2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media Just my normal F11 with 464M's
      12-28-2014, 08:31 AM   #1
C5 FOR
Drives: G05 xDrive30d Mineral White
Trying to compete with some of you guys is just impossible, but I gave it my best shot and here she is..............
      12-28-2014, 08:38 AM   #2
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Don't sweat the competition aspect. Your F11 looks great! Cheers.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      12-28-2014, 09:10 AM   #3
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
Nice, sohisto gray?
      12-28-2014, 09:55 AM   #4
C5 FOR
yep, Sophisto Grey "Xrallic"
      12-28-2014, 10:09 AM   #5
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Very nice F11, and I really like those OEM wheels.
      12-28-2014, 05:08 PM   #6
C5 FOR
This was my post on the UK web site with the pics you've seen, im not sure how much cross Atlantic sense it makes to youz guys, but thot In would share anyway, this from a Scotsman, who, loves his 5T and is feeling a bit Brave!!!!
Heres the post..................
Recently took delivery of my new F11 520d M Sport in Sophisto Grey and wanted to give some comparisons to my previous 2011 F11 which was also a 2.0d M Sport but in Alpine White.
So, firstly a short summary of specs and previous ownerships.
2008 – 2011 E61 525i M Sport in Le Mans Blue with 19” 172M’s. (I still miss this car so much!!)
2011 – 2014 Alpine White model had the N47 engine and was fairly decently spec’d. I put the OEM black grilles on it and also taped the chrome indicator surrounds. (didn’t spec the ambient ltg so there was no need to worry about the chrome strips on the door handles!). De badged. Kept the standard 19” 351M’s. So with the exception of the alloys it was a black and white car (or should that be white and black??). Eight Speed Sports auto transmission.
Current model has the new B47 engine version (more of which later), manual gearbox (more of which later), Matt Aluminium exterior trim and roof rails, M Sport Plus package (Harmon/Karmon, SPG, and the 19” 351’s) Pano sun roof, LED adaptive headlights, ambient ltg, Pro Sat Nav, the MFIP as i call it (Multi Function Instrument Panel), VDC and the always lovely Grey Shade band. In keeping with the chrome feel i stuck the kidney grilles from the Modern Touring on it as well. Chose a set of 20” 464M’s for her as I was desperate for the mixed wheel look and something a little more distinctive overall.
The main difference or change I wanted to make was to get as far away from an automatic gearbox as fast as I could. The auto gearbox made me a lazy driver and the longer it went on the more “disconnected“ I felt from the car. Specifying the manual box was the easiest decision i was ever going to make and it has been more than worth it. On taking delivery and driving away the driving sensation was immediately back, I could feel the car, the biting point, the ability to flip the throttle, the driving vibration through the clutch pedal and just the overall sense of being in charge of that throttle again without some piece of software making decisions for you. On the previous F11, I used the paddles a handful of times in 3 years and whilst they are good on roads where you don’t have to turn the wheel and can keep your fingers on the paddles continuously as soon as the wheel needs to do a 90 deg plus turn, you don’t have control of the gears any longer. Would appreciate your feedback on this point, yes there’s a case to be made that you make the gear changes before turning into the corner, hence no need to make a shift up (or down) when you are in the corner, I just felt that the shifts between the gears were quite short and needed to be made more quickly as you were exiting a corner and crucially before the wheel was back to less than the 90deg and then having to get your fingers back on the paddles again..........
The improved engine is an exceptional piece of engineering. The previous N47 as I have stated before (not on this forum) was like starting a cold tractor and despite all of its good points (torque, /power ratios) I never quite got away from the farmer in the morning carry on. This new B47 has been dramatically improved, not just with its cold start “noise” which has been improved beyond measure, but i’m sure i can hear it purr when in any mode above Eco Pro. I don’t feel a tremendous difference for the increased lower end torque/power output over the old version but the refinement is undeniable.
LED Adaptive Headlights/High Beam Assistant – WOW!!! what a package this is. I must admit my first reason for specifying this was for its looks, the eyebrow indicator light and the goddam mean sporty look of the headlights themselves with the distinctive flattened corona rings and the LED light display split across the centre of each of the 4 rings. I realised from the start after some research there was a lot more to this package that its good looks. There’s a BMW video on YouTube of their operational aspects and it is just awesome. Are they better than the Visibility Package/Bi Xenons on the old F11, yes would be my opinion all day long. They do take some getting used to at night, when you push the High Beam Assistant to “on” and there’s a car coming towards you, your first instinct is to switch it off as the headlights are still on full beam, but only after a while do you realise no–one is flashing back at you to put the high beam down, the adaptive tech is doing all the work (the video explains how it works).
