need to run a +12 volt supply to the ExhaustMeister. That part is easy since the battery is in the trunk.' It's a little bit of work but sounds possible. If you go that route and get all of the components in place, you would just need to cut the male connector off of the ExhaustMeister harness and direct wire to the battery in the trunk. |
04-27-2017, 03:56 PM | #30 |
Rep 237
I am running the vacuum from the engine bay to the rear. I found the vacuum source from a 525i. Testing the vacuum this weekend.
Do you have the pigtail/harness for the Pierburg Vacuum Switch? I also need to know where this goes to. The switch is cheap and easy to buy. |
05-04-2017, 12:00 PM | #32 |
Rep 237
Finally got to my testing and figured out a way to make the quad exhaust with valves work on a 535i.
I'll start a new thread with the details in the next couple of days. |
05-10-2017, 10:10 AM | #33 |
Petrolhead
440
Rep 806
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
This picture clarifies (for me at least) why BMW moved the Comfort Access and TPMS modules on the M5. That proximity to the tips will surely damage them in no time.
05-10-2017, 11:13 AM | #34 |
Rep 554
07-21-2017, 09:26 AM | #36 | |
Rep 4,209
The mufflers them selves will be axle back. |
