2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Fuel supply malfunction
      12-31-2011, 01:39 PM   #1
sali
Drives: 18 911, 16 Range Rover
My F10 showed a fuel supply malfunction while driving with 1/4 gas in tank. I pulled into a gas station to get more gas and see if restarting car helps. After refueling the car refused to restart with heavy vibrations.
Finally got the car towed and now it restarts fine with no error message. I'm still at dealership.
Is it a known issue?
      12-31-2011, 02:22 PM   #2
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
what is your build date? early f10's had the fuel level sender replaced in a recall campaign.
      01-03-2012, 11:10 AM   #3
sali
Yes, just verified and it is indeed early built.
I am still waiting to hear back from the dealer. It was pretty annoying that I had to yell at the service advisor to speak with his manager to get a loaner car as he said he didn't have anything and suggested they could drop us off at the nearest bus stop in NJ while we live in NYC.
      01-03-2012, 11:31 AM   #4
gatoman39
gatoman39's Avatar
Make: BMW Model: 5-SERIES
Model Year: 2011
Manufacturer: BMW OF NORTH AMERICA, LLC Mfr's Report Date: JUL 21, 2010
NHTSA CAMPAIGN ID Number: 10V331000 NHTSA Action Number: N/A
Component: FUEL SYSTEM, OTHER:STORAGE:FUEL GAUGE SYSTEM
Summary:
BMW IS RECALLING CERTAIN 2010 AND 2011 5-SERIES AND 5-SERIES GRAN TURISMO PASSENGER VEHICLES MANUFACTURED FROM JANUARY 12 THROUGH JULY 1, 2010. THE VEHICLE'S FUEL LEVEL SENSOR WITHIN THE FUEL TANK CAN BECOME WEDGED AGAINST THE TANK.
Consequence:
IF THIS OCCURS, THE FUEL GAUGE IN THE INSTRUMENT CLUSTER WOULD DISPLAY A LARGER AMOUNT OF FUEL THAN WAS ACTUALLY IN THE TANK. AS A RESULT, IF THE TANK BECAME EMPTY, THE VEHICLE COULD STALL INCREASING THE RISK OF A CRASH.
Remedy:
BMW WILL NOTIFY OWNERS AND DEALERS WILL REPAIR THE VEHICLES FREE OF CHARGE. THE SAFETY RECALL BEGAN ON OCTOBER 18, 2010. OWNERS MAY CONTACT BMW AT 1-800-525-7417.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
      01-03-2012, 12:32 PM   #5
sali
Just called the guy again. He said it was a high pressure fuel pump failure. He said they are replacing it. Strange the high pressure fuel pump died with just 5100 miles on the car.
      01-03-2012, 12:38 PM   #6
gatoman39
gatoman39's Avatar
This was a big problem in the last version N54 engines. Haven't seen many N55 current versions with that problem.
      01-03-2012, 12:49 PM   #7
sali
The adviser said its a common problem.
You are right as I thought this issue was limited to N54 but then again, there is little data on N55 (just a year).
      01-03-2012, 12:54 PM   #8
gatoman39
gatoman39's Avatar
The N55 actually has been out for quite some time now. I believe it debut in 2009 on the 2010 535GT. Calender wise I think it's about 2.5 years, but don't quote me.