VDC – specified this time round as I was putting the 20” 464M’s on the car, the previous model was the standard M Sport suspension. I see a noticeable improved difference in the ride across all settings but overall when I look at the car I think it sits higher than the M Sport suspension model particularly at the front. The gap from the top edge of the wheel to the wheel arch is more than i recall. I see there has been some debate on this and wondered if there was a definitive answer? Seems that the M Sport suspension is deleted when you spec the VDC and that is making the difference???? Overall tho, I think having the VDC is needed with the rims I chose. I’m not planning a “drop” at all.
MFIP – quite simply put, a marvellous piece of tech. From the “flashing lights” to advise gear changes in “sports” mode to the vastly improved “Eco Pro” screen, this piece of kit just keeps giving and giving. The Sat Nav aspect display improvement on their is sublime and so much easier to follow than what wasn’t a bad version before. I thought the full black panel display on the previous version was excellent but this tops it 10 fold. Where this tech takes us in the future is something I’m really looking forward too. Will we be able to customise our own displays and colours within the required parameters of what needs to be shown on it – who knows how far this could go!!!
In summary, a vastly improved car from the previous model, the engine refinements, interior spec improvements, headlights and that manual gearbox have made me one happy Han Solo.
So there you have it, hopefully some good feedback for you and now may I present my new Falcon (via some rather poor iPhone camera pics)
Jet in Oz184.50
Bbb34730.50
      08-21-2016, 07:16 AM   #7
Steveo535
Drives: Phytonic Blue X3MC
Thanks for the review C5 FOR.
Lovely looking car and love the alloys.
Read it with great interest as I am trading in my current 2012 535i F11 to a new 535i F11 due of delivery end of September.
Have also chosen the LED adaptive headlights, VDC and MFIP and one or two other options.
A quick question if you don't mind how do you find the panoramic sunroof and do you use a great deal, I ask as some people have said it makes a massive difference to interior light if you have the Black dakota leather which I will have.
cheers Steven
      08-22-2016, 02:24 PM   #8
C5 FOR
cheers Steven
Steven,
Pano roof is used anytime I can, the internal blind is never shut. It brings a serious amount of light into the car and I have the Oyster leather.
My only picky point would be that the front portion of the roof that opens is the smaller section, I would prefer it like the wife's X5 with both portions opening and the larger section at the front.
You have a great car on the way, always wanted that Diesel engine but the extra cost limits the options tab somewhat.
The pics I posted were rather simple, I have others but need to edit them down in size which I haven't found a suitable app for.
Send us all a pic when your beast arrives.
      08-23-2016, 02:56 PM   #9
Steveo535
Thanks for the reply C5 FOR
The info on the roof was much appreciated as when I ordered mine the dealer didn't have an F11 with a sunroof so nice to get a real world opinion.
The car I've ordered is a petrol 535 I looked at the diesel but I just don't do the mileage to get diesel.
Look forward to some more pics really do love those wheels very tempted when I've had mine a year or so to pop a set of those on.
      08-28-2016, 05:36 PM   #10
C5 FOR
My Falcon.
      08-29-2016, 12:46 PM   #11
remmib
remmib's Avatar
Norway
1568
Originally Posted by C5 FOR View Post
My Falcon.
As I said before, such a good looking OEM wheel.
      08-30-2016, 12:58 PM   #12
Bbb34
Drives: '11 535i 6sp. DHP/RWD
Nice
Shame we dont' get F11 in North America.
... ideally with RWD, manual, and 550 V8 engine
I've got one thing to say to you on this, and, it goes something like this:
I just wish more people would get to experience these cars with manual transmission.
      08-31-2016, 05:14 PM   #13
C5 FOR
Originally Posted by Bbb34 View Post
Nice
Thanks Bbb34, nearly wanted to type BB8.....
I fear we may be fighting a battle already lost.....
      08-31-2016, 06:09 PM   #14
Bbb34
We are, and in my view, it's such a shame.
In the meantime, we get to enjoy them while we can.
I mentioned it in another thread, never yet met anyone who's done what you just did and went "awwww I really miss my automatic transmission" but hear the argument going the other way all the time.
      09-01-2016, 03:57 PM   #15
sqeezed
sqeezed's Avatar
Drives: BMW 2014 M5
so sharp nice car
      09-02-2016, 09:30 AM   #16
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
The 464 wheels looks great on your beautiful Touring!
      09-02-2016, 03:09 PM   #17
C5 FOR
Thank you all for the kind comments.
I love this model, but fear for a possible watering down yet again for the new version.
It may be the last Touring I drive...........
      09-02-2016, 03:27 PM   #18
Bbb34
It met be the last Touring I drive...........
Only worry about things you can control, right .
If that's the case then you have a very special car on your hands, enjoy it.
Oh, and all F11s I have seen, look even better in person.
C5 FOR172.00
      09-10-2016, 04:28 PM   #19
vladberca
vladberca's Avatar
Romania
763
These wheels look awesome! 👍
