2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
02-12-2013, 10:05 PM | #45 |
Rep 64
To start car without holding break down with your foot:
Change both values to, ->nicht_aktiv CAS -> 3000 TC -> TC_STARTLOCK_BRAKE CAS -> 3000 TC -> TC_STARTLOCK_DRIVINGREADINESS |
02-13-2013, 06:57 PM | #47 |
Rep 852
For those messing with the HUD turn signals, an interesting thing I have found is that somehow the "profiles" are linked to whether they work or not. If you program them and they seem to only work some of the time, go into the profile menu and switch to one of the other profiles (even if still named '----' by default). You'll find one where it is 'working'. Unsure if this will happen with any other settings, but figured I would share my experience.
REF: HUD TURN SIGNALS KOMBI -> 3008 -> HUD_PIA_BLINKER -> aktiv KOMBI -> 3008 -> BLINKER_HUD_ENABLE -> aktiv HU_NBT -> 3000 -> HUD_TURNSIGNAL -> aktiv Display turn signal indicators in the HUD |
02-14-2013, 10:53 AM | #48 |
Internet Crash Test Dummy
331
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
I would think some of the coding settings are tied to the profile you had activated while coding the car.
I've never confirmed/tried as I haven't used the other key yet Now the interesting test would be if the settings would move with the profile to another car (doubt it)
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
02-15-2013, 05:04 AM | #49 | |
Rep 852
02-23-2013, 06:33 AM | #50 | |
Rep 108
Drives: X535d; M2, M3, M5, 540d, AMV8V
Garage List 2016 BMW X535i [0.00]
2015 Aston Martin V ... [0.00] 2015 BMW M4 Convert ... [0.00] 2013 BMW M5 [0.00] 2010 BMW X535d [0.00] |
09-13-2014, 03:08 PM | #51 |
Rep 14
Hey Bimmer fans,
Real quick question, do i need to install token for E-SYS? I heard mixed answers to this. Some people say yes and some people say no if you are just coding. |
04-08-2016, 07:36 AM | #54 |
Old BMW Fan
Rep 25
Can no longer code after a software update!
I have a F10 550i 2013; I had the car at the dealer for some work and they updated the software on the car.
Because of that I lost my coding. No problem, I thought, I just redo it. I can connect, activate, read the ecu but when I try to read any data I get an error that it can't read it. Does anyone have experienced this before? Btw: I am using Esys 3.27.1 |
04-24-2016, 02:29 PM | #55 |
Rep 15
I have changed cars from F36 to F10 and have successfully programmed most things. However, I am having challenges finding 2 settings, as F10 does not have FEM_BODY:
1. Programming Triple Blinkers for turn signals. Default is 3. On the F30, this setting is in FEM_BODY, under "BLINKZYKLEN_ANZAHL_TIPP". Looking for the F10 setting. 2. Also, what is the F10 equivalent of "CM_LOGIC_R_OFF_DOOR". This is to turn off Radio and Navigation when driver door is opened. |
04-24-2016, 10:20 PM | #56 | |
Rep 5,353
The F10 is the same as F30... |
06-30-2016, 01:04 PM | #57 |
Rep 357
Drives: 19' M2C
07-22-2016, 12:26 PM | #58 |
Rep 1,123
08-18-2016, 09:16 PM | #59 |
Rep 39
Drives: 2014 M235i Estoril Blue
iDrive Start Screen Animations
For anyone that is wondering how many start screen animations there there are and what they look like, I've put together a playlist:
https://www.youtube.com/playlist?lis...218z-oP0TnN-HF Enjoy! |
NV GUNS57.50 |
08-18-2016, 10:28 PM | #60 | |
Rep 357
Drives: 19' M2C
08-18-2016, 11:32 PM | #61 | |
Rep 5,353
TIA! |
08-23-2016, 12:18 PM | #62 |
Rep 39
09-07-2016, 07:47 PM | #63 |
Rep 8,364
09-08-2016, 12:03 AM | #65 |
Rep 8,364
But do you do get Weather Band, which NBT does not
09-08-2016, 07:35 PM | #66 |
Rep 5,353
